Where can I buy two pieces if glass, 22in by 10in. Need to replace sconce glass. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-09-2014, 10:35 PM - Thread Starter
ODirty's Avatar
Quoted: 24 Post(s)
Bought these plug in wall sconces for really cheap to put in my home theater. Only prob is, the glass pieces that go in them are super ugly.
I need some sort of darkened glass to replace these.
Does anyone have the slightest idea where I can find a pair of these to replace them?
Link: http://www.ikea.com/us/en/catalog/products/S19884449/
ODirty is offline
post #2 of 4 Old 08-12-2014, 12:17 PM
Bacon13's Avatar
Quoted: 14 Post(s)
Liked: 39
Local glass shop? They should be able to cut pretty much whatever you want.
Bacon13 is offline
post #3 of 4 Old 08-12-2014, 12:53 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
So you want to remove the glass with lettering for a plain piece of frosted glass?
If the letters can be removed, you can buy a spay on frosted glass product. I would apply the frosting to the back of the glass. If you can not get the letters off, any hardware store can cut a piece of 1/8" glass to your size. Then frost the back and install. I used the frosting spray on a bathroom cabinet that I put in a powder room so as to hide all the stuff in side. You can make it as opaque as you want it by applying additional coats.
http://www.walmart.com/ip/Rust-Oleum...Spray/17011140
Another way to achieve frosted glass is to sandblast one side. I cut a piece of 1/4 glass I had to make a shelf for below the cabinet and sandblasted one side, it turned out very nice. I would have done the same for the cabinet but could not remove the glass..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 4 Old 08-12-2014, 07:06 PM
bluewaves's Avatar
Find your local glass shop
bluewaves is offline
Reply Theater Room Items & Accessories
