Ambient light for behind a TV suggestions - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #121 of 141 Old 08-18-2014, 11:28 AM
AllTheLights's Avatar
I have used Ikea Dioders on the back of my tv for a while and am very happy with the look/colour.
Having said that, I'm hoping to be able to refine the control so that the lights can either be controlled by remote or just automatically turn on with the tv. What would be the best way to accomplish this?
If I just went with turning on automatically, I assume that a 'smart' power bar would be the easiest. Does anyone have recommendations for these?
AllTheLights is offline
post #122 of 141 Old 08-19-2014, 07:30 PM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
I put one of these behind mine just today: http://www.amazon.ca/gp/product/B00D...?ie=UTF8&psc=1
didn't find out until after they arrived that they don't come with a power convertor though, so add another 5bux for one of those. I've got a more 'expensive' version that I used for lighting up my platform seating, looks very similar but has a few more features and came with everything needed. I was trying to do it on the cheap this time, since I wasn't sure if I'd really ever use the bias lighting.
works decent, but 'white' isn't very white. if I had to guess I'd say it's like 7500k or there about.
'white'
red/green/blue(there's some other options as well)
*note, the blue actually does look blue in real life. not sure what happened in the pic to make it look pinkish in parts
so my verdict, is that I would not recommend the exact model I used, as I think it'd be nice to be able to dim them as desired. but I like the general idea. they are remote controlled, color changeable, and if you plug it into a switched outlet, it'll remember the last setting.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #123 of 141 Old 09-14-2014, 11:15 PM
Diamond Dog's Avatar
Quoted: 18 Post(s)
looks like Eclipse is out of business. Anyone have any recomendations that are LED, Color changing and use an IR remote?
I have a 75" samsung and all the cords rund through a channel that starts behind my TV and routes into a cabinet under my TV where outlets are concealed.. So I want to minimize the amount of cords I have to run to the power outlet.
Diamond Dog is offline
post #124 of 141 Old 09-15-2014, 10:55 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
I just put up this stuff a few weeks ago
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
It went up easily, does color change, with IR control. There is a bit of a wall wart, and the IR receiver takes up some space. Looks nice, though.
Keep in mind this is during daytime, with a white or yellow backlight, taken from far back, using the photosphere!
NickTheGreat is offline
post #125 of 141 Old 10-06-2014, 06:46 AM
flyingdog's Avatar
looks like Eclipse is out of business. .
Ya...and what a shame. They were a great backlighting system. To bad you didn't catch them during their closeout sale. I was able to pickup three more sets at half price. They were certainly a hit for Christmas presents.
flyingdog is offline
post #126 of 141 Old 12-16-2014, 01:02 PM
gm2376's Avatar
Quoted: 20 Post(s)
Question, can the lights with a IR be controlled by a Harmony remote? and is the kit you linked large enough for a 70 inch tv?
gm2376 is offline
post #127 of 141 Old 12-16-2014, 03:41 PM
Quoted: 381 Post(s)
Liked: 255
I found some Taotronic in the Harmony database. It wasn't my exact model, but it works for some of the functions. Not all of the light colors. I honestly haven't gone to the trouble of learning the missing ones through the software.
My LED strip was 16.4 ft long (197"). A 70" diagonal would roughly be 60" x 35", for a total perimeter of 190".
So it'd be close. Probably really close. You'd just have to see where you could cut if you had extra. It's only every 3rd light or so.
post #128 of 141 Old 12-16-2014, 04:00 PM
gm2376's Avatar
Quoted: 20 Post(s)
gm2376 is offline
post #129 of 141 Old 12-16-2014, 04:08 PM
gm2376's Avatar
Quoted: 20 Post(s)
One last question.....does this come with connectors when i cut them? is there any soldering involved?
Thanks again
gm2376 is offline
post #130 of 141 Old 12-16-2014, 04:55 PM
boulder_bum's Avatar
Quoted: 50 Post(s)
I bought my backlighting at IKEA and hooked it up to a WeMo switch so I could turn it on/off with my phone. I only use it for bias lighting if I want the perceived blacks to be deeper when I am watching a movie with the lights off.
It works well!
boulder_bum is offline
post #131 of 141 Old 12-17-2014, 09:47 AM
Quoted: 381 Post(s)
Liked: 255
Thanks again
The LED strip itself is designed to be cut every so often. Every third light or so. I don't think it came with any connector/splices, and I'm not sure if you can purchase them.
I bought some thinking I'd need them, which I didn't. But I'm pretty sure I bought the wrong ones, as they don't look like they'd work!
post #132 of 141 Old 12-17-2014, 07:43 PM
fierce_gt's Avatar
Liked: 1570
the harmony remotes can learn IR commands, so yes. any ir controlled light can be programmed and controlled by a harmony remote.
i did this with mine, i had no idea what brand the lights i bought were, i didn't even bother to look in the database. but it came with a little card remote and about 20 different buttons. i only programmed the ones i was going to actually use though. it takes about 5-10 seconds per button to program.
post #133 of 141 Old 01-01-2015, 11:51 AM
Quoted: 18 Post(s)
Here is mine (click on image for a larger image). 75" Samsung 7150
I bought these for $24.00
I was able to flex the corners, but in retrospect, i would have bought these in addition
http://www.amazon.com/L-shape-4-cond...XAXS109S8J4E2H
It has a ir remote that I programed into my universal remote.
post #134 of 141 Old 08-04-2015, 06:59 PM
gcbavs's Avatar
How annoying is it when you have black bars.
i just realize i always have black bars... either i'm watching a movie with black bars on top/bottom, or playing old games with black bars on the sides.
gcbavs is offline
post #135 of 141 Old 08-04-2015, 07:45 PM
gcbavs's Avatar
found an example with top/bottom bars.
gcbavs is offline
post #136 of 141 Old 08-04-2015, 07:50 PM
gcbavs's Avatar
and an example with side bars (on a movie... why!?)
btw, what are the brands that have this natively? only phillips still?
gcbavs is offline
post #137 of 141 Old 12-05-2015, 07:46 PM
c1courtney's Avatar
Quoted: 34 Post(s)
The bands have nothing to do with the TV brand but w/ the aspect ratio of the Movie/Show. The first one was showing a movie in 21:9 (2.35:1) ratio while the TV is a native 16:9 TV. The second one happened to be a 21:9 TV (very uncommon) and had a 16:9 show on. Similar side bars would be seen w/ a 4:3 show on a 16:9. That said it wouldn't be that annoying w/ a standard ambient lighting, those show a dynamic ambient lighting, which I actually find annoying in and of itself, because it draws your attention away from the show and onto the light play. The major reason for ambient lighting for me is to avoid getting headaches from pupils over dilating, the backlighting of the wall fills light in the peripheral vision to prevent the over dilation.
I personally want this fixed and not changing.
Samsung PN64D550 (Home Theater Setup)
Denon AVR-3808CI - Mirage FRx Speakers
Samsung UN50H6350 (Living Room)
Yamaha HTR6130 - Polk RTi/CSi Speakers
Samsung UN32EH5000 (Master)
c1courtney is offline
post #138 of 141 Old 12-06-2015, 06:47 AM
gcbavs's Avatar
I was inquiring about which tv brands have that lightning from the factory
gcbavs is offline
post #139 of 141 Old 12-06-2015, 10:31 AM
c1courtney's Avatar
Quoted: 34 Post(s)
Wink
And I was replying to your comments about the Black Bars as that is the main focus of your discussion. And in this thread (at least for the previous years worth of posts) I don't see anything that would indicate that you were inquiring about which TV brands would have lighting from the factory.
https://www.youtube.com/watch?v=aMMxRcAzUAs
https://www.youtube.com/watch?v=P_lG9XGQvIc
post #140 of 141 Old 01-13-2016, 10:36 AM
renesis27's Avatar
I watched a few videos of Philips new AmbiLux technology, and too me at least, it seems like it would be distracting. I understand the use of light around the frame, as I almost did that with my plasma awhile back, but this seems like overkill.
It might be neat when playing certain games or having music or videos playing in the background but again, it just seemed like I was watching a rave and I can't imagine that having that on during sports or just regular viewing would be that useful. I do, however, want to see it in person to be 100% sure.
Kingram likes this.
renesis27 is offline
post #141 of 141 Old 02-07-2017, 08:47 AM
Kingram's Avatar
Quoted: 101 Post(s)
Liked: 58
I think the Philips Ambient lighting around the TV would be good for gaming and movie trailers and maybe for the start of the Movie as our eyes adjust to a dark room then fade out or dim after a few minutes.
Kingram is offline
Reply Theater Room Items & Accessories
Reviews , Accessories , Ambient
