hdmi wall plates with cat6 or long hdmi cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-12-2014, 03:05 AM - Thread Starter
jrcrunch's Avatar
Quoted: 81 Post(s)
i have a two rooms that are 22 meters aparts but would want the other room to receive the same hd source.
what is a better choice? hoping quality wont degrade and will work well with a hdmi splitter
a cat6 cables with hdmi wall plates
http://www.monoprice.com/Product/?pg...mat=4#feedback
or a very long hdmi cable?
http://www.amazon.com/PTC-Premium-ca...0ft+hdmi+cable
thanks!
jrcrunch is offline
post #2 of 10 Old 07-14-2014, 08:08 AM
NickTheGreat's Avatar
Quoted: 435 Post(s)
Liked: 307
22 meters? That seems too far for an HDMI cable to me. People like the redmere cables, myself included, but they only go up to 60 ft on Monoprice.
I think you're at the balun length here, your first option.
NickTheGreat is offline
post #3 of 10 Old 07-14-2014, 04:03 PM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
But don't use the HDMI wall plate versions of the baluns. Those tend to be cheap, "passive" implementations that are hit-or-miss. If you can run wires, run two cat5e/cat6 lines and use a powered HDMI extender (balun). HDBaseT would be the best solution, but is more expensive.
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #4 of 10 Old 07-15-2014, 05:13 PM
fierce_gt's Avatar
Quoted: 1772 Post(s)
Liked: 1693
fyi, I'm running 30FOOT lengths of hdmi to my projector and a tv in an adjacent bathroom out of my powered splitter, that would apparently be about the max. I rearranged the room, which required me to add a 15ft extension to the cable going to the bathroom, and it no long works properly. it will NEVER work if any of the other displays are on, and it only works about 25% of the time if it's the only display on. I haven't quite figured out what the issue is, it seems to work ok for my computer desktop, but not at all for video.
for a 22 meter run, it's probably cheaper to buy a second source, or maybe one of the wireless transmitters will work over that distance(still pretty doubtful though). that hdbaset or whatever it's called is crazy expensive, and seem to be what's required for those kind of lengths.
fierce_gt is online now
post #5 of 10 Old 07-25-2014, 09:17 AM - Thread Starter
jrcrunch's Avatar
Quoted: 81 Post(s)
hi guys, thanks for inputs do you have any product in mind? i only need one source and hoping to have 2 to 3 outputs. IR capability to control source is required. thanks
jrcrunch is offline
post #6 of 10 Old 06-22-2015, 05:30 AM - Thread Starter
jrcrunch's Avatar
Quoted: 81 Post(s)
sorry need to bump this. are there any new devices for devices that are far from each other? hdmi to hdmi? or hdbaset but it is still expensvie?
jrcrunch is offline
post #7 of 10 Old 06-22-2015, 06:14 AM
Quoted: 3899 Post(s)
Liked: 3333
HDbaseT adapters might get this job done.
post #8 of 10 Old 06-28-2015, 09:41 AM - Thread Starter
jrcrunch's Avatar
Quoted: 81 Post(s)
thanks for the reply. are they still expensive? where is the best place to purchase them???
jrcrunch is offline
post #9 of 10 Old 06-30-2015, 07:27 PM
bpassman's Avatar
Quoted: 125 Post(s)
Liked: 55
thanks!
At work, we use the MP HDMI over Cat all the time in our conference rooms to run TV\Cable to the TVs. They work great.
Brad
AVR Anthen AVM 60 Amp Emotiva XPA-7 & XPA-5 Sources Oppo 203, FireTV, FiOS
Speakers Atmos 7.2.4 - TruAudio B23-465s (LCRs), TruAudio B23-265s (SL/R & SB), Dual SVS PC-2000s (Subs), 4 In Ceilings
PJ JVC RS500 Screen 153" DIY 2.35:1 Spandex
My crazy long build Coffered Ceiling
bpassman is offline
post #10 of 10 Old 08-21-2015, 01:54 AM - Thread Starter
jrcrunch's Avatar
Quoted: 81 Post(s)
which monoprice item do you use in your office? my prob is one room 22 meters away. what kind of cable and brand do you use?
jrcrunch is offline
Reply Theater Room Items & Accessories
