MyPreMovie.com has launched! - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 219 Old 11-13-2011, 03:21 AM
agarr14's Avatar
Not sure if you're still working on this software? But I noticed that the loop slides until (time) is not working anymore. Hope to see an update soon really like the software.
agarr14 is offline
post #182 of 219 Old 01-03-2012, 08:41 PM
alkatmsu's Avatar
Just downloaded this for the first time today! Skimmed through the whole thread. I would definitely like to see:
1. Randomly play x number of trailers
2. Be able to pull files from subfolders (those of us that have hundreds, or thousands, of trivia slides would see the need for this!)
3. The 'play slideshow for x minutes' option would be nice, but the clock option is handy too
4. Transition options for the slideshow would be amazing (fade, slide, etc)
5. More video filetype support (.avi etc. since WMP is being used now, shouldn't any video it can play be supported?)
I also ran into the bug where it says no files are loaded unless you manually add something, then clear it back out or switch back to the folder mode. Figured it out before I found the posts on it though
Slight nitpick, when making a custom arrangement, every time the + is clicked on, the file browser resets to the root of the drive. It'd be nice if it'd remember where my stuff is so I don't have to browse every time.
Love the program so far. Items 1 and 2 being fixed would warrant a donation Thank for your time put in on this!
alkatmsu is offline
post #183 of 219 Old 01-03-2012, 11:42 PM
pokekevin's Avatar
Liked: 102
More video file support would be nice I just download trailers off of itunes and use em. Demolandia.net has some nice dts dolby intros too. I've never been able to get the end slideshow at this time feature to work :/
Great program overall though
pokekevin is offline
post #184 of 219 Old 01-07-2012, 07:27 PM - Thread Starter
SuperTal's Avatar
Thanks for the recent replies, in fact, one of my New Years Resolutions is to further enhance MyPreMovie.
I will definitely work on these issues you guys are having and add some more enhancements.
Thanks again for your encouragement!
My new site is up: http://www.MyPreMovie.com/ - the ultimate in pre-movie showing, it's a fun hobby!
SuperTal is offline
post #185 of 219 Old 01-08-2012, 07:18 PM
alkatmsu's Avatar
Awesome, thanks for the update!
alkatmsu is offline
post #186 of 219 Old 01-11-2012, 12:47 AM
sabresfan08's Avatar
I can't get the trailers to play. What format do they need to be in? They are all .mov files
sabresfan08 is offline
post #187 of 219 Old 01-16-2012, 01:23 PM - Thread Starter
SuperTal's Avatar
Yes, .mov files should play fine. MyPreMovie uses Windows Media Player 12 to play the .mov files. Do they play fine in just Media Player?
SuperTal is offline
post #188 of 219 Old 03-18-2012, 11:07 PM
pokekevin's Avatar
Liked: 102
Is there a way to change it to use MPC HC?
post #189 of 219 Old 03-19-2012, 07:18 PM - Thread Starter
SuperTal's Avatar
What do you mean? Play a different file type or call MPC HC at the end of the premovie show?
SuperTal is offline
post #190 of 219 Old 03-22-2012, 01:15 PM
pokekevin's Avatar
Liked: 102
I mean instead of using WMP12 to play the trailers is it possible to use another media player?
post #191 of 219 Old 03-23-2012, 07:00 PM - Thread Starter
SuperTal's Avatar
No, MyPreMovie is designed to run on a Windows 7 HTPC and only uses WMP12 for ease of video and audio playing since it is built into the OS.
SuperTal is offline
post #192 of 219 Old 03-23-2012, 07:05 PM - Thread Starter
SuperTal's Avatar
Here is another reason: http://mpc-hc.sourceforge.net/Vista64.html
The MPC HC you mentioned has all kinds of functions missing for 64-bit OSes. I've looked at possibly using VideoLAN, but it didn't fit nicely with .NET and I didn't have much time to work on it (it would have taken hours!)
Does WMP 12 not work properly for you?
SuperTal is offline
post #193 of 219 Old 03-26-2012, 12:45 PM
pokekevin's Avatar
Liked: 102
Ahh found it out it was the trailer. Everything else works perfect! Thanks for such a great piece of software
Time to donate!
post #194 of 219 Old 04-09-2012, 06:54 PM - Thread Starter
SuperTal's Avatar
Thank you!!!
Look forward to any and all donations!
SuperTal is offline
post #195 of 219 Old 08-04-2012, 09:54 PM
bjamm's Avatar
bjamm is offline
post #196 of 219 Old 08-05-2012, 05:16 PM - Thread Starter
SuperTal's Avatar
Sorry about that! Here is a direct link to it: MyPreMovie 1.0.
Working on a new web site and version 2.0 is finally complete! smile.gif Stay tuned!!
SuperTal is offline
post #197 of 219 Old 08-08-2012, 09:16 PM
alkatmsu's Avatar
2.0! Woo hoo! I got my HTPC set up a couple weeks ago and was playing around with 1.0, can't wait for the new smile.gif
alkatmsu is offline
post #198 of 219 Old 08-31-2012, 06:33 PM - Thread Starter
SuperTal's Avatar
Just days away! My 2 young sons (8 and 10) have been helping me with ideas. http://www.mypremovie.com/
SuperTal is offline
post #199 of 219 Old 09-12-2012, 07:30 PM
rhilyard's Avatar
Both the direct link to the file don't work. Plus the website still has the coming in Sept. I still use the old program can't wait to see this one. Thanks
rhilyard is offline
post #200 of 219 Old 09-13-2012, 07:54 PM - Thread Starter
SuperTal's Avatar
I will post here when the new site is up and version 2.0.
SuperTal is offline
post #201 of 219 Old 09-14-2012, 04:49 PM
alkatmsu's Avatar
alkatmsu is offline
post #202 of 219 Old 09-24-2012, 07:10 PM
jenielsen's Avatar
Went to download MyPreMovie and I can't find the original anywhere (google search included).
Looks like you killed even all of the old directories on your server, as I get 404 errors when I tried to find it that way (using google).
I see that the new version is set to come out soon. Looking forward to trying it out.
Any update on a timeline for release? Also, it's great to see you are involving your two sons in the process!
jenielsen is offline
post #203 of 219 Old 09-29-2012, 06:24 PM - Thread Starter
SuperTal's Avatar
Jenielsen,
Thank you, yes, my two boys love it and are so excited about!!
SuperTal is offline
post #204 of 219 Old 09-29-2012, 06:32 PM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
What does the software actually do
Holiday121 is offline
post #205 of 219 Old 09-30-2012, 07:57 AM - Thread Starter
SuperTal's Avatar
Just went live with version 2.0!!!
It's home theater software that enables you to run slide shows with optional sound in the background, play HD trailers, and then kick off a program of your choice. Give it a try! smile.gif
SuperTal is offline
post #206 of 219 Old 09-30-2012, 08:55 PM
alkatmsu's Avatar
Tried out v2.0... I'm not seeing what's changed, besides the new logo.
Still no support for "play X number of random trailers" or reading subfolders for slides
The bug where you can't play slides by folder without first making a custom arrangement remains
The "loop slides until (time)" function still doesn't work
I'm also now having an issue where the task bar remains on top of the slideshow, that didn't occur in v1.0.
I saw where the trailer selection now supports more filetypes, but the program won't see .avi files I try to point it to.
alkatmsu is offline
post #207 of 219 Old 10-01-2012, 01:19 PM - Thread Starter
SuperTal's Avatar
We'll look into these bugs. We definitely want you to be a happy panda. smile.gif
One of the main new features is the ability to open and save multiple .mypremovie files, more video file support, and an Update checker feature.
SuperTal is offline
post #208 of 219 Old 10-02-2012, 01:44 AM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Does it support full blu ray ISo playback without any loss of video or audio quality
post #209 of 219 Old 10-02-2012, 07:35 AM
alkatmsu's Avatar
The program doesn't play actual movies, only trailers. It has a part where you can have it launch your movie playing software, however, so your current software can be used.
alkatmsu is offline
post #210 of 219 Old 10-15-2012, 07:20 PM - Thread Starter
SuperTal's Avatar
Version 2.2 Released!
SuperTal is offline
Reply Theater Room Items & Accessories
