Need parts for electric recliners - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-06-2008, 08:42 PM - Thread Starter
Maveri9720's Avatar
Hi all. Kind of a weird request here. I just bought an electric 6 piece recliner sectional from Haverty's last week. The outer recliners have switches built into the outside of the recliner, while the 2 inner recliners have wired remotes to control reclining position. I would like to find switches similar to what the outer recliners have, so I can install them into the adjoining consoles of the inner recliners and eliminate the need for the wired remote.
It's just a simple 2 position switch, but it has a nice slide lock cover plate, that hides the screws and makes it look nice. I was wondering if anyone knows of any places that have parts like this that you can order. I have surfed for awhile and haven't come across anything.
Worse case, I can try to call Haverty's warehouse and see if I can buy a couple switches from them.
Can anyone help me out?
Maveri9720 is offline
post #2 of 5 Old 02-07-2008, 04:19 AM
Dark_Wizard's Avatar
My wife and I have just recently purchased a lot of furniture from Haverty's and although it is nice furniture they do not make their own. I would suggest contacting the manufacturer of the seats rather than talking to Haverty's warehouse personnel.
Dark_Wizard is offline
post #3 of 5 Old 02-07-2008, 06:04 AM - Thread Starter
Maveri9720's Avatar
That's the problem. I can't find any ID anywhere on the sectional that identifies who the original manufacturer is. Maybe I can get that info from Haverty's warehouse.
post #4 of 5 Old 02-07-2008, 06:18 AM
Can the salesperson you dealt with help you?
post #5 of 5 Old 02-09-2008, 08:13 PM
StockSux's Avatar
Furniture manufacturers are typically not in the switch building business and they are most likely an "off the shelf" part. There is a chance it's a custom spec switch, but probably not.
I would take one switch out and see if there is a manufacture stamped on it. Start there, you may be able to find them somewhere like Grainger.
StockSux
Hook'em Horns \m/
StockSux is offline
Reply Theater Room Items & Accessories
