Color-changing LED strips with WIFI: Philips Hue alternatives? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-27-2017, 12:12 PM - Thread Starter
ThoughtCriminal's Avatar
Question Color-changing LED strips with WIFI: Philips Hue alternatives?
My new home theater is currently under construction and I am investigating options for lighting.
The Sci-Fi-referenced design is going to incorporate wall panels that will be backlit, ideally with color-changing led strips.
I own multiple Philips Hue products which I am very pleased with. However, given the amount of lights I am going to need, I'm looking for a less costly alternative. Moreover, Philips light strip doesn't seem to be designed as a construction product for lighting extensive areas.
Anyway, does anyone know of any led strips that also work via wifi/smartphone app? The products I've seen all come with a little wonky remote and I'm not certainly multiple strips can be controlled in tandem.
Thanks for your thoughts!
ThoughtCriminal is offline
Reply Theater Room Items & Accessories
led lights
