Projector Mounting Question - AVS Forum | Home Theater Discussions And Reviews
Old 08-27-2014, 09:06 AM - Thread Starter
netr@cer's Avatar
Liked: 0
Installation scenario
I will have double 5/8" sheet rock ceiling with green glue, hung on metal furring channels on sound isolation clips.
Since I haven't completed construction yet, and am months off on getting to the theater part of things I haven't chosen an exact model of projector (I'm expecting tech to change) so I'm not exactly sure where the projector is going to sit.
What is the best way to mount a projector to a soundproofed ceiling?
If I understand the GG, dbl rock, furring design, it is supposed to 'wave' and 'flex' as part of its sound absorption. I would think that waving and flexing NOT good for a projector to be directly fastened to, or is the movement so insignificant that it doesn't matter. I was thinking of using 5/8 plywood and sheet rock in the area the projector might be.
On the other hand, if I put a hole through the ceiling to mount directly to the joists, I've now put a hole into the ceiling for sound to travel.
Ceiling isn't up yet, so I'd like to get some input from folks that have dealt with this issue in their room construction.
netr@cer is offline
Old 08-27-2014, 10:01 PM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
I don't know the 'right' answer, but I'd mount the projector to something sturdy either way. even if not about the flexing, they can be heavy, and I would want it mounted as securely as possible so the image doesn't drift or anything like that too. a small bit of 'opening for sound' is worth it imo.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
Old 08-28-2014, 11:24 AM
Josh Z's Avatar
Quoted: 2143 Post(s)
Liked: 1439
Went through this exact scenario last year. This is what my contractor installed in the ceiling to mount my projector to.
Are you working with The Soundproofing Company? I got the specs and requirements from them.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is online now
Old 09-04-2014, 08:04 AM - Thread Starter
netr@cer's Avatar
Liked: 0
So I see the metal channels on the walls, are you also putting channels on the ceiling? Or will you be screwing the sheetrock directly to the plywood board you have up?
I haven't been working with anyone. Just gleaning knowledge from reading everyone's posts and some guides from various sites (i.e. backer boxes as per the soundcompany guide)
netr@cer is offline
Old 09-04-2014, 08:14 AM
Josh Z's Avatar
Liked: 1439
My room was completed last year. Channels were also installed on the ceiling, but that photo was taken before they were put in.
Josh Z
Old 09-04-2014, 04:59 PM
Quoted: 3259 Post(s)
Liked: 2746
I substitute either a 4 ft wide or full sheet of 5/8 plywood for the first layer in the projector location. Screw it to the channel. That makes drywalling around it easier if it is either 4 or 8 ft long.
Old 09-04-2014, 09:44 PM
Liked: 2746
pic
Old 09-15-2014, 01:16 PM - Thread Starter
netr@cer's Avatar
Liked: 0
BIGMo - I do like the 4x8 board as a solution to mounting mostly because it would afford me greater flexibility in final projector location.
BUT...Big BUT - there is a picture under 'how clips work' tab near the bottom of this page (http://www.soundproofingcompany.com/...solation-clip/) which has me concerned. I fully get that the oscillation wave is greatly exaggerated in the photo and in the real world is fractions of fractions of an inch, but my concern is that even tiny tiny movements may cause discernible movement in the image being generated 14' away. A tenth of a degree of movement of the projector results in over 1/4" of movement 14' away. Even one hundredth (.01) of a degree of movement results in .03" (1/32) bounce at the screen. Can I notice that? I don't know.
I'm worried that room thumping sound will have the screen dancing if I mount it to the ceiling rather than the joists. And as the above numbers are purely theoretical, I'd like to get a sense of practicality from real world rooms that thump out the power of a small rock concert. If you're saying you use the 4x8 in rooms that have ear shattering sound, that's good enough for me. If it's only in modest volume rooms I'd like to understand that too.
And thanks for sharing your experience and knowledge....
netr@cer is offline
Old 09-15-2014, 04:48 PM
Liked: 2746
If you are really concerned or bass addict you can take this to a level 10 solution. Ceiling vibrations moving the projector have been reported but I haven't had that problem yet.
Basically do some blocking between the joists. Secure a chief ceiling mount plate to the joist and blocking, drop the 1 1/2 threaded down pole through the ceiling drywall leaving clearance so it doesn't rub. fill the gap with a flexible caulk. The ceiling can flex all it wants but your projector will be mounted to the joists. This picture is an adjustable down pole but you can just use a fixed length of Home Depot pipe.
Just hope your joists don't bounce when someone walks overhead. Sometimes it is a matter of what is the worst problem.
Old 09-16-2014, 08:58 AM
rboster's Avatar
Quoted: 892 Post(s)
Liked: 744
What about using a neoprene pad between the plywood and joists and/or between the chief ceiling mount and plywood?
http://www.grainger.com/product/5C02...140916145440:s
This might help with vibration control.
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is online now
Old 05-27-2016, 10:21 AM
Quoted: 13 Post(s)
Liked: 1
Would you suggest using clips to isolate the blocking or would you think that is unnecessary?
Sundodger is offline
Old 05-31-2016, 02:37 PM
I built my mount between 2 ceiling joists (2 - 2x8's), and then used plywood layers so that the mounting side of the plywood was level with the soundboard insulation I used. When I put the metal channels on the celing I did not put them across the plywood mount. After the drywall was put up I cut out a rectangle of the drywall so that my projector ceiling moung could be directly bolted to the plywood. After the mount was in place I used baseboard around the hole (and overtop of the mounting lag bolts) to clean it up.
My wife and I did a sound test after drywalling the ceiling and after cutting the mounting hole and we couldn't hear any noticable change in sound transmission to the room about our theater.
I do notice that if someone is walking in our kitchen above, we do get some vibration of the projector. It's not enough for me to worry about at this time, but a few fixes I think I've found range from using a more solid projector mount to building little supports that replace the feet on the projector and push against the ceiling drywall to stop the vibrations. I know that my vibrations are due to the projector mount vibrating, so I'm pretty sure in the future I'll probably buy a more solid mount, but for now I can live with what I have.
jgmac98 is offline
