Center Speaker Placement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-21-2013, 06:37 AM - Thread Starter
C130's Avatar
How/where do most people mount their center speaker? I have a dedicated home theater room in a newly constructed house and currently the center speaker is mounted to the wall just below the screen. The speakers were installed by a company affiliated with the builder and I don't care for the center speaker and have one that is much better but it's also much bigger. The center speaker I want  to use has no place on the back to mount it so trying to figure out where to put it. I have seen some brackets that mount to the wall and holds the center speaker which is an option.
C130 is offline
post #2 of 3 Old 01-04-2014, 06:48 AM
jdsmoothie's Avatar
Quoted: 15053 Post(s)
Liked: 7263
Have you considered setting the center speaker on a stand?
jdsmoothie is offline
post #3 of 3 Old 01-04-2014, 05:15 PM - Thread Starter
C130's Avatar
Yes, that's what I'll probably do. I just wasn't for sure what's the most common method of placing it. Any recommendation that you guys sell? All of the rest of my equipment will be in the back of the theater room.
C130 is offline
Reply Theater Room Items & Accessories
