Look what Black Friday got me! - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #1 of 122 Old 11-30-2014, 04:42 PM - Thread Starter
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
On Friday we went to BB to get a few items. I first had a brand new 40 inch insignia for my poster frame. I put it back as I did not want to spend $180. So we go over to the iPads and they had the iPad minis miss labeled for $224. So we snagged that before they changed the price.
The whole day I was second guessing not getting that tv. So we ventured to a few BB but all out.
Saturday morning I start checking BB online and all out, oh well. Then decided to look for open box and a location by me had one. So off to BB before opening. After finding it in the back I picked it up and tested it in store. Two other customers wanted to know if I was taking it, I said yes. It was marked $161 but missing stand screws. So I asked a manager and said they would give it to me for $139, sweet! I'm not using the stand anyways.
So got wood today and did most of my build. So here it is. It's going to be hung with French cleats. So it can be lifted right off the wall. I still have to fill brad nail holes, corners, and paint. Total cost is $175. What do you think?
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is online now
post #2 of 122 Old 11-30-2014, 06:50 PM
Angus.Young's Avatar
Very nice..
Looks great.
How are you putting posters onto it.. just USB media?
Angus.Young is offline
post #3 of 122 Old 11-30-2014, 08:10 PM - Thread Starter
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
Originally Posted by Angus.Young View Post
Very nice..
Looks great.
Yep, just usb stick for now. Just design some headers and footers in Photoshop.
post #4 of 122 Old 12-04-2014, 06:49 AM
Liked: 5
okay that's pretty cool.
lotus1 is offline
post #5 of 122 Old 12-04-2014, 09:51 AM - Thread Starter
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
All painted and hung on wall.
Squirrel! and Delta1142 like this.
post #6 of 122 Old 12-04-2014, 09:58 AM
cesar123's Avatar
Quoted: 376 Post(s)
Liked: 557
Very nice!
Yippee-ki-yay...
cesar123 is online now
post #7 of 122 Old 12-07-2014, 08:16 PM
realcodeguy's Avatar
Quoted: 27 Post(s)
This is a great idea, love it!
realcodeguy is offline
post #8 of 122 Old 12-08-2014, 05:54 AM
Tedd's Avatar
Quoted: 1154 Post(s)
Liked: 441
The framing as the mount, is an awesome idea. Very nicely done.
So where are you getting your digital movie posters? I've used the pay
sites, but lately have been collecting from:
http://www.impawards.com/
You might want to add some top and bottom cooling vents to the frame,
or shim out the frame from the wall slightly.
Are you simply scaling to fit?
Tedd is offline
post #9 of 122 Old 12-08-2014, 09:58 AM - Thread Starter
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
Thanks guys.
For movie posters I'm just searching the net but thanks for that link, it will help.
I have only used a few posters to get the idea. Now I need to download a bunch. As for scaling I'm using photoshop to make my own headers and footers. I might use them or just have the posters with top and bottom black bars, or design coming soon.
The frame sits about 1/4 inch all the way around off the wall. I might put in a 80mm fan at top with holes on bottom. I don't leave it on right now for hours so fine for now.
I designed the frame and TV to be one so its easy to take off the wall to get to the USB stick. I might add an extention usb later on. I originally was going to use 2 French cleats as shown but ended up only using one. I also used foam tape between the TV and frame so no rattles.
post #10 of 122 Old 12-08-2014, 10:13 AM
Tedd's Avatar
Liked: 441
I would think the frame sitting a 1/4" off the wall should handle ventilation.
I was also thinking a usb extension cable would be a nice improvement.
So you don't Photoshop your digital posters to a 1280x1920 native resolution then?
I was leaning that way.
There's also a pay website that is very extensive and has much larger resolutions.
Tedd is offline
post #11 of 122 Old 12-08-2014, 11:19 AM - Thread Starter
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
I just resize the image with a width of 1080 and keep original aspect. So that makes it the correct width and the top or bottom can fall within a few pixels., still has black bar at top and bottom. If you take the image and make it native resolution the poster would be stretched top and bottom.
post #12 of 122 Old 12-08-2014, 11:29 AM
Tedd's Avatar
Liked: 441
I wrote down 1280, but should have wrote 1080x1920.
Gotcha. I understand how you are doing your posters.
I was thinking more along the lines of doing a near resizing, and then cut to
1080x1920, if the poster doesn't have details that extend out to the edges.
Tedd is offline
post #13 of 122 Old 12-08-2014, 12:40 PM
Tedd's Avatar
Liked: 441
Stretched to 1920 tall first, and then cut to 1080.
Name:	Frankinweenie 1080x1920.jpg
Tedd is offline
post #14 of 122 Old 12-08-2014, 02:49 PM
Tedd's Avatar
Liked: 441
and down-rezzed to 675x1200 by AVS.......
DexDeadly likes this.
Tedd is offline
post #15 of 122 Old 12-09-2014, 04:42 AM
InfiniteReality's Avatar
Nice, I dig the idea of keeping the TV enclosure inside the frame. Nice and simple and looks awesome!
Optoma HD141X Projector With 110” Elite Screen
Yamaha RX-V775WA A/V Receiver
4 Polk Audio TL250 Surround Speakers
2 Polk Audio RC85i In-Wall Speakers
1 Polk Audio TL2 Center & PSW505 Subwoofer
Berkline 12003 Leather/Power, Straight Row Of 3
InfiniteReality is offline
post #16 of 122 Old 12-09-2014, 05:13 AM - Thread Starter
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
So it's cutting off some left and right, right?
post #17 of 122 Old 12-09-2014, 02:25 PM
Tedd's Avatar
Liked: 441
That one, yes....
These pair were simple cut and paste into a 1080x1920 image. (Low hanging fruit...)
A few I have played with, might just work scaled slightly oversized, and
a 1080x1920 cut works.
And some are so loaded with print or detail to the edges, that an added
header saying something like "Now Showing", or "Coming Soon" is a simple
way to achieve a 1080x1920.
And maybe some
ID:	411649   Click image for larger version
Name:	Last Call 1080x1920.jpg
Tedd is offline
post #18 of 122 Old 12-10-2014, 05:40 AM
Tedd's Avatar
Liked: 441
Ever seen Mcascio's digital poster movie where MainLobby fills out the 1080x1920 resolution with information?
The Cinemar Home Theater Construction Thread
Which makes me wonder if maybe subdividing that hdtv panel into two frames, might return the original poster aspect, and allow
for simple editing to flush out a 1080x1920 frame with additional information, such as "Coming Soon", " Coming Attraction", etc, to fill out the panel's use?
Tedd is offline
post #19 of 122 Old 12-10-2014, 06:22 AM - Thread Starter
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
In my original post you can see the header and footer I made in PS to use the black space. I did that for a quick test. I still need to make some coming soon and now showing stuff.
I believe his is running off a pc with the poster program. I wanted mine for now simple off the usb stick.
post #20 of 122 Old 12-10-2014, 06:41 AM
Tedd's Avatar
Liked: 441
We're on the same page then, but I was thinking more along the lines of a physical separation
on the poster frame, and mimic the older style movie poster light boxes at the theaters.
(Might be an "age gap" thing... growing up with more traditional style theaters, then todays media
complexes.)
Name:	now showing.jpg
Tedd is offline
post #21 of 122 Old 12-10-2014, 10:39 AM - Thread Starter
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
complexes.)
That's a good idea too. I can make a PS file with the border. Then I can insert the poster and whatever text I want.
I hope in the next few days I will be able to play with PS. Just to busy recently.
post #22 of 122 Old 12-10-2014, 12:59 PM
meyer64's Avatar
Quoted: 299 Post(s)
Liked: 252
The installation looks great! If your interested, I actually wrote some software specifically for this type of installation. It would require a PC to be connected to the display, but the software can automatically download posters and metadata (ratings, rottentomatoes scores, etc) as well as show trailers overlayed on the poster. All with very little user interaction. You can try it out for free. See the links in my signature for more info.
Loudominos and Andy Tedd like this.
meyer64 is offline
post #23 of 122 Old 12-10-2014, 01:28 PM
Tedd's Avatar
Liked: 441
I've been playing around with a bunch of digital posters I have, and I can see
myself settling on 1080x1600 and then adding a 1080x320 header (to the bottom
for myself).
Those that don't scale to 1080x1600 (but most seem to), I have been scaling to a wee
bit little wider then 1080, and then use a cut and paste to 1080x1600.
Here's the Terminator Genisys 2015 digital poster that was 1753x2544 (second attachment) and got the above
treatment to end up at 1080x1600 (first attachment). I gave up a few pixels per side, and a few off the bottom.
With the usual AVS down rez I expect.
Name:	Terminator Coming Soon 1080x1600.jpg
ID:	413689   Click image for larger version
Name:	terminator 1753x2544.jpg
Tedd is offline
post #24 of 122 Old 12-10-2014, 02:46 PM
Tedd's Avatar
Liked: 441
bluer101, does this animated poster work via usb?
Tedd is offline
post #25 of 122 Old 12-10-2014, 05:13 PM - Thread Starter
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
I tried the program before I bought the tv. For some reason it was making my laptop run at 100% and freeze. After I closed the program through task manager I cannot get the exe to run again.
I tried it again and as soon as it pops up with regristation it says it has to close as the program has encountered a problem.
post #26 of 122 Old 12-25-2014, 08:25 AM
Tedd's Avatar
Liked: 441
A thread bump, if nothing else.
I've been messing around with around a hundred digital movie and tv show posters, and
the majority and be resized straight up to 1080x1600, or given a resize and small digital trim,
to hit 1080x1600. Then I've been cutting and pasting these to 1080x1920 panels, with a header
blurb.
I was thinking a wider framing of a rotated hdtv could lead me to a more theatrical light box
look, and eliminate the tall/wide look, while still leveraging the simplicity of your idea.
And if animated gifs work in this manner, I could see doing some scrolling headers.
Name:	Penguins with header1080x1920 - shrunk.jpg
ID:	440698   Click image for larger version
Tedd is offline
post #27 of 122 Old 02-02-2015, 08:18 PM
Th0r4z1n3's Avatar
Liked: 7
Digging the setup. I just recently started on a similar project. On thing I ran into with my Vizios is that the firmware on the TVs would only recognize a maximum of 217 posters, and in preparation I had accumulated quite a few more than that. Also wasn't too keen on the max display time built into the TVs. I ended up getting a couple Raspberry Pi units, and programming them to run full screen slideshows. This allowed me to have full access to all of my posters, and set the display time of the posters to what I wanted (2 minutes each).
Here's my display so far (not trying to be spammy).
Th0r4z1n3 is offline
post #28 of 122 Old 02-03-2015, 11:57 AM - Thread Starter
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
Never thought about the raspberry pi units. I have no experience with them so I'm going to look it up.
post #29 of 122 Old 03-17-2015, 03:52 PM
Tedd's Avatar
Liked: 441
So how are people setting up their poster database for a usb drive?
I have no idea if there's a limit on files for my hdtv, but I already have 1,100 plus posters to
organize and was wondering what others are doing?
Tedd is offline
post #30 of 122 Old 03-17-2015, 06:05 PM - Thread Starter
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
I have not done anything more as I have been busy. Look up your tv manual to see the max limit for pictures. I just put all my posters on the flash drive and set the usb to slideshow random.
Reply Theater Room Items & Accessories
