Universal Style Animation/Logo - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 558 Old 01-26-2007, 08:07 AM
Sevker's Avatar
Originally Posted by MikeFalz View Post
bike potato
greighn
Sevker
mprusak
Stone Mason
Your blender files are done.
And mine looks great! Thanks Mike!! I'll post a low rez wmv of it later on.
Sevker is offline
post #182 of 558 Old 01-26-2007, 10:44 AM
Magius's Avatar
To those having problems rendering a 16:9 resolution in your dvd player without black bars, I'll repeat some advice that I picked up in the original FOX intro thread. I'm not the originator of this information but it worked for me and my FOX intro.
720x480 (DVD resolution) is obviously not a 16:9 ratio (it's 1.5:1 rather than 1.777:1). In order to fill the screen with no black bars you need to use a true 16:9 resolution, such as 800x450 instead. This is close enough to the regular DVD resolution, but maintains the aspect ratio that you're looking for without the black bars.
Of course you can render in the HD resolutions (1280x720, etc.) and eliminate the problem entirely, but in the FOX thread there were many peole complaining about black bar issues while trying to get DVD or near-DVD resolutions, so I thought I'd repost the solution here. Hope that helps.
Magius is offline
post #183 of 558 Old 01-26-2007, 12:16 PM
Magius's Avatar
Finally after a long week of not having the time to touch my .blend file it's Friday and I'm able to add some finishing touches. The white on gold lettering is now complete, and I've attached some 16:9 screenshots showing the new look. It was painstakingly difficult to do, but I think it turned out nice.
Also, I felt that the text was a wee bit dark after settling into place in front of the earth, so I added some extra lamps to help illuminate it. These lamps dont come on until the same time the Halo appears, so it looks like the earth's halo actually brightens the text. I don't know it's kinda cheesy, but I like the result. Look closely at frame 300 vs. 400 and you'll see the difference in lighting that I'm talking about.
I guess the next step is another low-res video to make sure there's nothing blatant that needs fixing, but otherwise this intro may just be complete!
Magius is offline
post #184 of 558 Old 01-26-2007, 12:27 PM
MikeFalz's Avatar
Originally Posted by redstang93 View Post
PM sent Mike.
Everyone has done awesome work with this intro. I was able to work with the Fox opening pretty easily, but this one has been giving me a lot of trouble. I want to learn blender because it seems like it can be a useful tool to have.
On it's way...
"You need people of intelligence on this mission. . . quest. . . thing."
MikeFalz is offline
post #185 of 558 Old 01-26-2007, 12:50 PM
zductive's Avatar
Anyone willing to help me branch this off with deep space nine replacing the earth and enterprise circling along with the text?
zductive is offline
post #186 of 558 Old 01-26-2007, 01:25 PM
atagert's Avatar
Well, replacing the stuff is easy, just insert the messhes where the other were and delete the old ones. the bigger problem, is that you will have to come up with a new lighting scheme as the star trek ships don't emit light. At some point, I'm going to attempt something like that, but I want to get my universal and fox logos done and rendered.
Adam
Descartes walks into a bar. The bartender says, "Wine?" Descartes says, "I think not," and disappears.
atagert is offline
post #187 of 558 Old 01-26-2007, 01:51 PM
atagert's Avatar
I just discovered that there optimized versions of blender that run faster for windows users with advanced CPUs. I'm installing now to see the speed difference.
http://graphicall.org
Select windows and then BF.
Adam
atagert is offline
post #188 of 558 Old 01-26-2007, 01:57 PM
atagert's Avatar
Adam
I can confirm that the render times feel like better than half of what they are with the official version.
Adam
atagert is offline
post #189 of 558 Old 01-26-2007, 03:41 PM
MikeFalz's Avatar
ND23,
Your blender file is on it's way.
Mike
MikeFalz is offline
post #190 of 558 Old 01-26-2007, 05:23 PM
StoneMason's Avatar
bike potato
greighn
Sevker
mprusak
Stone Mason
Thanks a mill Mike... it looks perfect!
I started the render a few minutes ago (that'll take some time). However, You saved me countless hours of setting this up myself in Blender.
I do want to understand how to do this myself eventually, but I am hardcore into finishing the theatre right now.
sm
StoneMason is offline
post #191 of 558 Old 01-26-2007, 05:56 PM - Thread Starter
w84no1's Avatar
Adam
Yes, it cuts my render time in half. For a 1280 x 720 render it went from 3 hours to 1.5 hours. For the .blend file that Mike sent me
Great find!!!
Update, it crashes when I try to render one frame of my fox style .blend file
w84no1 is offline
post #192 of 558 Old 01-26-2007, 07:14 PM
atagert's Avatar
Great find!!!
Hmm, I am rendering the fox logo right now on my 2nd computer with the optimized blender. I think I may have figured out the flickering.
Adam
atagert is offline
post #193 of 558 Old 01-26-2007, 07:28 PM
atagert's Avatar
Hi all, I have finished my universal file. Here is the video of it. This video has feature presentation wrap around the earth and the theater name to fade in. Personally, this is what I prefer.
http://atagert.andrew.cmu.edu/videos...al_feature.wmv (4mb)
Fortunely, it is easy to edit this way.
blender file
http://atagert.andrew.cmu.edu/videos...ntation_wt.zip
To Edit
1. Right click on ATagert Theater PGH
2. press TAB
3. Change Text
4. press TAB
5. render.
you may have to assoicate the earth sphere with the map of the earth, to do that, Right click on the early, F6, then Load Image.
I have included a slightly edited map, that begins over India instead of the Pacific.
Remember, you can downloaded a version of blender that is optimized for your CPU. http://www.graphicall.org
I will post a file that can be used to edit the wrapping text soon. (maybe tomorrow).
Adam
atagert is offline
post #194 of 558 Old 01-26-2007, 07:37 PM - Thread Starter
w84no1's Avatar
Adam
If you do get it render without the flicker can you post the .blend file? That is the only thing that I hate about my Fox intro.
w84no1 is offline
post #195 of 558 Old 01-26-2007, 07:42 PM
atagert's Avatar
Sure, I'll make the post in the fox thread though if successful.
Adam
atagert is offline
post #196 of 558 Old 01-26-2007, 08:00 PM - Thread Starter
w84no1's Avatar
Adam
w84no1 is offline
post #197 of 558 Old 01-27-2007, 01:32 PM
atagert's Avatar
Ok, I created the template file with instructions that will allow you to edit any of the text in the universal file.
http://atagert.andrew.cmu.edu/videos...l_template.zip
Hope all the instructions are clear. If anybody creates anything with, I'm interested in knowing about what you did.
The file is real a zip file and includes the blender file and the instructions in both word 97-2003 and word 2007 formats.
Adam
atagert is offline
post #198 of 558 Old 01-28-2007, 07:40 AM
disguised coot's Avatar
thanks for the files, but i have followed your guide but a cant seem to edit the text that comes around the globe,, i select it but it shows up as a mesh and not text.
disguised coot is offline
post #199 of 558 Old 01-28-2007, 09:26 AM
Magius's Avatar
disguised coot, I confirmed what you are talking about just this morning. Atagert's file seems to have the text already converted to a mesh, however his modified version of my instructions treat it as if it were still plain text. Unfortunately He'll have to upload a .blend file with plain text in order for the instructions to work out.
Alternatively you could download my old .blend file (back on page 3 or so) and use my instructions, but you'll be lacking a number of visual enhancements that have happened since then. Off the top of my head I know it's missing the white on gold lettering, the halo is a poor looking hack job (though there's a second set of instructions for fixing that), and there are no clouds on the earth (though this can be easily added). There might be other things missing from that file as well, but if you're up for some experimenting it's not a bad place to start.
Magius is offline
post #200 of 558 Old 01-28-2007, 01:51 PM
atagert's Avatar
oh, sorry about that. I guess I just uploaded the wrong file. I'll check into it.
Adam
atagert is offline
post #201 of 558 Old 01-28-2007, 04:02 PM
jeffczyz's Avatar
Looks like you guys are making some good progress on the blender files. I apologize for the delay in getting back with everyone, I've been trying to wrap up this countdown project this past week.
A few of you expressed interest in having me render out some AVI's without the sound. For those that contacted me, are you still interested? After the progress being made with the blender files, I don't want to waste time rendering out stuff that can't be altered.
Please PM me if you're interested,
Jeff
jeffczyz is offline
post #202 of 558 Old 01-29-2007, 08:45 AM
atagert's Avatar
I fixed the file. For some reason, which I don't know I can't upload it, so I'm just going to attach it here, and later update the other one.
just_blender_universal.zip 125.552734375k . file
Instructions.doc 43k . file
atagert is offline
post #203 of 558 Old 01-29-2007, 10:09 AM
mprusak's Avatar
Mike -
I got my file and rendered it this weekend. It looks great! Thank you, Thank you!!
Now, my questions...I did this before with the Fox style one, but can't remember how.
So, I have this huge 1.8 GB avi file (that my computer can not play smoothly).
How do I add the audio to this?
How do I convert this to a file the computer can play?
How do I convert this to a file I can play on a DVD player?
Thanks again...
Mark.
mprusak is offline
post #204 of 558 Old 01-29-2007, 10:21 AM
Chiahead's Avatar
Originally Posted by mprusak View Post
Mike -
Thanks again...
Mark.
Try downloading VirtualDub. It is free, and can add the audio, plus compress the video.
Or for the Fox one, I used Studio from Pinnacle. (It came with my video card) It will allow you to make the video, add audio, and make a DVD.
I don't know, but Nero might take your final file and make a DVD for you.
Michael
PSN: Chiahead
Chiahead's Man Cave - Indexed
Loganed on 8/29/2008
Chiahead is offline
post #205 of 558 Old 01-29-2007, 03:37 PM
redstang93's Avatar
On it's way...
Thanks Mike. The animation looks awesome. Added the audio and now am just trying to convert it to a .vob file.
redstang93 is offline
post #206 of 558 Old 01-29-2007, 05:18 PM
Mark Booth's Avatar
Quoted: 49 Post(s)
Liked: 61
Mike -
Thanks again...
Mark.
Load the big ponderous file into iMovie HD, edit (add sound, fade in/fade out, etc.) to your heart's content, and then export it as a H.264 compressed file. Everything you need comes free with your Mac.
Sorry... couldn't resist!
Mark
Mark Booth is offline
post #207 of 558 Old 01-29-2007, 06:31 PM
atagert's Avatar
Mark
I think Windows Movie Maker does the same stuff.
atagert is offline
post #208 of 558 Old 01-29-2007, 08:34 PM
Jawhn's Avatar
Having problems!
I've used some earlier files, followed the instructions and made a couple of DVD's with decent results. With the latest file above I had several problems.
1. When I switch to "top view" (7) all text and the globe disappears.
2. After changing the text on the globe and centering, the 2 texts don't line up and the white text disappears when selected. " Backspace" only deletes part of the text ("delate" must be used for the remaining letters).
3. The lower fade in text renders "black".
4. When in "Animation" (Part 3 of the instructions), there does not appear to be any animation.
5. What do I select in the "World buttons" panel to select a new background sky?
One last Question: What sound file are you using?
I figured out how to correct some of these problems but could definitely use some help.
Thanks for all the hard work! Any help is appreciated.
Jawhn
If the Theater is a Rockin, don't come a Knocking!
My Home Theater
Jawhn is offline
post #209 of 558 Old 01-29-2007, 10:50 PM
atagert's Avatar
I haven't actually added any sound to mine. I'm not sure what I'm going to use. I was hoping to figure out how to encode it into 5 channels and thus do some fun effects with it, but I don't know how to do that yet.
1. As to the globe disappearing, I think you may just have to zoom out. To do that, it the - key on the number pad. You can scroll around the window by holding ctrl and pressing 8,6,4,2.
2. The reason you may have use backspace and delete, is that blender remembers where the cursor was when I last edited the file. Apprently, I had it somewhere in the middle.
2a. Let me see you're right, it does disappear when editing. I'm not sure why it does that. I have only been using blender this past week.
2b. To re lineup your text you can select it and then click on the object menu, and then on transform. You'll see the options move on axis and scale on axis. the x axis is left and right and z is up and down. Choose the local opion to make it simplier.
3. You'll want to make sure you render after frame 550. Before that point it is set to be transparent.
4. I am assuming that you are having a problem to get the text to move around the earth. My suggestions is to be looking straight down (7), then select the arm that comes out of the earth. Press r and as you move the mouse around it should swing the text around the earth.
I know lots of my answers include should, but I hope it is similar for you.
Answering questions are no problem in this, since I have a graps of what is going on in the file, since i have messed it up enough times. Let me know if you have any more questions, I'll be checking the thread.
Adam
atagert is offline
post #210 of 558 Old 01-30-2007, 10:22 AM
tried your new blender file, the text looks great but i still cant seem to get the text to swing around the earth, i have selected the armature and that does move with the mouse,, but does not turn with the globe
Reply Theater Room Items & Accessories
