Wallmount Candy/Concession Paper Towel Holder - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-13-2014, 06:35 PM - Thread Starter
nuAVfan's Avatar
This is my brainstorm for a wallmount holder for candy and a paper towel holder. I used clear containers that were once used for roasted peanuts purchased at our local grocery store. I removed the labels and built the shelves to fit perfectly to there measurements. Textured paint from Lowes applied with a clear coat and bingo i have a candy display at eye level. What do you think?
nuAVfan is offline
post #2 of 3 Old 01-14-2014, 07:42 AM
socal swagger's Avatar
Quoted: 54 Post(s)
Liked: 25
nice what are the demensions
socal swagger is offline
post #3 of 3 Old 01-15-2014, 02:34 PM - Thread Starter
nuAVfan's Avatar
The dimensions are 10 1/2 " x 18" and each shelf is 6 inches deep. This works great. using previous roasted peanut containers for candy. I used a flush mount picture bracket to hang it to the wall. The underside and rear are not boxed in, just painted flat black and a cross memeber attached on the bottom for the paper towel holder.
nuAVfan is offline
Reply Theater Room Items & Accessories
