Bass Shakers - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #631 of 1170 Old 04-24-2005, 06:26 PM
dennisgg's Avatar
Hi,
I just installed 3 today (old Realistic Prologic receiver) on 3 of my Jaymar seats. I am still playing with them, but they are definitely cool (even my wife said so!).
Dennis
dennisgg is offline
post #632 of 1170 Old 04-26-2005, 01:59 PM
margomaps's Avatar
I've found that a 125 watt channel (8 ohm) split between 2 Aura Pro's wired in series...is a bit too much. Watching the prologue of LOTR:FOTR, with the level set to nearly 100%, the effect of the shakers was just too much. I'm talking severely blurred vision, dizziness, disorientation, and general malaise. At a level somewhere between 1/2-3/4, the effect was more subdued, and more pleasant.
Also, I'm now using 2 Clark 239's in one row of seating, and I highly recommend them. At $100, they're an absolute steal IMO. Yes, they require a bit more juice than the Aura Pro's, but the frequency range and overall effect is much more pleasing than the Aura's IMO. I'm not badmouthing the Aura's by any means -- I still use them in 4 of my seats. I'm just saying that the Clarks are really a whole lot better.
margomaps is offline
post #633 of 1170 Old 04-26-2005, 03:12 PM
dhanson's Avatar
Are you running the Clarks full-range? How about the Auras?
The thing I miss about the Auras so far is that, being driven from the subwoofer LFE output they don't work at all with many sources. And some sountracks are great ("Master and Commander" was fantastic!), but others don't have much LFE info at all.
dhanson is offline
post #634 of 1170 Old 04-26-2005, 09:00 PM
margomaps's Avatar
I'm running both the Clarks and Aura's full-range. It's not my first choice -- I was dreading the infamous "voice-in-butt" effect -- but the sub pre-out on my AVR is busted, so I have to use the L/R pre-out instead. And I don't have an EQ. So far the voice-in-butt effect hasn't bothered me.
The Aura's do fine, especially on soundtracks with nice, meaty LFE. It's just that by comparison, the Clarks do much better than fine, in all respects. If I'm watching a movie or listening to music with a walking bass line (especially acoustic), the sound and feeling is just sublimely musical.
I would advise anyone who is thinking about buying a pair of Aura Pros to consider getting a single Clark 239 instead.
post #635 of 1170 Old 04-26-2005, 10:47 PM
Clarence's Avatar
Quoted: 282 Post(s)
Liked: 9689
I've already got aura pro's for my berk 90's and small auras for my 2nd row, but I might have to try a Clark for a comparison.
Is this the one you have?
http://www.smarthome.com/8248x2.html
Clarence is online now
post #636 of 1170 Old 04-27-2005, 02:19 AM
MATA7's Avatar
Quoted: 13 Post(s)
can i use the Bass Shakers wiht my pioneer 1015 wiht out buy a extra amp?
i have A JBL E250P 12 can i connect the Bass Shakers on this connection?
thanks
English Is Not My First Language
My HD-DVD/BD Collection
MATA7 is offline
post #637 of 1170 Old 04-27-2005, 05:12 AM
David_Larkins's Avatar
MATA7,
1) probably not, but not enough info to answer.
2) as for the diagram, No - that appears to be a speaker level input for a subwoofer. This is what you would use to run straight from a receiver's speaker outputs to a sub. It's an input and therefore would not provide power output to your shakers. At least that's the way it looks to me.
David
David_Larkins is offline
post #638 of 1170 Old 04-27-2005, 05:30 AM
MATA7's Avatar
Quoted: 13 Post(s)
Originally posted by David_Larkins
MATA7,
thanks, what info do you need?
MATA7 is offline
post #639 of 1170 Old 04-27-2005, 08:17 PM
kmc123's Avatar
I have 8 of the Aura Bass Shaker Pro's in my theater, and I LOVE them! I currently have one mounted to each chair, and am buying 8 more soon for a total of 16 (2 per chair). They are GREAT!
I have pictures posted at:
http://gallery.avsforum.com/showgall...ppuser=7478983
If you want to see how I mounted them, etc...
kmc123 is offline
post #640 of 1170 Old 04-28-2005, 07:29 AM
High Def 03's Avatar
ok i am thinking of getting these shakers and i have an extra receiver i can use.What else do i need? Do i need an amp?
High Def 03 is offline
post #641 of 1170 Old 04-28-2005, 08:31 AM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
No, the receiver is an amp. Looks like the only thing you'll need is wiring and mounting material.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #642 of 1170 Old 04-28-2005, 08:36 AM
MATA7,
I needed more info on your receiver. I found it on the web, and the answer is no.
The only way I can think of that you could have done it would have been if your receiver had extra channels of amplification that you weren't using, as well as "main in" or "amp in" connectors - if you had that you could have fed the main in on the channels you weren't using with the sub pre-out. Only a few receivers have main in's, and yours does not.
David
post #643 of 1170 Old 04-28-2005, 08:40 AM
MATA7's Avatar
Quoted: 13 Post(s)
well thanks David
MATA7 is offline
post #644 of 1170 Old 04-28-2005, 09:13 AM
Are the Buttkickers better than the Aura Pro's?
post #645 of 1170 Old 04-28-2005, 09:18 AM
shepP's Avatar
Quoted: 39 Post(s)
Buttkickers are a whole new level IMO.
shepP is offline
post #646 of 1170 Old 04-28-2005, 09:28 AM
So i guess that means there better but more expensive
post #647 of 1170 Old 04-28-2005, 10:58 AM
MATA7's Avatar
Quoted: 13 Post(s)
If i get 2 Buttkickers plus Buttkickers amp, do i still need a sub?
MATA7 is offline
post #648 of 1170 Old 04-28-2005, 12:03 PM
Elfman's Avatar
Butkickers are also a lot more expensive too but yes, they are probably quite a few steps above the Aura's.
MATA7
The Aura's and Butkickers operate on a similar principle. To put it plainly, they behave similarly to sitting on top of your subwoofer. They vibrate like a sub would but they do not produce the LFE frequencies in sound. If you remove the subwoofer element from your theater and keep the shakers, you will feel the bass but you will not hear that bass. So for the complete experience, I would imagine all of us run shakers along side our subwoofers. I currently run 2 subwoofers and 4 shakers.
Elfman is offline
post #649 of 1170 Old 04-28-2005, 01:49 PM
MATA7's Avatar
Quoted: 13 Post(s)
what about this, i have the pioneer 1015, can i do this?
now i have a 7.1 setup system, but if i setup a 5.1 can i use the 2 SB output, to give sound to the Aura's.?
MATA7 is offline
post #650 of 1170 Old 04-28-2005, 05:53 PM
margomaps's Avatar
My ears are very sensitive, and if I watch a bass-heavy movie (even with the subwoofer at a reasonably calibrated level), I experience a lot of discomfort during and after the movie. I find that turning the sub down a bit, and supplementing the bass with shakers, makes movies much more enjoyable for me. Gotta protect the hearing, man!
As far as Buttkickers are concerned, I'm sure they're head & shoulders above the Aura's in terms of both performance and price. I've found a happy medium with the Clark transducers, but I don't doubt that if I paid more for the Buttkickers, there'd be more shaking going on.
post #651 of 1170 Old 04-29-2005, 09:15 AM
Cowher36's Avatar
Looking to get some Buttkickers. I have four seats. Do I need one for each seat? Also where is a good place to get these?
Cowher36 is offline
post #652 of 1170 Old 04-29-2005, 12:16 PM
HiHoStevo's Avatar
Question.........
A friend who is a professional HT installer, claims that most of his customers disconnect their Buttkickers after a couple of months or less.
He says they are a great WOW factor for having friends over, but most do not to live with them on an every day basis......
Have you guys found that to be the case???
How long have you had yours installed?
Do you have them turned on all the time, or just for certain movies/events?
thanks
There are just two theories for successfully quarreling with a woman -- neither one works!
The Barn - Use Password = AVSForum
HiHoStevo is offline
post #653 of 1170 Old 04-29-2005, 12:53 PM
Elfman's Avatar
Originally posted by HiHoStevo
Question.........
thanks
Sounds to me that these peoeple(the owners, not your friend) aren't calibrating them properly. Buttkickers are VERY powerful (require 1000 watts to drive them if I'm not mistaken) and can easily be a distraction to someone if they are not set to proper levels. I have heard that they can shake so much that it makes the vision blurry. Talk about a distraction!
I only use my Auras(much less powerful) for movies and sometimes some Xbox. I have had them for about 5 months now and I wouldn't watch a movie without them. I hardly ever use them for regular TV watching.
Elfman is offline
post #654 of 1170 Old 04-29-2005, 02:26 PM
HCDMN's Avatar
It can be a little overwhelming for some people. And I agree with Elfman that they just need to adjust the output level on the shaker amp. Which can need adjusting per movie. What has worked in the past is having a shaker amp that has an infrared volume control so you can adjust it sitting in your seat. I have also connected several shakers with a speaker switcher box that will enable you to shut off a particular seat if desired. I am also experimenting with volume controls at the seat so each individual can adjust their chair to their liking. They also make a speaker switcher box that has volume controls built in so each seat can be adjusted individually, but that means getting up and adjusting it. Not convenient.
But, they just need to adjust to what you like. They add so much to a movie.
HCDMN is offline
post #655 of 1170 Old 04-29-2005, 07:04 PM
You could do that IF you could somehow feed the SB channels with JUST signal from the LFE or sub out - but you don't have a way to do that.
Sure you can hook up shakers instead of speakers to the SB channels on your amp... but the only action you're gonna get out of them is the low bass that comes from that track on a movie - which would be very very little.
David
post #656 of 1170 Old 05-01-2005, 05:19 PM
ShinyPrincess's Avatar
I would like to get these shakers. The second receiver I have to use for this is a Kenwood VR-606 Home Theater receiver which has DTS, Dolby Digital, etc. My concern is whether this would work with the shakers because I don't believe it has stereo/mono mode. Its a decent home theater receiver, and I know most people are buying cheap receivers to use with the shakers. Is this too good of a receiver to be used? This is the only "spare" receiver I have to use for the shakers.
ShinyPrincess is offline
post #657 of 1170 Old 05-01-2005, 05:46 PM
Hi also can someone tell me where i can get a splitter for the shakers. Whats the name of the spliiter? Thanks for your help!
post #658 of 1170 Old 05-01-2005, 07:26 PM
Elfman's Avatar
Check this post. There is an image along with a place where the can be found on-line. Radio Shack should also have something like this as well. They would simply be called an RCA 1 to 2 'Y' splitter. Jut make sure you get the right connectors on the ends which is usually 1 male RCA end to 2 female RCA ends.
Elfman is offline
post #659 of 1170 Old 05-03-2005, 09:15 AM
Can someone tell me the diffrence between the Ausa Bass shaker and the Aura pro Bass shaker?
post #660 of 1170 Old 05-03-2005, 09:49 AM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 83
chinadog is offline
Reply Theater Room Items & Accessories
