Mounting large surround speakers - need suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-16-2014, 01:14 PM - Thread Starter
zhenya01's Avatar
Surround speaker mounting suggestions.
Hi all, how do you mount large surround speakers without drilling into them?
I want to wall or shelf mount my surround B&W CDM1 speakers. Thanks.
zhenya01 is offline
post #2 of 8 Old 08-16-2014, 07:58 PM
fierce_gt's Avatar
Quoted: 1772 Post(s)
Liked: 1689
you should be able to get wall/ceiling mounts that screw into the same place the floor stands do.
you will obviously need to screw into the walls, but you won't have to modify the speakers in any way.
you could also just install a small shelf, and then place the speaker on the shelf
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is online now
post #3 of 8 Old 08-17-2014, 06:05 AM - Thread Starter
zhenya01's Avatar
I don't mind shelves, I was even thinking about placing these two speakers on top of my blu-ray/CD shelves, just decouple them with blutac or something similar. But this way I won't be able to angle them towards the listening position.
zhenya01 is offline
post #4 of 8 Old 08-17-2014, 07:28 AM
BCRSS's Avatar
Quoted: 295 Post(s)
Liked: 230
I have 6 of these http://www.ebay.com/itm/2-Surround-S...item20eacb3275 and can not complain about them. They are holding my Ascend 170's fine without drilling any holes in them.
All gone for now---->The Elusive 1099 (L/C/R)---6 DIY Volt 10 (surrounds 9.4)---SVS PB 12 Plus---SVS PC 12 Plus---2 DIY 18's sealed--2 Pico Wreckers (tapped horns)---AVR Denon 4311CI---Emotiva Xpa-3---Behringer Nu6000DSP & Nu3000DSP iNuke---TV Vizio 70---110" Motorized Screen---Epson 8350 Projector---Unraid Network Storage---Gateway SX 2370 HTPC with 120 SSD
BCRSS is online now
post #5 of 8 Old 08-17-2014, 07:35 AM - Thread Starter
zhenya01's Avatar
What is holding the speakers in these mounts?
I was looking at similar mounts locally: http://www.electronicsforless.ca/b-t...bt-77-541.html - the ones that you have posted look better (flat plate), but have $65 USD shipping quote to Canada. I am just not sure what will hold the tilted speakers in the long run?
zhenya01 is offline
post #6 of 8 Old 08-17-2014, 07:48 AM
BCRSS's Avatar
Quoted: 295 Post(s)
Liked: 230
The bracket has a small angle on each side and included with the mount are pieces of rubber self sticking tape that you stick on the plate bottom and on the angle. Along with the pressure (can tighten the angle to speaker pretty tight) and rubber hold the speaker in place.
BCRSS is online now
post #7 of 8 Old 09-03-2014, 02:54 PM
Luis5150's Avatar
Quoted: 118 Post(s)
Liked: 115
Scroll down to the bottom pictures of my album here: http://imgur.com/a/ILX76
The DIY shelves+brackets I used to build those can be found at Home Depot. The Paradigm Studio 20's surrounds you see in the pictures are 30-35 lbs each.
| Panasonic TC-P65S2 HD Plasma | Oppo BDP-93 | Paradigm Studio 100's v2 (mains) | Paradigm Studio CC-690 v5 (center) | Paradigm ADP-370 v3 (sides surr.) | Paradigm Studio 20's v2 (sides + back surr.) | SVS PB13-Ultra(x3) | Marantz AV-8801 pre/pro | Emotiva XPA-5 (x2) |
Luis5150 is offline
post #8 of 8 Old 09-15-2014, 08:05 PM - Thread Starter
zhenya01's Avatar
Ended up with this (angled speakers inward a bit more after taking a photo):
zhenya01 is offline
Reply Theater Room Items & Accessories
