AV rack - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-21-2017, 07:33 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 6
AV rack
I have a recessed area where wiring comes out for the home heater I am making. I am looking for an AV rack that can go in there. I want one that can slide out to allow easy access to wiring. Also, prefer one that has an open area up top (not closeD) as I have a fan installed up there. I will be putting a receiver, some type of kodi device, ps4, eventually want to make a computer that can lay horizontal to put in there.
The area is 20.5W x 46L x 22.5 depth
attached is a picture of the recessed area
DrUNC83 is offline
post #2 of 8 Old 09-22-2017, 08:21 AM
oldavman's Avatar
Quoted: 12 Post(s)
Check these two racks from Middle Atlantic: Model SRS2-19 slide out rail rack or the Model ASR-42 slide out rotating rack.
oldavman is offline
post #3 of 8 Old 09-22-2017, 08:35 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 6
The ASR-42 is something like what I am looking for but wow is it expensive. I am not sure I can justify paying $1800.
DrUNC83 is offline
post #4 of 8 Old 09-22-2017, 11:14 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 6
Anyone tried DIY? These racks are so expensive. Think Home Depot or Lowes have stuff to make myself?
DrUNC83 is offline
post #5 of 8 Old 09-24-2017, 06:40 AM
Quoted: 75 Post(s)
Liked: 41
I made my own rack. I basically built a box, and attached rack rails to the sides. Then finished it off with door casing. I ended up using a rack mounted fan instead of the fan you see on the box.
You can also see that I built a small door on the back to access the wiring, but all the equipment slides in from the front.
For the actual rack rails. I attached these to the sides of the box Reliable Hardware Company RH-20-SRR-A 20U Full Hole 20 Space Rack Rail Pair https://www.amazon.com/dp/B00JJ18OVS..._gy7XzbBZGZDH8
ID:	2287620   Click image for larger version
ID:	2287622   Click image for larger version
weboperations is offline
post #6 of 8 Old 09-24-2017, 04:02 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 6
Your pics didn't work. Does it slide? Mine must be able to slide out if you saw the above pictures. How much time and cost was this?
DrUNC83 is offline
post #7 of 8 Old 09-26-2017, 07:42 PM
Tedd's Avatar
Quoted: 1146 Post(s)
Liked: 437
Ebay.
Tedd is offline
post #8 of 8 Old 10-14-2017, 05:00 PM
DaveN's Avatar
Quoted: 134 Post(s)
Liked: 43
Check elvessupply. There is a thread about re42 rack 750 shipped. May still be available
DaveN is offline
Reply Theater Room Items & Accessories
