Need a wall mount suggestion for this LR arrangement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-04-2017, 01:38 PM - Thread Starter
puffinmylye's Avatar
Quoted: 20 Post(s)
I'm looking for some brand/model suggestions for a quality wall mount to be used in the following living room. This is 100% the way the living room is configured and that is not changing so please refrain from any reconfiguration suggestions.
The wall to the right is solid concrete so I'd rather avoid putting any mounts there. The wall below the TV in the pic has a big board of plywood installed between the studs to make mounting easier.
puffinmylye is offline
post #2 of 2 Old 10-04-2017, 07:41 PM
Liked: 7
Any type of full motion mount will work. I would look for something with a pretty good extension, which will allow better placement in a corner.
https://www.bestbuy.com/site/sanus-p...?skuId=5463305
Above is just an example.
49erfaninkansas is offline
Reply Theater Room Items & Accessories
