wires/cables to buy - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jautor
post #1 of 8 Old 08-22-2014, 11:27 AM - Thread Starter
jrcrunch's Avatar
Quoted: 80 Post(s)
wires/cables to buy
which brand should i buy?
belden? canare? monster? or regular ones?
this is for audio, hdmi and cat5e or cat6 cables or networking.
thanks!!!
--im very novice of this. we will be building our family's first home HT
jrcrunch is offline
post #2 of 8 Old 08-22-2014, 02:55 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 782
Monoprice...
As long as the specs for the cables / wires meet your needs (in-wall ratings, etc.), you're good to go. Belden makes very high quality wire that is priced accordingly - but for our residential needs it isn't necessary in most cases (meaning - Monoprice is good enough).
jrcrunch likes this.
jautor is offline
post #3 of 8 Old 08-22-2014, 07:17 PM
fierce_gt's Avatar
Quoted: 1629 Post(s)
Liked: 1570
second monoprice.
ESPECIALLY for anything digital, there's basically not even a theoretical benefit to the higher priced cables, let along a noticeable real world one.
for speaker wires, I've personally found more benefit associated to the gauge of wire than the quality. I'd rather use a 'cheap' 12awg wire than a brand name 14awg wire. the only exception to this, is some of the cheap stuff is REALLY stiff, so it's hard to run it in tight places.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #4 of 8 Old 08-24-2014, 12:50 AM - Thread Starter
jrcrunch's Avatar
Quoted: 80 Post(s)
how about for long cables? the cables i need are 20-60 feet? for hdmi, cat6 and audio cable thanks
jrcrunch is offline
post #5 of 8 Old 08-24-2014, 08:22 AM
rseven's Avatar
Is this a trick question? Seriously, Monoprice is still the place to get all cables, unless you have a fondness for being ripped off. (I should add they have all kinds of useful connection and charging gear at reasonable prices and no I'm not their shill,just a satisfied customer. That doesn't happen much these days with so much shoddy gear on the market.)
rseven is offline
post #6 of 8 Old 08-24-2014, 04:33 PM
fierce_gt's Avatar
Liked: 1570
no experience with the cat6...sorry(I thought it was pretty standard cable though, don't see too many IT dept's springing for luxury network cable, so there's likely not a big market for it)
for hdmi, get the redmere cables from monoprice. they are good for the long runs, a little more money, but they don't make cheaper 'high speed' hdmi cables longer than 20ft. before they introduced the redmere stuff, I ran a few 30-35ft hdmi cables(the flat CL2 rated ones they still sell) and they definitely show their limitations. everything worked great when I was running everything at 720p, at 1080p they are ok, but unstable, and they don't seem to support 1080p 3D
audio cable, being analog, can be susceptible to some interference. my preference though is to spend a few minutes of care when running the wires instead of a few hundred dollars for the promise(not guarantee) of a better shielded luxury cable.
either way, monoprice sells a range of 'performance'(they're all pretty high quality). so if you need a better cable for longer runs, they will have some good ones, and they will still be cheaper than many other places.
post #7 of 8 Old 08-24-2014, 04:36 PM
fierce_gt's Avatar
Liked: 1570
its true. I even have to deal with ridiculous shipping prices, but monoprice is the first and last place I even bother looking anymore. I KNOW they will be the best product for the money. many times I've heard of other places that are supposed to be better for Canadians, and every time it ends up being cheaper to get from monoprice, and I've never had a dud from them yet.
post #8 of 8 Old 10-01-2014, 12:36 PM
hjnaidu's Avatar
I just outfitted my recently finished theatre (and whole basement I guess) with Monoprice cables. 12AWG speaker wire, redmere HDMI, and digital coax for subs. I couldn't imagine what it would have cost if I'd tried to buy everything at an electronic store.
hjnaidu is offline
Reply Theater Room Items & Accessories
