TV Stand with mount missing bracket - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-19-2014, 08:07 PM - Thread Starter
slow-mo's Avatar
So I bought a TV stand with mount from Craigslist and apparently it's missing the bracket that mounts to the TV. The situation is almost identical to the one here. I was also under the impression that the TV would mount directly to the square swivel plate (pic below). I can't find the manufacturer of the stand and the original owner has conveniently become unresponsive. What I'm wondering is that could a fixed/tilt wall mount work in place of the missing bracket? My TV is a slim Samsung 55" listed at 40lbs. My assumption would be that if I can find a mount that supports my TV size and weight and lines up to the holes on the plate that I should be okay. Any advice would be appreciated. Thanks!
The stand I have
What I believe it should look like
LEAD Technologies Inc. V1.01
slow-mo is offline
post #2 of 3 Old 02-19-2014, 09:31 PM
johnnygee88's Avatar
Honestly if i were you i wouldn't risk it. Just a buy new stand. I have seen stands like this with only a square bracket, but only for small TVs not 55"
johnnygee88 is offline
post #3 of 3 Old 02-21-2014, 09:44 AM - Thread Starter
slow-mo's Avatar
Thanks that's kind of what I figured. I'll chalk it up to a lesson learned when buying from Craigslist rolleyes.gif ...thanks for the response.
slow-mo is offline
Reply Theater Room Items & Accessories
