Palliser tray table socket retrofit question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-21-2013, 01:30 PM - Thread Starter
2hotinaz's Avatar
I have a Palliser home theater seat, and would like to add the small tray table socket that is shown forward of the cupholder in the armrest. I can feel through the upholstery that the hole for it is already drilled in the wood frame. Has anyone done this? Does Palliser sell the socket and whatever retainer holds it in? It appears that by removing the black felt on the bottom of the chair, one can reach up and access the underside of the armrest frame. The upholstery is leather. I don't live near a furniture repair place or dealer so this would likely be DIY unless it is too risky/complex. Thanks!
2hotinaz is offline
post #2 of 14 Old 12-23-2013, 07:23 AM
KenLerch's Avatar
Yes, this can be done. Please contact me offline for more info.
Ken Lerch
StargateCinema.com
Home Theater Seating and Decor
HTSeating.com
KenLerch is offline
post #3 of 14 Old 05-08-2014, 04:22 PM
justinlutsky's Avatar
Did you ever figure this out? I just received an order of 4 Pacifico II seats from TheaterSeatStore.com and only 2 of the 4 seats had the sockets, even though I ordered 4 trays. I'd also like to add additional sockets to the other two seats. Thanks!
justinlutsky is offline
post #4 of 14 Old 05-08-2014, 09:19 PM - Thread Starter
2hotinaz's Avatar
You should feel an existing socket hole through the arm padding. Mine were pre-drilled. The Palliser socket is a hefty steel cylinder (with spring-loaded cover), and a polished estucheon piece that screws on (tighten it to hand-tight now). It comes with some various bolts and studs for different chairs I guess. Tip the chair over, unstaple the black felt on the chair bottom under the arms, and look up into the arm. You should see an interior wood brace with a hole, and then another wood piece with a bigger hole not visible in the pic (the arm itself). I could feel the armrest padding through it
. Once you have the sockets in-hand and confirm they match your other ones, take a deep breath and poke a hole through the center of the armrest hole through the padding and the upholstery. Right the chair; you should have a tiny hole centered in the soft area you felt earlier. Take an Exacto knife or razorblade, hold it vertical, and cut from the hole out to where the knife hits wood. I made eight cuts; you can use scissors once you know the size. You should now have an asterisk-shaped hole matching the hole in the wood. Press the socket through, letting the upholstery and padding fold down alongside. If the socket is too tight, take out some of the cut padding. The estucheon will easily cover any minor goofs. Turn the chair over again, and thread the bolt with washer into the bottom of the socket that should now be lined up with the hole in the inner brace. Yours may attach slightly differently. Tighten using a ratchet and long extension, with your hand on the center of the ratchet (not mega-tight). The socket will compress the upholstery and then feel tight. Restaple the bottom felt and you're done! Took about one hour for all four sockets.The estucheon unscrews so you can clean underneath, just don't yank the upholstery up past the stub of the socket.
KenLerch likes this.
2hotinaz is offline
post #5 of 14 Old 05-08-2014, 09:36 PM
Thanks so much for the detailed response! Where did you actually obtain the additional socket hardware?
-Justin
post #6 of 14 Old 05-09-2014, 09:43 AM
KenLerch's Avatar
Great instructions, 2hotinaz.
I also sent you a PM, justinlutsky.
Ken Lerch
StargateCinema.com
HTSeating.com
KenLerch is offline
post #7 of 14 Old 02-25-2015, 11:08 AM
Extreme's Avatar
anyone else figure this out , I am in the same vote , want to add a side table , im looking for 2 socket and 1 side table , but cant locate online anywhere , I can only find the side tables.
Extreme is offline
post #8 of 14 Old 02-25-2015, 11:52 AM
HTmarket's Avatar
Quoted: 195 Post(s)
Liked: 46
contact us and we can get the grommets from palliser it can take a while though probably 2 to 3 weeks as they slow in shipping parts.
Alan Hutchinson
HTmarket.cm
HTmarket is offline
post #9 of 14 Old 02-25-2015, 02:48 PM
Extreme's Avatar
Any ruff idea on price I called a few places they wanted $75 each, way way over my price range do you know model number or what exactlly that piece is called
Extreme is offline
post #10 of 14 Old 02-26-2015, 08:59 AM
HTmarket's Avatar
Quoted: 195 Post(s)
Liked: 46
That's probably about what we would quote with tray table or was without tray table?
HTmarket is offline
post #11 of 14 Old 02-26-2015, 09:58 AM
Extreme's Avatar
they didn't say , I did ask for just the socket tho , I am looking for 2 of the sockets.
Extreme is offline
post #12 of 14 Old 02-27-2015, 10:21 AM
HTmarket's Avatar
Quoted: 195 Post(s)
Liked: 46
I can probably include the tray table with that price, contact us offline and I'll get you a price.
Alan Hutchinson
HTmarket.com
HTmarket is offline
post #13 of 14 Old 06-07-2015, 10:25 PM
Liked: 2
Alan
can u contact me Id like to do this also.
thanks
Lorenzo Calce is offline
post #14 of 14 Old 01-24-2016, 12:32 PM
drober30's Avatar
Thanks for posting this! I was able to fix my Tray Tables from learning by tightening them up!
drober30 is offline
Reply Theater Room Items & Accessories
