LED Strips for indirect lighting in a dedicated home theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-06-2014, 10:06 PM - Thread Starter
ClemsonJeeper's Avatar
Quoted: 228 Post(s)
Liked: 139
I'm finishing up planning my dedicated HT build. Right now I have a fully drywalled rectangular room (no soffits), and I want to create a tray ceiling with cornice molding for indirect lighting.
I'm looking for help on the lighting to use. I'd love to be able to find some multi-color LED strips (or rope lighting) that I can run around and control to create dynamic color combinations (and dimming)? What do most people use if this is even possible?
Found these http://www.wholesale-leds.com/lightsledrgbsuperbrightremotecontrolledleddisplaylight16feetreel.aspx?gclid=CNCVoYS_zb0CFSqXOgod2FIAPA
but not sure how many I can chain together and if I could create an interface with them to tie into my HA system.
Any suggestions? Thanks!
November 2015 HT of the Month: The Vortex Theater
My Home Theater Build: The Vortex Theater Build
ClemsonJeeper is offline
post #2 of 6 Old 04-07-2014, 10:24 AM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
those are basically the same as what I bought(got mine off amazon) to put around my raised seating. for me, the only issue is they are still pretty bright on the dimmest setting, so it's not really possible for me to use them while watching anything as the light washes out the bottom portion of my screen.
I believe you can chain a bunch of them together, they all come with their own power supply, so I suppose worst case you run a couple control/power boxes. as long as the remote sensors are both visible, both chains should react the same way as if they were directly connected anyway.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #3 of 6 Old 04-12-2014, 07:03 AM - Thread Starter
Quoted: 228 Post(s)
Liked: 139
So what would people recommend then? Just pick a color and get a normal rope light coil of it and use that? That way they can be dimmed pretty low?
I'd like to do a painted night ceiling, so a black light rope would be nice too.
post #4 of 6 Old 04-18-2014, 07:37 PM
ADDUpstate's Avatar
I've ordered a bunch of kits from barlighting.com with no issues whatsoever. Ships fast and quality product.
ADDUpstate is offline
post #5 of 6 Old 04-18-2014, 09:08 PM
rxman's Avatar
Quoted: 13 Post(s)
check out Philips hue lighting,the have spot & "rope" sets that you can change to color of your choice,very nice for HT
rxman is offline
post #6 of 6 Old 04-18-2014, 09:19 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Yikes those are expensive for 2 meters!
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
Reply Theater Room Items & Accessories
