What gives off more heat? 100-inch TV or Protector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-10-2014, 06:41 AM - Thread Starter
moigpsrocks's Avatar
My home theater has a real problem with overheating especially in the summer.
There is no Air condition line and simple a small fan to bring in outside air. The theater was design by the previous home owners. Anyway, I was thinking of either getting a 4K protector or a 4K large TV but was wondering which type threw out more heat?
moigpsrocks is offline
post #2 of 8 Old 08-10-2014, 01:58 PM
jautor's Avatar
Quoted: 1147 Post(s)
Liked: 745
A "big" LED-LCD display probably in the 150-200W range, projector around the 250-350W range... Not an enormous difference that I'd base the whole project on.
jautor is offline
post #3 of 8 Old 08-10-2014, 07:41 PM
Sonyad's Avatar
Quoted: 168 Post(s)
Liked: 101
I've never heard anyone complain about heat from a tv whereas heat from a projector is often an issue.
Sonyad is offline
post #4 of 8 Old 08-10-2014, 08:25 PM
olyteddy's Avatar
Quoted: 522 Post(s)
Liked: 903
You haven't been up in the Plasma forum then...
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 8 Old 08-10-2014, 08:30 PM
Sonyad's Avatar
Quoted: 168 Post(s)
Liked: 101
True dat.
Sonyad is offline
post #6 of 8 Old 08-10-2014, 09:41 PM
airscapes's Avatar
Quoted: 335 Post(s)
Liked: 278
Um.. what is in the theater now?
Sounds like you should be upgrading the cooling rather than the video display..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #7 of 8 Old 08-10-2014, 09:58 PM
fierce_gt's Avatar
Quoted: 1595 Post(s)
Liked: 1525
agreed. fix the problem instead of avoiding it.
but to stir the pot, a projector could be placed outside the room in a 'projection booth' and contribute no heat whatsoever. still, it'd be less work to fix the ventilation in the main room.
what I can tell you, is that the Samsung f8500 I have in my basement runs at about 40C, and I have not had any issues with heat in the room whatsoever. I had an Epson hc720 projector that used to cause me some heating issues(though I believe that may have been more about the retractable screen restricting airflow), and I currently have a jvc x35 projector that also has caused no issues with heating.
like anything, some models will be more efficient than others too.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #8 of 8 Old 08-13-2014, 07:20 AM
jautor's Avatar
Liked: 745
Remember that the temperature of a piece of equipment is only an indicator - it's really a question of power consumption, since 100% of the electricity used by all these devices is turned into heat. As fierce_gt says, if you can move that equipment out of the room, the heat generation moves out as well.
Do a search through the forum for "mini-split" AC systems, which might be an option for the room...
jautor is offline
Reply Theater Room Items & Accessories
