Automated Curtain system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-01-2014, 02:20 PM - Thread Starter
ChldsPlay's Avatar
Quoted: 609 Post(s)
Liked: 317
Can anyone suggest a good place to find a large curtain to close off part of a room, and where a quality automated railing system can be purchased?
Any sound qualities for the curtain would be a bonus, but it is mostly aesthetic to make the theater area more dedicated. Below is an idea of what I'm looking to do:
Curtain Open:
Curtain closed for movies:
The curtain would probably need to be at least 14" wide to cover the area, and about 8' tall.
ChldsPlay is offline
post #2 of 4 Old 08-02-2014, 07:00 PM
beyond's Avatar
Quoted: 37 Post(s)
Liked: 31
Curtain Open:
I've been working on something similar, except mine would be used to cover up a 10ft x 8ft window that the screen comes down in front of. Anyways, I found an AWESOME guy on Etsy, I highly recommend him for his custom work and pricing... As for the rod, I'm going with the powercurtain rod that just came out...
Here's the links:
http://www.lushescurtains.com/
Here's his reviews on Etsy: https://www.etsy.com/shop/LushesCurt...?ref=shop_info
Powercurtain rods:
http://www.powercurtain.com/product_CL920A.shtml
Ordering mine all up this weekend as i'm finally kicking the build into gear...
beyond is offline
post #3 of 4 Old 11-30-2014, 10:26 AM
NateCCIE's Avatar
beyond,
Did you get these installed? How did you adapt the rod-pocket curtains to the power curtain track?
NateCCIE is offline
post #4 of 4 Old 12-01-2014, 10:20 AM
HTmarket's Avatar
Quoted: 194 Post(s)
Liked: 46
For home theater application I would recommend the BTX systems out there. They are heavy duty as they can handle weight of large drapes usually used. The imports out there in the lower price ranges on automated tracks generally can't pull the weight.
Alan Hutchinson
HTmarket
HTmarket is offline
Reply Theater Room Items & Accessories
