I have not seen too much in this forum on bass shakers. My quaestion is has anyone purchased and used the Aura Bass Shaker Pro's (50w); AST-28-04? I have seen them for a good price but don't know how well they work. I was thinking of mounting one per seat under my Lane Majestics with a plywood connection across the frame. The other way I have heard to do this is to make a plywood base the same size as the chair demensions, raise it slightly up using rubber pads, and then mount the shakers to the plywood and then the chairs to the plywood.
I was hoping to find a cheap used receiver to drive these shakers using the pre-amp output on my Yamaha 2400.
Anybody have these and use them ? How did you mount them? How many do I need to buy to get a good effect? Is one per chair okay or should I get more?
Tom
Tom
