Home theater racks? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By deewan
post #1 of 14 Old 06-20-2014, 01:33 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 136 Post(s)
Liked: 37
Home theater racks?
I'm getting ready to build my first dedicated home theater room and see many of you have home theater racks that have your electronic components stacked and sunk into the wall. Some have faceplates around the systems so you cant see behind it. Where do you get these? Do you have pics of yours?
mpjmeyer is offline
post #2 of 14 Old 06-20-2014, 01:38 PM
deewan's Avatar
Quoted: 256 Post(s)
Liked: 250
The shelves and faceplates are from Middle Atlantic. RSH custom shelves.
For a rack, watch craigslist and ebay. You can save A TON of cash using those two sites. I bought my rack on Craigslist and some shelves and faceplates off ebay. I have spent less on my total rack with shelving than just a rack would have cost me.
deewan is offline
post #3 of 14 Old 06-20-2014, 01:47 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 136 Post(s)
Liked: 37
That looks so clean!!!! Do you have a room behind that for access?
mpjmeyer is offline
post #4 of 14 Old 06-20-2014, 02:06 PM
deewan's Avatar
Quoted: 256 Post(s)
Liked: 250
Yes. On the other side of that wall is my unfinished storage room. I built a "closet around the rack with drywall, 2x4's, and a solid oak door (also found on Craigslist).
deewan is offline
post #5 of 14 Old 06-20-2014, 03:42 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 136 Post(s)
Liked: 37
Incredible!! That looks awesome!!
mpjmeyer is offline
post #6 of 14 Old 06-20-2014, 07:50 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 136 Post(s)
Liked: 37
There's so many different styles. Is yours the mrk series?
mpjmeyer is offline
post #7 of 14 Old 06-21-2014, 04:41 AM
deewan's Avatar
Quoted: 256 Post(s)
Liked: 250
The most important part of finding a rack is to make sure it is a standard 19-inch wide four post rack and has the standard 5/8"-5/8"-1-2" universal hole pattern. Most racks will match this pattern.
FYI - My rack is actually a Chatsworth Quadrarack, but I use Middle Atlantic shelves. As long as its a standard 19 inch wide rack that that hole spacing, everything is interchangeable.
Boxozaxu likes this.
deewan is offline
post #8 of 14 Old 06-21-2014, 06:35 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 136 Post(s)
Liked: 37
Looks great.
mpjmeyer is offline
post #9 of 14 Old 06-21-2014, 09:40 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 136 Post(s)
Liked: 37
I found a great deal on a Middle Atlantic MRK-4426-av rack for only $190. Is this what I should be looking for?
mpjmeyer is offline
post #10 of 14 Old 06-21-2014, 08:38 PM
deewan's Avatar
Quoted: 256 Post(s)
Liked: 250
If that size works for you, BUY!!!! You would be getting a deal and it will work out nicely for you.
deewan is offline
post #11 of 14 Old 06-23-2014, 02:42 PM
Barrettmr's Avatar
Quoted: 105 Post(s)
Liked: 29
[QUOTE=deewan;25128729]The shelves and faceplates are from Middle Atlantic. RSH custom shelves.
QUOTE]
Do those face plates come pre-cut for the devices or do you make them yourself? I have black panels but having the slot cut and the player etc. fitted looks much better :-)
Barrettmr is offline
post #12 of 14 Old 06-23-2014, 02:49 PM
deewan's Avatar
Quoted: 256 Post(s)
Liked: 250
[quote=Barrettmr;25201921]
RSH shelves are cut for you by Middle Atlantic and are ordered based on your device model.
QUOTE]
deewan is offline
post #13 of 14 Old 06-27-2014, 02:50 PM
adamf's Avatar
I have a middle atlantics ASX rack and looking to upgrade to rotating instead of the pull out. If your deal didn't work out, just PM me.
Adam
Our Home Theater
The Bunker
adamf is offline
post #14 of 14 Old 07-06-2014, 06:43 PM
hawnr6's Avatar
Hey Deewan - I actually have the same power center as you do. I didn't like how the silver stood out, so I spray painted it black - its really easy. Plus, the faceplate comes off without turning anything off - so you can still watch while its off..
hawnr6 is offline
Reply Theater Room Items & Accessories
