linking 2 PF60 together? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-28-2014, 10:01 AM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
Can you link 2 belkin PF60's together via the trigger on back? I need to be able to turn on one and other come on. I have one showing thru wall so I just turn on system but have other devices to far away to plug into and don't want 2nd PF60 showing thru wall.
Klipsch RF82II Fronts & Wides
Klipsch RC64II Center
Klipsch RB61II Heights & Surrounds
2X Elemental design 15" subs W/ O-audio amps
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
New theater under construction!
robc1976 is offline
post #2 of 9 Old 03-01-2014, 07:33 PM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
any input guys? Basically want 2 PF60's so I can plug each sub into them...they are to far apart to plug both subs into one PF60. I leave my subs in "on"position instead of the "auto" position...auto causes problems. I basically just want a way to turn subs off instead of on all the time.
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #3 of 9 Old 03-02-2014, 03:15 PM
bluer101's Avatar
Quoted: 347 Post(s)
Liked: 279
I run 2 12 ft extension cord to my subs off the PF60. I also leave mine on then triggered by my Denon thru the PF60.
But you should be able to trigger one from the other. The backs of the units have in and out but never tried.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #4 of 9 Old 03-02-2014, 04:11 PM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
would one need to be plugged into the other to cut power? I want them both plugged into a outlet...how would the trigger cut power?
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #5 of 9 Old 03-02-2014, 04:59 PM
bluer101's Avatar
Quoted: 347 Post(s)
Liked: 279
The trigger does not cut power really. It makes the outlet switched which is assignable on the back of the PF60. Then you need to turn on remote from the front panel. Then have your receiver trigger out or switched outlet to the PF60. I hope you understand. 2 PF60 units are not really necessary unless you need all those outlets.
bluer101 is offline
post #6 of 9 Old 03-02-2014, 05:18 PM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
not about outlets it's about location, in pic below in right you will see the PF60, when I turn that off everything but one sub turns off...I don't want to run a extension cord thru control room do basically the screeching PF60 would just be a way to turn off both subs at same time do I dint have to go into control room everytime lol! I want to be able to turn off everything from theater and nit have subs on all the time. Subs are between mains in wall.
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #7 of 9 Old 03-02-2014, 05:43 PM
bluer101's Avatar
Quoted: 347 Post(s)
Liked: 279
I found this while reading, Even the 12V trigger out can be switched or delayed. This output can be used to trigger other power consoles allowing the units to be easily daisy-chained.
So I guess you can use the 12v trigger out in the back of one Belkin to the other Belkin. Just choose the delay time.
robc1976 likes this.
bluer101 is offline
post #8 of 9 Old 03-02-2014, 06:15 PM - Thread Starter
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
exactly the info I needed...I couldn't find it lol!
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #9 of 9 Old 03-03-2014, 06:15 AM
bluer101's Avatar
Quoted: 347 Post(s)
Liked: 279
Let me know if it works.
bluer101 is offline
Reply Theater Room Items & Accessories
