Custom Home Theater Marquee - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 3 Post By jeffbab
post #1 of 2 Old 07-16-2014, 05:20 PM - Thread Starter
jeffbab's Avatar
I bought one of these from Hollywood Marquees. I went directly through their website instead of their ebay store. I think it turned out pretty good. Size is 50" x 18" and a few inches depth. They also offer a thicker version which is slightly cheaper if you don't care about the depth.
If you've seen their older marquees you will notice a difference on this one. It has flashing LED lights that light up around the letter-trak portion. You can see it in action on my youtube video here:
I think the flashing LED lights make a big difference. although it is definitely an expensive option.
Also please ignore the unfinished basement. One of these days I will stop buying accessories and will finish the flooring and ceiling. LOL.
jeffbab is offline
post #2 of 2 Old 07-27-2014, 07:35 AM
fibertech's Avatar
This is who I bought mine from and am pleased with the quality.
fibertech is offline
Reply Theater Room Items & Accessories
