Psyclone PSC01 manual ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-21-2007, 02:16 PM - Thread Starter
xoy74's Avatar
Hi,
I just picked up an open box Psyclone PSC01 switch with no user manual. Anybody knows where I can download it ? I've been searching for several hours and haven't been able to locate the manufacturer's web site.
Thanks !
xoy74 is offline
post #2 of 11 Old 07-24-2007, 12:20 PM
Monoplex's Avatar
http://www.psyclonegamer.com and choose Source Selector. The PSC01 model is on the top of the selections, click on it and "download manual" icon is at the bottom of the page.
Robin: "You can't get away from Batman that easy!"
Batman: "Easily."
Robin: "Easily."
Batman: "Good grammar is essential, Robin."
Robin: "Thank you."
Batman: "You're welcome."
Monoplex is offline
post #3 of 11 Old 07-24-2007, 12:40 PM - Thread Starter
xoy74's Avatar
Thank you very much !
xoy74 is offline
post #4 of 11 Old 07-25-2007, 07:16 PM
Monoplex's Avatar
If have trouble finding it, let me know and I'll be happy to e-mail it you. Just PM me with your e-mail address.
Glad to be of use to someone.
Batman: "Easily."
Robin: "Easily."
Robin: "Thank you."
Monoplex is offline
post #5 of 11 Old 06-08-2012, 05:48 AM
mdkline's Avatar
I know this is an old thread, but I was hoping someone would remember how to change the names on the display. I was just given one of these. The company is now defunct, and the manual is no longer online.
Thanks in advance for your help!
mdkline is offline
post #6 of 11 Old 06-08-2012, 06:01 AM - Thread Starter
xoy74's Avatar
Unfortunately I don't have the manual anymore, all I remember is that the small button on the right hand side of the box worked like a joystick and you could scroll through the characters and then go up/down to change them
xoy74 is offline
post #7 of 11 Old 07-09-2012, 06:56 PM
QuattroCS's Avatar
found manual here
http://www.atomroot.com/ebay/psyclone_manual.pdf
psyclone_manual.pdf 225k .pdf file
also attached in case website goes down
QuattroCS is offline
post #8 of 11 Old 02-12-2013, 06:46 PM
Outlawmars's Avatar
anyone know what the ethernet jacks are for? seem useless to me
Outlawmars is offline
post #9 of 11 Old 05-25-2013, 10:00 AM
icefloe01's Avatar
Here to re-resurrect for the third time. wink.gif The ethernet jacks are there to reduce your port usage on your router from four ports to one. It was really helpful for me when I didn't have a switch to increase my port count. Does anyone remember whether or not this box does signal translation? For example, will it take composite video and translate it over to component?
Eric
icefloe01 is offline
post #10 of 11 Old 08-09-2013, 07:31 AM
baconlover1's Avatar
hi,
when i go onto the site i dont see anywhere to download the manual.
maybe you could email it if you dont mind.
baconlover1 is offline
post #11 of 11 Old 02-25-2014, 10:39 AM
HyeVltg3's Avatar
Originally Posted by QuattroCS View Post
found manual here
For anyone else thats blind and cant find the manual, the site is dead (company disbanded/went-under)
Just got this in the mail, DID NOT expect it to be so big, the pictures of it on amazon look so misleading, this thing is huge, large footprint but very classy and thin, its twice as big as my broken switch.
Anyone know the speeds on the Ethernet? 10/100? 10/100/1000 ?
I already have a DDWRT router/switch, was wondering if I should bother using an "actual" switch or resume using my DDWRT.
HyeVltg3 is offline
Reply Theater Room Items & Accessories
