Bass Shakers - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #721 of 1170 Old 07-12-2005, 07:16 AM
SR Immortal's Avatar
I bought that same amp, but then I decided to send it back, because it was just much easier to use an old pro logic receiver, rather than that amp. And it just so happened that I did have an old PLI receiver laying around. Not that I remembered about it when I was purchasing the shakers, but after I got the amp I remembered. And even if you dont have one lying around, it would be cheaper to get a cheap receiver with remote on ebay than buying that amp with remote...
SR Immortal is offline
post #722 of 1170 Old 07-12-2005, 08:31 AM
Patrick TX's Avatar
Thanks for the reply Brickie! If I DID do 12 Shakers, would the 250X2 @ 8ohms be enough juice?
"I promise I'll never die." - Gary Johnston
Patrick TX is offline
post #723 of 1170 Old 07-12-2005, 01:51 PM
NaTeDoGG's Avatar
Quoted: 55 Post(s)
Planning on getting the wife to give my 4 shakers and an amp for my birthday at the end of this month. Can you guys review my installation below and give any feedback you might have?
Removed some 200 or so staples to get the bottom fabric off my couch. Here is a pic, the red box is where I am thinking of putting a 66.5" x 8" x 0.75" board. The red circles are where the bass shakers would go, on top of the board, towards the seat cushions. There is enough room to clear the springs.
The back of the couch is at the bottom of the pic. I chose the location in red above because I can screw the board into the frame not only to the boards in the middle, but to the 2x4 at the back of the couch. I think this will provide shaking not only to the seat cushions, but to the seat back and entire frame as well.
In the picture, the springs are touching pretty much all the boards you can see. I hope the shaking is not too much because of this.
I've heard that shaking the arms and back may reduce the sensation that the floor/room is shaking. Do you think I should avoid shaking the seat back? What would you say is the best placement for this couch?
Do you think a 3/4" board is too thick or not thick enough? What type of board should I ask for?
I am doing a big chair in addition to the couch above. The big chair is the same design, except it doesn't have room to clear the springs. I have 3-1/8" from the spring to the floor. The shaker is 2-1/8". If I mount it on a 3/4" board, I'll have a 1/4" to spare between the top of the shaker and the spring. I'll have to build a sort of tray to mount the shaker in this way. Here is a drawing of the pieces I will need to do my install...
I can get a pic of the chair later tonight.
I want to be completely ready to do the install on my birthday. What sort of connectors will I need for the shakers? Can you give me the exact size?
Also, I am undecided on what receiver to drive the 4 Pro shakers. I've read this entire thread and I think this receiver that was mentioned might work best...
http://www.partsexpress.com/pe/showd...number=248-515
I don't want to go with a plate amp as it has to go in the rack. I'd like to buy from PartsExpress since all the other parts are coming from there. Do you guys have any other recommendations?
NaTeDoGG is offline
post #724 of 1170 Old 07-15-2005, 02:55 PM
NaTeDoGG's Avatar
Quoted: 55 Post(s)
I took my placement issues to a different thread...
http://www.avsforum.com/avs-vb/showthread.php?t=558294
NaTeDoGG is offline
post #725 of 1170 Old 07-17-2005, 08:57 PM
kwill's Avatar
Nice thread guys.
I can never leave good enough alone. I just went from a 12 inch DIY Adire DPL to 2 15inch Titanic MKIII subs in a 15 by 25 foot room. Do you think shakers would dramatically improve my movie watching experience? I feel as if there is enough bass for movies, but it seems these offer a different effect?
kwill is offline
post #726 of 1170 Old 07-17-2005, 10:07 PM
brickie's Avatar
Quoted: 24 Post(s)
Liked: 26
Kwill, how do you like those Titanic subs?I agree they do offer up something a little different..although really good subs can give you that shake you in your butt feel as well.To me, I like to be able to feel the bass pressurize the room or load it up..A good sub needs to do this since shakers won't...Rgeb I like to have the shakers go ahead and take it right on over the top where you just really feel the shake all around you..
brickie
AM I THE ONLY OASIS IN THE DESERT OF STUPIDITY......" SIR BRICKENBOCKER"
brickie is offline
post #727 of 1170 Old 07-18-2005, 01:42 PM
kwill's Avatar
Brickie,
When I first hooked up the Titanics, I was a little disappointed. They did not sound as good as my previous sub. However, after some break in time, and phase/ placement adjustments, the sound improved greatly. This is plenty of bass for me- (I have the LFE level down almost all the way on my AVR.) I would recommend the Titanics to anyone looking for a (relatively) cheap and high quality sub.
I certainly can feel the room "pressurize", especially during certain movies- the Hulk comes to mind. But I dont feel any vibration in my seating area (a plush type couch). Thats why I am considering the shakers for that last little bit of effect.
kwill is offline
post #728 of 1170 Old 07-18-2005, 01:50 PM
brickie's Avatar
Quoted: 24 Post(s)
Liked: 26
Yeah, they will work perfect for you in this situation!I don't think you'll be disappointed at all..
brickie
brickie is offline
post #729 of 1170 Old 07-18-2005, 02:22 PM
kwill's Avatar
sweet- just what I wanted to hear. Now to figure out which model, how many, and how to power them. I am sure there are lots of suggestions in this 25 page thread- Im off to start reading-
thanks
kwill is offline
post #730 of 1170 Old 07-19-2005, 11:01 PM
theritzes's Avatar
I have a question that I might have missed within the 25 pages of thread...
Lame newbie question, but how do I run the sound to two seperate recievers to utilize a dedicated reciever for shakers?
Anyone else with any hair-brained ideas... or am I the only one?
theritzes is offline
post #731 of 1170 Old 07-26-2005, 02:35 PM
maxkoz's Avatar
Hi guys, a few quick questions. What would be the ideal frequency in which to run the shakers? I just bought 6, and I will be powering them up with a simple amp. Do you guys recommend that I buy one of those things that cut off the higher frequency? What level should it be?
Will an amp with tone control help in any way? Those that have a know that goes from bass on the extreme left to treble in the extreme right.
Max
maxkoz is offline
post #732 of 1170 Old 07-26-2005, 03:42 PM
PAP
PAP's Avatar
Theritzes - you run the shakers off the LFE output.
Maxkoz - run them off hte LFE output. I run mine "full range" at that level. Tone control: nope. You can buy cutoff filters if your preamp doesn't let you specify, but I wouldn't bother.
Good, cheap, easy - pick any two.
PAP is offline
post #733 of 1170 Old 07-26-2005, 04:06 PM
maxkoz's Avatar
Thanks PAP, just let me get it straight. If I use my Sub out I dont really need a cutoff filter? My HT Sub has a crossover knob, and so does the receiver. What I dont want to do is lose bass in the sub due to the setting for the shakers. Any ideas?
maxkoz is offline
post #734 of 1170 Old 07-26-2005, 05:56 PM
PAP
PAP's Avatar
Just use a 'Y' connector from your sub output on your receiver and send signal to both sub and shaker amp.
PAP is offline
post #735 of 1170 Old 07-26-2005, 06:49 PM
maxkoz's Avatar
PAP, sorry to insist, but what should I set the receivers cross over setting to?
Will that affect my subs performance?
maxkoz is offline
post #736 of 1170 Old 07-27-2005, 04:40 AM
PAP
PAP's Avatar
If your receiver is 5.1 there should be no crossover for the LFE output. You may be able to direct some of the output from other speakers to the sub (i.e. "small" vs. "large") but that's up to the characteristics of your other speakers (i.e. bookshelf vs. full range).
As far as the shakers, just run them with whatever come from the LFE output. If you have to choose a high pass, I'd set it around 80 hz.
PAP is offline
post #737 of 1170 Old 07-27-2005, 07:17 AM
maddogmc's Avatar
Just jumping in with a comment here...
Bass Shaker effects and subwoofer interaction is a matter of preference. The subwoofer should be set up to crossover properly with your main speakers.
My personal preference with the Bass Shakers is too use a separate crossover for the shakers around 40 Hz. I want to feel action effect but have as little music energy as possible passing to the shakers.
Shakers are fun and different when you first install them but once the novelty wears off, you will probably reduce the effects from your initial settings. Of course, everyone to their own preferences.
"I'm a fanatic without a cause and I believe in it!" - B. D. G.
maddogmc is offline
post #738 of 1170 Old 07-27-2005, 08:53 AM
maxkoz's Avatar
Ok, I think I am getting it, however I still have a question. Is there a difference betwen sub out, and LFE out? If thats the case, my receiver only has sub out.
I think that an fmod could be right for me. Anyone out there has an extra one to sell?
maxkoz is offline
post #739 of 1170 Old 07-27-2005, 01:35 PM
theritzes's Avatar
Thanks pap, I figured things out once I actually set down to read all 25 pages of this thread. Page 12 or so had the answers I was looking for.
post #740 of 1170 Old 07-27-2005, 03:01 PM
maxkoz's Avatar
Guys, I have one of those 80's amps with an eq. Will this work for me? Even if the amp does not power 20hz, I would switch it with another amp, but the question is geared towards the cutoff. WIll the eq, allow me to do the cutoff I need?
Thanks again.
maxkoz is offline
post #741 of 1170 Old 07-28-2005, 04:41 AM
lvisneau's Avatar
Shakers are fun and different when you first install them but once the novelty wears off, you will probably reduce the effects from your initial settings. Of course, everyone to their own preferences.[/quote]
it will never wear off. i've had mine for 3 mo.s and i keep turning them up and up and up ...... i need more
My sono build
Psn Id- lvisneau or lvizzzy
Xbl- chief vizzy
lvisneau is offline
post #742 of 1170 Old 08-01-2005, 09:00 AM
barhoram's Avatar
Quoted: 167 Post(s)
Liked: 37
Does anyone have experience driving bass shakers with a digital reciever? I'm looking at the Sony 3000es that can be had a a very reasonalbe price these days--and has full rs232 controll for a tie in wiith my autiomation system.
I don't really like talking about my flair
barhoram is online now
post #743 of 1170 Old 08-07-2005, 04:27 PM
Josh Z's Avatar
Quoted: 2475 Post(s)
Liked: 1627
Forgive me if this has already been addressed somewhere in the previous 25 pages of the thread. If so, feel free to just point me to which page.
People have suggested running a Y-connector from the primary receiver's subwoofer output to go to a secondary receiver or amp to power the bass shakers. That makes perfect sense, but let me try this theoretical:
What if, instead of running the Y-connector out from the subwoofer out, you ran it from the DVD player's coax digital output? One branch goes to the primary receiver, the second branch goes to a secondary DD/DTS receiver. You set that 2nd receiver for 3 large front speakers, no surrounds, and no subwoofer, then crank up the bass settings. Connect to three bass shakers attached to the chair. You should then get discrete directional shaking from left, center, and right.
Is there any reason this wouldn't work? Any disadvantages? Would there be too much bleed from non-bassy sounds shaking the chair?
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #744 of 1170 Old 08-08-2005, 01:20 PM
Elfman's Avatar
I guess in theory, this could work, but I think you already addressed some of the drawbacks to this. I would think that your shakers would shake essentially whenever there was sound coming out of your speakers. In some cases, it might not be too much, but in others, I would think it would be very distracting. I don't know how wierd it would be to have as something as small as a bird chirping in the background actually shake the seats.
Also, I am not sure how much transferrence would happen as well. Even if you attached these shakers to a couch, would the other parties even be able to feel the directional shaking? Plus the guy in the center seat would probably go crazy from all the shaking from dialogue.
Now if you put an LFE crossover between the shakers and the amp, that would filter out all the high end frequencies and leave the bass to go to the sub and I suppose you could get some of the effect you describe.
So if you have the gear, I say give it a try and let us know how it feels. I would also run a normal setup so that you can see the difference between the two setups.
Elfman is offline
post #745 of 1170 Old 08-08-2005, 01:44 PM
Josh Z's Avatar
Liked: 1627
Thanks for the response, Elfman.
I suspect you are right, but the only thing I have to add is that currently I am not using an external receiver at all. I just have the Aura Bass Shakers connected to the front mains on my primary receiver (with those channels set to Large), and I hardly get any shake at all except for extreme bass situations. I had feared, as you say, that every time someone spoke my chair would vibrate, but that isn't the case now. Is that just because I don't have enough amplification?
The plan was to put the shakers close enough together that 1 person in the center would feel all three. I watch most of my movies alone. I wasn't really even thinking about others.
Josh Z
Josh Z is offline
post #746 of 1170 Old 08-08-2005, 07:52 PM
Randy S's Avatar
I bet you'd enjoy the ability to control power to the shakers separate from your main amp. At the point you get them adjusted where you like, the higher frequency shaking may become more noticeable and subsequently bothersome? If so, an easy solution are 50/70/etc Hz FMOD in-line low pass RCA filters.
Search the forum or Google for more info.
Randy
Randy S is offline
post #747 of 1170 Old 08-09-2005, 06:46 AM
Rotoman's Avatar
Liked: 40
Josh,
I tried what you're suggesting and for many movies you won't notice much 'shaking'. When it got annoying however, was when I would watch a movie that had a character with a deep bass voice. Then you'd get 'shake' whenever that character spoke. Got to be a bit annoying and so I switched to a separate amp. Much better experience now.
Xbox handle: TheRotoman
Rotoman is offline
post #748 of 1170 Old 08-09-2005, 07:59 AM
Josh Z's Avatar
Liked: 1627
Good advice.
I think I might try it anyway, and if I don't like it I'll just disconnect the output from the DVD player and connect to the main receiver's subwoofer out instead.
Josh Z
Josh Z is offline
post #749 of 1170 Old 08-19-2005, 11:25 AM
Josh Z's Avatar
Liked: 1627
Well, I had a bead on a cheap DD/DTS receiver but the seller turned out to be a total flake and the deal fell through.
I think I'm just going to go with a standard subwoofer amp now. Parts Express has a good deal on a 70W unit. Would that be enough to power 2 Aura Pro shakers?
Josh Z
Josh Z is offline
post #750 of 1170 Old 08-19-2005, 12:33 PM
J. L.'s Avatar
If you only have two you will need to put them in series. this will result in an 8 ohm load to the plate amplifier.
Is the amplifier rated for 70 watts into 8 ohms, or at 4 ohms?
If at 70 watts at 8 ohms, you will be fine. Otherwise, you might only have 35 to 45 watts available at 8 ohms if it was rated at 70 watts into 4 ohms.
Then if only 35 to 45 watts, it will be marginal for the "pro" units as you will only have about 20 watts available for each shaker. (Now... they will still shake plenty hard at this level, but not at the full potential of the "pro" model)
Joe L.
J. L. is offline
Reply Theater Room Items & Accessories
