Excel HT Ticket Maker rev. 4.1.2 (9/2/04) - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 450 Old 01-26-2005, 07:44 PM - Thread Starter
MikeWh's Avatar
IfixitBIG-- FYI: You can get rid of those little green triangles on your tickets by disabling Error Checking. Excel thinks that there might be a problem in the cell (even though there isn't). I believe the feature is disabled in Excel 2002 by going to Tools/Options and selecting the Error Checking tab.... then deselect the box that says something like "Enable background error checking." Sorry... I don't remember if that's it exactly. I've got Excel 2000 here at home. Alternatively, you can hover your mouse over the individual cells and a pop-up will ask you if you want to fix the cell.... and you can tell it to pound sand... or something to that effect. :-)
(Maybe others can correct me here, if I didn't get those directions quite right... )
MikeWh is offline
post #182 of 450 Old 01-26-2005, 07:52 PM - Thread Starter
MikeWh's Avatar
Rotoman-- question:
I noticed that you posted a .bmp of your ticket. Did you know there is a button for automatically saving your ticket as a .gif? It says "Save Ticket 1 as a GIF." It should save it as "Ticket1.gif" in the directory where you have saved the TicketMaker .xls workbook.
(Just a helpful hint.... since gifs and jpgs are generally more browser-friendly when posting images in the forum.)
MikeWh is offline
post #183 of 450 Old 01-26-2005, 08:20 PM
IfixitBIG's Avatar
Thanks for the information. I have them when I save as a graphic, but not on the print out.
John Burton
IfixitBIG is offline
post #184 of 450 Old 01-27-2005, 08:47 AM
Rotoman's Avatar
Liked: 40
Mike-
Thanks for the tip. I'm not printing these as I don't have a good printer so the format I'm saving them in hasn't been that important to me as I'm just emailing them out. That said, I had just cut and pasted the ticket from your program into Paint in order to add some other graphics which after reading Ifixit's posts I realized I didn't need to do. Then when I saved from paint it defaulted to a .bmp file.
Going forward, I'm just going to use the add image function in Excel to tweak the graphic. And I'll remember to save as a .gif.
To your point about the 'Save ticket 1 as a .gif' button, I don't use it as I like to keep copies of all of the tickets I make. May be a suggestion for later to have the option to "Save as" and then pick a filename. Otherwise, each time you use the program to create a ticket you're overwriting previous work. May not be a big deal to some but I like to have the old ones.
Xbox handle: TheRotoman
Rotoman is offline
post #185 of 450 Old 01-27-2005, 09:48 AM
rdwalt's Avatar
Mike, Thanks for the 'disable error checking' tip. You got it right. Here's my new SBXXXIX Ticket. (All Excel, no photoshop)
"If you never did, you should. These things are fun and fun is good."- Dr. Seuss
rdwalt is offline
post #186 of 450 Old 01-28-2005, 10:15 AM
salreus's Avatar
Ok. this is what I tossed together. I am done messing with it now. This is a great program.
salreus is offline
post #187 of 450 Old 01-28-2005, 11:28 AM - Thread Starter
MikeWh's Avatar
I had considered doing the Save As..., but thought this would be more user-friendly.... maybe not though. I didn't think people would be keeping their tickets, so I went the other way (plus the coding was easier). As an alternative, you can always rename the Ticket1.gif after it's saved, so you don't overwrite it next time. I've added this to my "issues log" for the next version.
Good to know. Thanks for the follow-up. FWIW-- this issue was raised in a previous thread about the Ticket Maker, but I can't seem to find that thread. DOH!
MikeWh is offline
post #188 of 450 Old 01-28-2005, 12:04 PM
voltes's Avatar
Finally made my last ticket. If anybody wants some of the graphics I used, like the helmets, logos, etc just let me know. I can attach them here. Thanks for everybody's great ideas!
voltes is offline
post #189 of 450 Old 01-28-2005, 12:34 PM
salreus's Avatar
man, i looked all over the place for the DD sign. I want that for later if you want to post it. Here is another pic I ran across but didn't use.
salreus is offline
post #190 of 450 Old 01-28-2005, 12:36 PM
salreus's Avatar
duh, I can see why now. wrong bowl. hehe
salreus is offline
post #191 of 450 Old 01-28-2005, 12:36 PM
salreus's Avatar
salreus is offline
post #192 of 450 Old 01-28-2005, 12:44 PM
voltes's Avatar
salreus, is this what you want?
voltes is offline
post #193 of 450 Old 01-28-2005, 12:48 PM
voltes's Avatar
And here's a big Superbowl XXXIX logo.
voltes is offline
post #194 of 450 Old 01-28-2005, 01:19 PM
taxman48's Avatar
Quoted: 301 Post(s)
Liked: 297
Voltes: can you attach the helmet logos? How do you bring them into the ticket maker? thanks matt
taxman48 is offline
post #195 of 450 Old 01-28-2005, 02:15 PM
voltes's Avatar
here's the helmet logos.
I will just attach the others in case anybody's interested.
voltes is offline
post #196 of 450 Old 01-28-2005, 02:16 PM
voltes's Avatar
Pats helmet..
voltes is offline
post #197 of 450 Old 01-28-2005, 02:21 PM
voltes's Avatar
afc logo
voltes is offline
post #198 of 450 Old 01-28-2005, 02:23 PM
voltes's Avatar
nfc logo. very small, maybe you can find a bigger one. so far this is the only thing i can find.
voltes is offline
post #199 of 450 Old 01-28-2005, 02:24 PM
voltes's Avatar
eagles logo
voltes is offline
post #200 of 450 Old 01-28-2005, 02:34 PM
voltes's Avatar
pats logo
I think that's all of it. I hope somebody find them useful.
matt,
do an insert of a picture from file. insert the file and resize it to overlay the part where the you want the pics to show.
voltes is offline
post #201 of 450 Old 01-29-2005, 09:50 PM
salreus's Avatar
yeah, that was the gif I wanted. thanks. I can use that for my normal tickets. Thanks for finding it and posting it.
salreus is offline
post #202 of 450 Old 01-30-2005, 08:31 PM
murph3699's Avatar
I made a ticket of my own as well. Thanks Voltes for the logos and the Photoshop template.
murph3699 is offline
post #203 of 450 Old 01-31-2005, 02:30 AM
ithrill's Avatar
my first ticket how can i easily put a picture in the backround? (star wars ticket on page 7)
ithrill is offline
post #204 of 450 Old 01-31-2005, 08:26 AM
voltes's Avatar
Originally posted by murph3699
Thanks Voltes for the logos and the Photoshop template. [/b]
Greats tickets everyone! One more week and we can put them to good use.
Btw, I didn't provide for the photoshop template it was generously provided by bugman72.
The picture background can be done if you use the photoshop version. I haven't found a way to do that in the excel version yet.
voltes is offline
post #205 of 450 Old 01-31-2005, 09:07 AM
rdwalt's Avatar
Murph, I like the 'No Recording Devices' and 'No Smoking' on your ticket.
rdwalt is offline
post #206 of 450 Old 01-31-2005, 04:37 PM - Thread Starter
MikeWh's Avatar
Unfortunately, you can't do backgrounds with the Ticket Maker. I'll have to check if Excel 2003 is any friendlier with background images (possibly for the next version), but it can't be done with Excel 2000 and earlier. The tickets with backgrounds are done using a Photoshop template (also available in this thread).
MikeWh is offline
post #207 of 450 Old 01-31-2005, 04:53 PM
ithrill's Avatar
sucks for me i guess. I don't know how to use photoshop Does someone have a tut. on inserting the pic?
ithrill is offline
post #208 of 450 Old 01-31-2005, 06:03 PM
704set's Avatar
This thread shows why this is the best forum. Great talent and resources on every aspect. Several years ago I was trying to figure out what the hell was 5.1. Now I'm trying to figure out how to print tix for my soon to be completed theater.
Thak you.
Skip
704set is offline
post #209 of 450 Old 01-31-2005, 08:40 PM
murph3699's Avatar
I sent out a bunch of "tickets" to my friends and family who will be watching the game at my house.
post #210 of 450 Old 02-01-2005, 04:19 PM
murph3699's Avatar
I added a Lombardi Trophy to the ticket I made for my pal. Here it is.
Reply Theater Room Items & Accessories
