Just bought Movie theater seats for $350. Good deal? Stadium seating advice? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By bluer101
  • 1 Post By thrillcat
Old 06-30-2014, 07:51 PM - Thread Starter
ODirty's Avatar
Quoted: 24 Post(s)
After months of trying to find seats that would fit in my narrow theater room (currently building), I finally found these movie theater seats that would fit in the room.
It was also important that I find something I could actually get into the room, the hallway is really narrow.
They are super comfy and seem like they are in brand new condition.
Did I get a good deal? He was asking $400 but I got them for $350.
(by the way, the back row of seats are going to be raised on a stage about 8inches, to give the room stadium-type seating.
I dont know much about theater seats, did I get a good deal?
Also, if anyone has done the stadium seating in their HT; how did you go about it? How much did you raise it?
Any ideas are always welcome!
link: http://imgur.com/a/fK62O
ODirty is offline
Old 07-01-2014, 05:49 AM
bluer101's Avatar
Quoted: 347 Post(s)
Liked: 279
They look great to me.
ODirty likes this.
bluer101 is online now
Old 07-01-2014, 07:29 AM
thrillcat's Avatar
Quoted: 175 Post(s)
Liked: 233
Those look pretty nice. I would say you got a pretty good deal...
Here's a Riser Height Calculator: Riser Height Calculator
Here's a Riser Construction Primer: Risers 101
These are very common in dedicated theater construction, so you should spend some time perusing that forum for ideas, tips, techniques.
ODirty likes this.
I love my iPhone, but it will never replace my turntable.
The Cinema 1858 Remodel Thread
thrillcat is offline
Old 07-01-2014, 11:40 AM - Thread Starter
ODirty's Avatar
Quoted: 24 Post(s)
Thanks! That is just was I was looking for!
ODirty is offline
Old 07-01-2014, 05:36 PM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
I just used 2x8's stacked on top of each other to build my riser. imo, 12" is the min I would do. but I find it a comfortable step height, and I'm not getting awkwardly close to the ceiling either. a good compromise for me. I could see going 2-3" higher being worth it in my case though. the screen is hung fairly low, and the only way to see the bottom of the screen from the back row is if the front row is fully reclined.
here's a pic that pretty much shows the whole construction:
fierce_gt is online now
Old 07-01-2014, 05:44 PM - Thread Starter
ODirty's Avatar
Quoted: 24 Post(s)
Originally Posted by fierce_gt View Post
I just used 2x6's stacked on top of each other to build my riser. imo, it's the min I would do. but I find it a comfortable step height, and I'm not getting awkwardly close to the ceiling either. a good compromise for me. I could see going 2-3" higher being worth it in my case though. the screen is hung fairly low, and the only way to see the bottom of the screen from the back row is if the front row is fully reclined.
looks very nice! Good job. I think we are going to build it this weekend so I will post some pics if we do.
ODirty is offline
Old 07-01-2014, 05:46 PM - Thread Starter
ODirty's Avatar
Quoted: 24 Post(s)
thats not a sub in the middle of the first pic is it?
ODirty is offline
Old 07-01-2014, 06:41 PM
fierce_gt's Avatar
Liked: 1570
it is. I cut out some holes to 'vent' it to the outside. not ideal, but it was better than no sub at all, which was pretty much my only other placement option
Old 07-01-2014, 07:20 PM
CinemaAndy's Avatar
Quoted: 700 Post(s)
Liked: 136
Irwin and Seating Concepts are the best makes of commercial auditorium seating you can get. Those Irwin's are stain and fade resistant and will last you for years. These are the older version prestige telescopic seats and looks like Number 2 rocker platform. The rocker platform is how the seats recline, this is what the number means. The seat back, is what kind of seat cushion and back they have. Hope that makes sense for you. In other words that is how they are sold. If you got all six seats, yes it was a good deal. New they were around $175 a complete seat plus cup holders. I'm sure some one redone a auditorium and was given the seats to dispose of, this is the way it usually happens.
If head room is a problem i would go with 1 foot rise. If head room is not a problem i would go with 2 feet rise. For your best bet, simply experiment with the seats height versus screen height until you find your perfect combination. The best, most practical way to do that is to use scrap lumber and add and subtract till it feels right to you, then build your platform to that height. There is not really a right or wrong, it is what you want. Also do not forget about leg room to avoid that commercial someone's kicking your seat feeling, unless you want that experience.
CinemaAndy is offline
Old 07-01-2014, 09:26 PM - Thread Starter
ODirty's Avatar
Quoted: 24 Post(s)
Is that $175 for a set of three? Thanks for the background information.
I did some measurements and used a riser height calculator from diymovierooms.com and it suggested a 16in riser. With our low ceilings, if we did a 15in riser, I believe I would have about 3 or 4inches from the ceiling while standing up on the riser (I am 6ft tall). I am cool with that, because I am the tallest in the house and for the most part, it will just be us using the room.
The room is 17ft long, so we were thinking about doing a depth of approx 5ft, so we can have enough room to put some sort of foot rest/railing attached to the stage.
The consensus here is there needs to be foot rests for both rows, to make the theater seats more comfortable for long sitting periods.
I have been reading about how some people make these and most suggest lining the inside of the stage with plastic and filling with play sand, or insulation (we will do which ever is cheaper).
I also read that the stage/riser should not be totally against the surround walls; to prevent rattling? Is this true?
Has anyone done this?
Thanks again for your input guys, it is much appreciated!
ODirty is offline
Old 07-01-2014, 11:22 PM
CinemaAndy's Avatar
Quoted: 700 Post(s)
Liked: 136
No the $175 is per seat on a minimum order. What i do is on the commercial cinema side, as you guessed headroom is never a problem. So i have little to no experience with any HT set up. When it comes to commercial construction or remodels i know everything but speakers, i leave that to the pros at Christie, Barco and Dolby. I suggest you search the forums for DonaldK or CINERAMAX and look at the outstanding HT's they have done. You will find a lot of answers to your questions without asking them.
movie theater seats
