MyPreMovie.com has launched! - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 219 Old 10-17-2012, 06:10 PM
alkatmsu's Avatar
I am now having an issue where, upon exiting the slide show, the MPM window pops back up, and I can then hear the trailers playing, but they are no where to be seen. Sound during the slide show has also broken it seems, I tried folder selection and making a playlist. I have not noticed any other of the issues I have previously mentioned being fixed, if they were supposed to be (no changelog makes it difficult to test out the program).
alkatmsu is offline
post #212 of 219 Old 10-17-2012, 07:00 PM - Thread Starter
SuperTal's Avatar
Found the bug, will have a fix up by tomorrow night. I'll also put a change log on the web site, too. Good idea! Thanks!
My new site is up: http://www.MyPreMovie.com/ - the ultimate in pre-movie showing, it's a fun hobby!
SuperTal is offline
post #213 of 219 Old 10-19-2012, 06:19 PM - Thread Starter
SuperTal's Avatar
Got version 2.3 uploaded last night. It should fix your problems. Let me know.
SuperTal is offline
post #214 of 219 Old 10-20-2012, 07:56 AM
jenielsen's Avatar
Thank you for the updated version. I just downloaded and will install later.
Another two suggestions for you -
1) Put the date in the changelog for each version
2) Add the version number to the end of the file to be downloaded. Such as "MyPreMovieSetup_ver2.3.zip"
jenielsen is offline
post #215 of 219 Old 10-21-2012, 03:28 AM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Are there any invites?
zoro is offline
post #216 of 219 Old 10-22-2012, 06:06 PM - Thread Starter
SuperTal's Avatar
Zoro, what do you mean by invites? They had a site elsewhere in this forum where you could join and send out invites.
SuperTal is offline
post #217 of 219 Old 10-29-2012, 05:19 PM
agarr14's Avatar
I have downloaded the latest update, but I still can't get the loop slides until work. I set the time for the slide show to end and for the trailers to start but the slides keep playing. Also I was wondering if you could add an option where we could select a folder for the trailers and select how many trailers to play from that folder. That way we could always have random trailers being played without adding and removing files
Adam
agarr14 is offline
post #218 of 219 Old 11-04-2012, 09:32 AM
agarr14's Avatar
I wanted to use this last night, but it would not play on the projector. It would only play on display 1 and gave no option to play display 2. Even when I put the program on display 2 when I selected to play the pre show it switched back to display 1.
agarr14 is offline
post #219 of 219 Old 11-26-2012, 11:39 PM
SD Vidiot's Avatar
Tal,
Thanks for your great program! A couple of issues:
1) when trying to add trailers, the program recognizes .mov files but does not recognize .wmv files (yes, I used the dropdown menu)
2)when I choose the option "Close mpm show at the end of show" , the program shows the desk top for a second or two between the last trailer and the launch of my player. However, when I choose the "Leave mpm show open" option, the program freezes on the "feature" slide and does not advance to the movie.
I'm using v2.3 on my Win7 32bit
Thanks for your help!
HB
Bear's Lair Home Theater
Howie: "I think my screen may be TOO big."
Norm: "Screens are like breast implants..."
SD Vidiot is offline
Reply Theater Room Items & Accessories
