Looking for Recommendations on Wall-Mountable A/V Cabinet - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Newbie789
post #1 of 5 Old 09-06-2017, 03:08 PM - Thread Starter
Artemido's Avatar
I was looking at the Sanus Foundations JFV60 A/V Cabinet, but, of course, it has decided to become universally unavailable. As such, I would be interested in something similar (similar form factor, glass doors, wall-mountable) in about the same price range ($300-$400ish), but I welcome input on things that I haven't even considered. Basically, what I want to do is have a place to store my XBOX and FIOS receiver mounted on the way **above** my TV. Thanks in advance.
[jR]
Artemido is offline
post #2 of 5 Old 09-06-2017, 05:34 PM
bpassman's Avatar
Quoted: 125 Post(s)
Liked: 55
Have you looked at the Ikea Besta product line? They offer a way of wall mounting their frames and their inexpensive.
Frames
http://www.ikea.com/us/en/catalog/ca...ng_room/12151/
Wall mount rail
http://www.ikea.com/us/en/catalog/products/30284846/
In the opposite cost direction, Salamander Designs make some great cabinets that can be wall mounted.
http://www.salamanderdesigns.com/pro...cabinets-miami
Brad
AVR Anthen AVM 60 Amp Emotiva XPA-7 & XPA-5 Sources Oppo 203, FireTV, FiOS
Speakers Atmos 7.2.4 - TruAudio B23-465s (LCRs), TruAudio B23-265s (SL/R & SB), Dual SVS PC-2000s (Subs), 4 In Ceilings
PJ JVC RS500 Screen 153" DIY 2.35:1 Spandex
My crazy long build Coffered Ceiling
bpassman is online now
post #3 of 5 Old 09-07-2017, 06:58 PM
Newbie789's Avatar
Quoted: 332 Post(s)
Liked: 93
This is a wall mount shelf from peerless that is about $40
Peerless Adjustable Component Shelf for AV EQ https://www.amazon.com/dp/B00155PSXS..._kKySX9sZ4cI9G
bpassman likes this.
Newbie789 is offline
post #4 of 5 Old 09-19-2017, 04:35 PM
rbouch8828's Avatar
Middle Atlantic has a series of options for in-wall mounting, with slide out and rotate:
HTML Code:
https://www.middleatlantic.com/products/racks-enclosures/slide-out-racks.aspx
rbouch8828 is offline
post #5 of 5 Old 09-30-2017, 10:39 AM - Thread Starter
Artemido's Avatar
Ended up going with the Besta TV stand and flipping it upside down to hide the predrilled nut holes for the adjustable feet. I think it looks okay.
Artemido is offline
Reply Theater Room Items & Accessories
