Palliser battery packs? - AVS | Home Theater Discussions And Reviews
post #1 of 9 Old 01-02-2015, 08:50 AM - Thread Starter
dgolombowski's Avatar
I purchased a set of four Palliser home theater chairs with the battery packs. My chairs are located in the center of my theater and I have no outlet nearby so having the battery pack was key point in our decision to purchase this set. Well now we are finding the batteries go dead about every five days whether we use the chairs or not. We purchased the chairs at ABT (good people) and they are being told by Palliser that the batteries are fine and they go dead from the LED lights in the switches on the cupholders. I question that response since LEDs have a very low draw. But it is ridiculous that after a dozen cycles and only a few days I have to run the cord to an outlet to charge the battery packs.
I know I have read a few posts here where others have bought chairs with the battery packs. I was wondering what the experience of others have been with the length of the battery charge?
You know, a guy could get into this HT thing and drop a couple of bucks!
dgolombowski is offline
post #2 of 9 Old 01-02-2015, 09:16 AM
airscapes's Avatar
Quoted: 150 Post(s)
Liked: 159
No expert here but I would think the Battery pack is like an UPS to let you get out of the chair when power fails.
One option but not all that great would be to buy a UPS to set behind the chairs and plug them in, then turn off the ups. When the packs die turn on the UPS to charge them. This of course would be a reasonable sized UPS with a capacity of 1000va (about $150) Of course you would need to plug it in every once in a while to charge it's battery.
Doug
Planar PD8150 paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 9 Old 01-02-2015, 09:38 AM - Thread Starter
No that is not the case. These battery packs are designed to allow you to operate the seating units without having to run a cord to the wall.
http://www.htseating.com/palliser-po...tery-pack.html
They have a nominal capacity of 2300 mAH and they claim 80% capacity after 300 cycles. And I would be happy with that.
Using UPS system to back them up would really do nothing more than the present setup. The seats each have a charger and a battery pack underneath them. I have the four chargers running off of a surge protector strip under one of the seats. The charger is wired to the battery and the battery is wired to the seat.
post #4 of 9 Old 01-02-2015, 11:34 AM
HTmarket's Avatar
Quoted: 54 Post(s)
Liked: 3
The problem is the LED lights as they are backlit and draws all the power of the packs, if you did not have the led cupholders you would get the cycles they suggest, I have done tests with rafel battery packs and it's same problem it dies in 2 to 3 days if you have led cupholders that have back lighting, we don't recommend them if you have led cupholders for this reason.
regards
Alan Hutchinson
HTmarket.com
HTmarket is offline
post #5 of 9 Old 01-02-2015, 01:44 PM - Thread Starter
regards
Alan Hutchinson
HTmarket.com
I wish I had known this before I made my purchase. Although I guess it was inevetible that I would need to pull up the carpet one day and run power to the center of the room.
post #6 of 9 Old 01-06-2015, 11:04 AM
hv9200's Avatar
Quoted: 30 Post(s)
I am having same issue, I am thinking of using a larger battery and using a power inverter. something like a deep cycle ATV battery would fit under my riser but not sure how much longer a battery like that would last over the existing setup.
"although he walks among us, he is not one of us"
hv9200 is offline
post #7 of 9 Old 01-06-2015, 02:34 PM - Thread Starter
I don't know if that would work but I do know the company that manufacturers the batteries; Limoss does have higher capacity batteries available.
http://limoss-us.com/product/mc-240/
post #8 of 9 Old 01-06-2015, 03:42 PM
blazar's Avatar
Quoted: 494 Post(s)
Liked: 414
Led cupholders look weak... Not sure why folks buy those in the first place.
blazar is online now
post #9 of 9 Old 01-07-2015, 06:54 AM
Quoted: 977 Post(s)
Liked: 952
BIGmouthinDC is online now
Reply Theater Room Items & Accessories
