Mini Buttkicker Vs LFE - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 02-12-2007, 08:24 PM - Thread Starter
darrenpresley's Avatar
Since the Berkline Factory only installs the Mini in their smaller chairs (45004,088) and LFE in their "larger" chairs, has anyone experienced the difference in the Mini and the LFE?
darrenpresley is offline
post #2 of 25 Old 02-12-2007, 11:03 PM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
I have.
While the buttkicker LFEs are more powerful, I found that the mini buttkickers are quite efficient and could literally move the chair
Everything is relative though...
Roman
rtheaters.com
Fusion Collection Seating
Ultimate Home Entertainment
rsh is online now
post #3 of 25 Old 02-13-2007, 08:50 AM
mccabekyle's Avatar
Agreed. I find the Minis to be every bit as responsive and "punchy". They just don't quite shake the paint off my walls like my full-sized LFEs. The Minis are definitely worth the money!
Kyle McCabe
Carolina Interiors Home Decor
Theater Seating Specialist
mccabekyle is offline
post #4 of 25 Old 02-13-2007, 08:51 AM
Iceblade's Avatar
Roman,
How would you rate the mini LFE vs. the mini Concert? Is there an appreciable difference? I'm leaning towards the LFE since my theater is mainly used for movies, but I do throw on the odd music track now and then.
Jeff
Iceblade is offline
post #5 of 25 Old 02-13-2007, 10:00 AM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
Jeff,
Mini and mini concerts are the same transducers. The only difference is in impedance - the minis are 4 Ohms, and the mini Concerts are 2 ohm (were designed for the drummer's seats).
Roman
rtheaters.com
rsh is online now
post #6 of 25 Old 02-13-2007, 10:04 AM
Iceblade's Avatar
Roman,
Maybe I am misunderstanding. According to this picture, there are two varieties of mini.. the LFE and the Concert.
http://www.thebuttkicker.com/MINI_home.html
Does that help clarify my question any more?
Regs,
Jeff
Iceblade is offline
post #7 of 25 Old 02-13-2007, 10:08 AM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
Yes, there are, and the differences I described - IMPEDANCE - that is the only difference.
Oh, there is another one - the color. Sometimes they paint them blue, sometimes red
Roman
rtheaters.com
rsh is online now
post #8 of 25 Old 02-13-2007, 10:18 AM
Iceblade's Avatar
LOL. Fair enough. Thanks!
Regs,
Jeff
Iceblade is offline
post #9 of 25 Old 04-21-2007, 05:57 PM
timatraw's Avatar
Quoted: 24 Post(s)
What type of buttkicker is installed in the Berkline #45003?
The mini or the LFE?
timatraw is offline
post #10 of 25 Old 04-21-2007, 06:02 PM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
BK-LFEs
Roman
rtheaters.com
rsh is online now
post #11 of 25 Old 10-17-2007, 07:37 AM
strange_brew's Avatar
Roman,
What do you recommend for the 45004's? I was thinking of going with the Minis, but would consider the LFE as well if you think its worthwhile. I know where the LFE would likely mount in my chairs, but where does the mini go? Same place?
Craig
ReedZone Theater Thread
strange_brew is offline
post #12 of 25 Old 10-17-2007, 08:21 AM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
Craig,
The Berkline uses mini buttkickers. They say that there is not enough space for the BK-LFEs, but I know some AVSForum folks were able to install the BK-LFEs in their 088s, so I do not think there should be a problem with the 45004 either. You want to make sure that there is anough clearance for the reclining mechanism, so it is not hitting the buttkicker .
The mini-buttkickers are usually mounted on the back wooden rail - just screwed into that.
Roman
rtheaters.com
rsh is online now
post #13 of 25 Old 10-17-2007, 09:10 AM
mccabekyle's Avatar
Anyone have any links or photos of the full-size LFE's installed in one of the smaller Berkline chairs? Or for that matter, any non-Berkline chair? I, too, have heard of some AVS'ers that have made it happen.
Kyle McCabe
post #14 of 25 Old 12-30-2007, 04:19 PM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
bump!
I would also like to get more info.
I got 45004 and 090 and would like to go with only one flavor of BK.... I was told from a very knowledge source that mixing of mini and LFE BK will cause trouble, due to the difference electrical characteristics.
____
Axel
Axel is offline
post #15 of 25 Old 12-30-2007, 05:25 PM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
Axel,
I will not cause trouble, but the load will not be equal, so tuning would be hard, and it will almost be impossible to make it even bewtween different style chairs.
Roman
rtheaters.com
rsh is online now
post #16 of 25 Old 12-30-2007, 07:10 PM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
Roman;
Thanks for your clarification. Appreciated!
So the questions remains how well LFEs fit in smaller chairs, e.g. 45004. Anybody tried it yet??
____
Axel
Axel is offline
post #17 of 25 Old 12-31-2007, 06:27 AM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
Axel,
I have seen some folks retrofitted the BK-LFEs into the 088s, so I would assume you could do it with the 45004s as well. Try searching the forum...
Another option is using mini-buttkickers in all of the chairs. While they called mini they are pretty effective.
Roman
rtheaters.com
rsh is online now
post #18 of 25 Old 12-31-2007, 10:36 AM
power's Avatar
Yep mixing and matching full sized LFEs and the minis off of the same Buttkicker amplifier will not necessarily yield problems, the minis would run at their full potential but given the power load running off of the same amp, the full sized Buttkickers will not be running at their max potential. So mixing and matching will work, the minis will run full power, the full sized kickers will be hardly breaking a sweat.
Either upgrading the 086, 088 and 45004 to full sized LFEs has been done but this would be DIY, not a factory option available from Berkline directly. Same goes for downgrading the full sized chairs to mini Buttkickers, this can also be done but again DIY. Hope this helps.
I wish Berkline would make the minis available on all their chairs, more than enough power to add that extra dimension members are seeking to the theatre experience and much cheaper to boot.
Serge Breton
htauthority.com
Home Theater Authority
power is offline
post #19 of 25 Old 03-27-2009, 12:16 AM
donnie1221's Avatar
Hate to dig up old threads, but would these be just as good as subwoofers? Like if I attached one each to a seat in a car? Just wondering, was thinking it would be nice to get some effect like a subwoofer, but without taking up space in the trunk or anywhere else. Thanks for any info, I've kind of read around a little, but I haven't gotten to personally "feel" these things in action. I was looking at the minis though.
donnie1221 is offline
post #20 of 25 Old 03-27-2009, 07:51 AM
jamis's Avatar
Bass shakers and other transducers are used all the time in cars for this very purpose.
For HT applications, they should be used in addition to a sub woofer... I would never use them instead of.
jamis is offline
post #21 of 25 Old 04-03-2009, 03:29 PM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
I agree. While BK or transducers add nicely to the overall LFE experience, they are no substitution when in comes to feeling the low frequencies and the compressed air pounding against chest and forehead .
____
Axel
Axel is offline
post #22 of 25 Old 11-11-2012, 02:15 PM
Archaea's Avatar
Quoted: 2834 Post(s)
Liked: 2416
Bump for additional feedback? Anyone compared the Buttkicker mini LFE to say the Clark Synthesis 209?
Archaea is online now
post #23 of 25 Old 11-12-2012, 10:35 AM
Rob Greer's Avatar
As an aside, I called Buttkicker the other day and asked the OPs question straight out. They said that the Minis are recommended over the LFEs for single chair installations as the Minis have more than enough juice to move the chairs.
And now back to your regularly scheduled programming.
"By my troth, I care not; a man can die but once; we owe God a death.... He that dies this year is quit for the next." -- William Shakespeare, Henry the Fourth, Part II
Rob Greer is offline
post #24 of 25 Old 11-13-2012, 12:25 PM
Archaea's Avatar
Liked: 2416
Cool thanks Rob.
My clencher to buy my four was 1) price -- they are only $65 at amazon right now through a partner vendor, and 2) I found out that the mini lfe is what Berkline used in their recliners for tactile transducers and that they install real easy.
Just to be sure I'm getting something I like though I'm buying a single Clark Synthesis TST209 to compare the Buttkicker mini lfe's to, and also a buddy is going to bring over his aura bass shaker units as a third comparison.
Mine should arrive this week!
Here is our thread.
http://www.avsforum.com/t/1438696/a-comparison-of-two-transducers-buttkicker-mini-lfe-vs-clark-synthesis-tst209/0_20
post #25 of 25 Old 11-13-2012, 12:33 PM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
Just to clarify - the Berkline used the mini-buttkickers only on their small footprint models like 45004. On the rest they used BK-LFEs, which IMHO were an overkill, and the best application for those would be "in-riser/platform installation". I find that the advanced BK4-4s are probably the best solution for "in-chair" installation. The mini-buttkickers are quite effective as well. The main difference would be - they go down to 10 Hz, while the advanced BK4-4s and BK-LFEs are able to reproduce the frequencies up to 5 Hz, and the advanced ones will give a bit better impact since they are more powerful.
Roman
rtheaters.com
rsh is online now
Reply Theater Room Items & Accessories
