'Seinfeld' in HD on TBS HD! - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 07-03-2009, 01:56 AM
Kram Sacul's Avatar
If the BDs are cropped a lot of people are going to be disappointed.
Kram Sacul is offline
Old 07-03-2009, 07:34 AM
dcowboy7's Avatar
Quoted: 262 Post(s)
Liked: 302
& if the BDs are only 4x3 alot of people are going to be disappointed.
Maybe they should do a 16x9 box set & a 4x3 box set....kinda like they did the old "fullscreen" & "widescreen" versions for a dvd.
dcowboy7 is offline
Old 07-03-2009, 05:26 PM
Cosmos2's Avatar
The cropped widescreen is unacceptable. For example, there's a scene where George rolls up his sleeve to show his arm, and you can't see his arm in the widescreen version. That kind of stuff drives me nuts.
The DVDs are good enough for me. The jokes aren't funnier in HD.
Cosmos2 is offline
Old 07-04-2009, 01:37 AM
videojanitor's Avatar
Originally Posted by MattGuyOR View Post
I think they look great, and since there is extra info on the sides, the cropping isn't that bad at all.
I was watching an episode tonight ("The Pez Dispenser") on side-by-side monitors -- one with the 4:3 SD version, and with the 16:9 HD version. If there's anything "extra" on the sides of the 16:9 version, it's negligible at best. On a 42-inch screen, maybe a half-inch. On the other hand, the amount cropped from the top and bottom was humongous.
videojanitor is offline
Old 07-04-2009, 05:44 PM
scowl's Avatar
Quoted: 122 Post(s)
Liked: 39
But you can see actors' reactions better in the cropped version.
One episode that was awkward was "The Raincoats". When George's friend was convincing him to sign up for the big brother program, they couldn't fit his friend and the kid's face on the screen at the same time when they were standing. This is rare though.
It's funny how many shots are out of focus. Since they originally edited these episodes on tape, they couldn't tell how sharp the original footage was.
NOW: my post on AVS Forum.
NEXT: someone else's post on AVS Forum.
scowl is offline
Old 08-22-2009, 01:03 AM
MattGuyOR's Avatar
Is it possible they are extracting episodes from the new widescreen versions? I flip back and forth between channels and the widescreen version has A LOT more information on both sides and isn't cropped at all on the top and bottom. The cropped versions look pretty bad. I watched two episodes tonight and they were both like that.
MattGuyOR is offline
Old 08-22-2009, 02:31 AM
igreg's Avatar
Quoted: 265 Post(s)
Liked: 47
How would you compare the Seinfeld HD braodcasts with those for Hogans' Heroes (not quite 16:9); Charlie's Angels; Becker et al? I am impressed with the Hogans' Heroes HD broadcasts on HDNET.
igreg is offline
Old 08-22-2009, 10:46 AM
scowl's Avatar
Quoted: 122 Post(s)
Liked: 39
Was it possible to zoom into the frame when they edited the original 4:3 broadcast versions if they didn't think the original framing was good enough? If all this stuff was edited on tape originally, I don't see how they could do that without making a blurry mess unless they were able to specify framing changes when it was transferred to tape.
scowl is offline
Old 08-22-2009, 01:51 PM
I was present at some of the telecine sessions for the original versions, and I can tell you that there was no zooming taking place. The telecine op sized the frame so that the entire 4:3 area was filled (the aspect of a 35mm film frame is not quite 4:3), which does result in a little bit of cropping on the sides. But not much. I'm not sure about the claims (made by others) that they are seeing "a lot" more information on the sides -- there will be a little to sure, because for the HD transfers they would frame the sides first in order to minimize the amount of cropping necessary from the top and bottom.
Old 08-22-2009, 01:54 PM
Were these the episodes that aired on Friday? If so, we should still have them in our servers -- I will take a look and see. Do you remember the names or the plots of these episodes? Just want to make sure we're looking at the same thing.
Old 08-22-2009, 05:10 PM
foxeng's Avatar
Quoted: 165 Post(s)
Liked: 66
Air date 8/21/2009
1st run - SEIN409 - The Opera
2nd run - SEIN717 - The Cadillac Pt2
We haven't done a one on one comparison yet, but from what I have seen off the bird on the HD feed, there is definitely picture content not on the 4:3 version and it doesn't looked cropped. Several of us in the shop looked at it and we all think if it wasn't shot in 16:9, it is VERY close because we looked at it through a AJA-FS1 and used the crop mode on it and when cropped, it looked very close to the 4:3. How it is being done, I don't know.
EDIT: By the way, you guys using the TOP Server?
All opinions expressed (unless otherwise noted) are the posters and NOT the posters employers. The poster in NO WAY is/will speak for his employers. "Arguing with an engineer is like mud wrestling with a pig. After a couple of hours, you realize the pig likes it"
foxeng is offline
Old 08-22-2009, 05:56 PM
Well, I can't explain what you are seeing. I am looking at the SD and HD versions of "The Opera" right now, and it is just as I would expect -- the side information on both versions is almost identical, but the HD version is heavily cropped at the top and bottom. Why you are seeing something different escapes me.
You can trust me when I tell you the show was not shot for, or with any intention of 16:9 -- it was 4-perf 35mm. I was there and looked directly at the negative that came out of the camera. And this was in several different seasons, one of which included this episode.
I will try to get some image captures from these clips, though I'm not sure right off hand how I will get one from the HD server. TOPS? No ... but I hear it is coming ...
Old 08-22-2009, 09:38 PM
Well, this is the best I can do on short notice. Here are two images taken off the screen (from "The Opera") using my MacBook's built-in camera. How much more image does anyone see on the sides of the 4x3 image vs the 16x9? I would call that negligible. In fact, the 4x3 is showing a tiny bit more on the left, but that could be because the monitor is overscanning when displaying 16x9. On the other hand, there is a TON missing from the bottom on the 16x9. Note that they did not just "center cut" the crop -- they are favoring the top of the frame to keeps the heads from being chopped off.
If people are seeing something different from this, I have no explanation.
Old 08-23-2009, 07:18 AM
foxeng's Avatar
Quoted: 165 Post(s)
Liked: 66
Ours is on the way. Expected any day.
foxeng is offline
Old 08-29-2009, 11:44 AM
scowl's Avatar
Quoted: 122 Post(s)
Liked: 39
I did some comparisons too and I certainly do not see "a lot" of new frame on the sides. Perhaps MattGuyOR is watching the SD versions on a heavily overscanned television.
scowl is offline
Old 01-14-2010, 07:04 AM
machpost's Avatar
Originally Posted by lobosrul View Post
3) Theres plenty of old TV shows that were made on 35mm film that could look good on Bluray. And I do think theres a market for it. An entire season of a 24 episode sitcom should be able to fit comfortably in 1 BD-50 @ 720p quality (and I think for a lot of old shows 720p is adequate). Off the top of my head, I'd like to see: Friends, Seinfeld, MASH, Twin Peaks, Northern Exposure, Hill Street Blues, and Magnum PI.
A few of them might be suitable for 16x9 but most should be framed for 4x3 or maybe the compromise ratio of 14x9. Just depends on how they were framed.
FWIW, Crime & Investigation HD has been airing Twin Peaks in 4:3 HD for some time now. It looks great.
machpost is offline
Old 06-04-2010, 07:00 PM
Ken H's Avatar
From TV Week
No Joke: The Amount of Money 'Seinfeld' has Really Made in Syndication
Though the hit sitcom "Seinfeld" is distributed by Sony Pictures Television, the show is owned by Time Warner subsidiary Castle Rock. And at an investor's conference in New York last week, on Thursday,May 27, Time Warner revealed how much the show has already made in syndication.
According to a report about the conference in The Hollywood Reporter, the hit sitcom "made $598 million in off-network first cycle revenue, $984 million in the off-network second cycle and $703 million in the third. The cable first cycle brought in $180 million, followed by $113 million in the second and $86 million in the third. That made for a total of $2.67 billion revenue for the eight seasons and 180 episodes of the show, including $2.07 billion after the first cycle (or 346% of the first cycle.)"
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Old 06-05-2010, 10:14 AM
Vlad Theimpaler's Avatar
Liked: 33
Not that there's anything wrong with that!
Vlad Theimpaler is offline
Old 06-05-2010, 12:37 PM
foxeng's Avatar
Quoted: 165 Post(s)
Liked: 66
And you wonder why Jerry Seinfeld is so rich?
foxeng is offline
Old 06-15-2010, 08:48 PM
halsnook's Avatar
Not sure if anyone is reading this old thread, but I think I've figured out what's happening, and it's one of the many grim side effects of the transition from 4:3 to 16:9.
For their SD feeds, some cable and satellite systems are simply center cutting their HD feeds. Most stuff these days is produced 4:3 safe for this reason. But when it comes to Seinfeld, which has already been cropped top and bottom, you're getting an extremely zoomed-in picture (only 56% of the original picture, if I'm doing my math correctly!). I recently witnessed this first-hand on KTXL on Comcast in Roseville, CA. Also on the DirecTV feed on JetBlue. It's as horrific as it sounds.
halsnook is offline
Old 07-23-2012, 05:28 PM
ak3883's Avatar
Anyone notice that TBS seems to be playing with playback speed on tonight's Seinfeld episode? It looked "sped up", the voices did not sound right. I've seen Nickelodeon do this for old shows on Nick at Nite, obviously speeding up the playback to fit another 2 minutes of commercials to make more $$$ at the expense of ruining the show. Can't stand it!
ak3883 is offline
Old 07-25-2012, 12:17 AM
charlie460's Avatar
I sure hope not. Crap like that is a total disgrace.
charlie460 is offline
Old 11-04-2013, 04:27 PM
Doctor's Avatar
I saw the Seinfeld pilot episode on TBS today. Some scenes looked like HD while others were quite blurry looking. What gives?
Doctor is offline
Old 11-04-2013, 05:13 PM
They couldn't find the original film for some of the scenes, so they inserted unconverted video from the 1-inch (composite NTSC analog) video masters. It IS quite jarring to have that mixed in there, but it was either that or nothing.
Old 11-04-2013, 05:32 PM
Doctor's Avatar
Was that just a problem for the Pilot or did it occur in a lot of other episodes?
Doctor is offline
Old 11-04-2013, 06:19 PM
The pilot had the most instances of this -- there may have been a few occurrences in the next couple of episodes, but after that, you won't see it again.
Old 03-04-2015, 02:38 PM
Young C's Avatar
Quoted: 424 Post(s)
Liked: 324
Seinfeld actor Daniel von Bargen dies at 64
by Ariana Bacle | Wednesday, March 4 2015 | ew.com
Daniel von Bargen, known for his roles on Seinfeld and Malcolm in the Middle, has died. He was 64.
Von Bargen made his Seinfeld debut in 1997 as George’s boss, Mr. Kruger - whom George photobombed before they even started working together. He went on to have guest roles on shows including The X-Files, Party of Five, and The Practice before appearing in multiple episodes of Malcolm in the Middle as Commandant Edwin Spangler. He most recently appeared in 2009 comedy London Betty.
http://www.ew.com/article/2015/03/04...bargen-dies-64
Young C is offline
Old 04-29-2015, 12:18 AM
dad1153's Avatar
Quoted: 1810 Post(s)
Liked: 1127
Send a message via Yahoo to dad1153
From the "Hot Off The Press" Thread (top of 'HDTV Programming' page).
Streaming/TV Notes
‘Seinfeld’ Heads To Hulu With SVOD Deal
By Nellie Andreeva, Deadline.com - Apr. 27, 2015
When Seinfeld ended its run on NBC in May 1998, people were still using dial-up connection to go online, Netflix was planning to launch as a DVD rental business, Amazon was an online book store, and Hulu was a decade from being born.
Now the classic sitcom from Jerry Seinfeld and Larry David is heading to online streaming for the first time through a rich SVOD deal with Hulu. Under the pact between the streaming service and Sony Pictures TV, all nine seasons and 180 episodes of Seinfeld will be available on Hulu as its exclusive SVOD provider.
Financial terms of the deal are not being disclosed, but word is that the license fee fetched by Seinfeld is north of $700,000 per episode for a total in the neighborhood of $130 million. I hear that is higher than — as much as double — the per-episode price the show’s Must See TV companion Friends landed from Netflix.
Hulu landed Seinfeld in a bidding that involved multiple streaming platforms. The pact follows years of planning on part of Sony TV, which took a strategic approach and held back on selling Seinfeld online while the show was flying high in off-network syndication. Seinfeld is among the biggest off-network hits of all time, still bringing in tens of millions a year, now in its fifth syndication cycle.
Hulu and Sony TV declined comment.
http://deadline.com/2015/04/seinfeld...al-1201417827/
dad1153 is offline
Old 05-28-2015, 08:57 PM
cpalmer2k's Avatar
Quoted: 215 Post(s)
Liked: 25
Has the "The Puerto Rican Day" been banned from airing again? I've been archiving the Seinfeld episodes in HD from our local station and TBS and both are about to finish their runs of Season 9. The locals skipped this episode entirely, and it appears based on guide data that TBS is going to skip it too (unless it airs after the Finale, which wouldn't make much sense)
I thought it had gone back into circulation?
cpalmer2k is online now
Old 06-04-2015, 12:29 PM
Young C's Avatar
Quoted: 424 Post(s)
Liked: 324
Jason Alexander reveals why Susan was killed off on 'Seinfeld': 'It was such a disaster'
By Chris Eggertsen | Wednesday, June 03, 2015 | hitfix.com
George Costanza's fiancee Susan was unceremoniously killed off at the end of Season 7 by licking too much low-quality glue, and rumors later swirled that she met her demise because Jason Alexander couldn't stand working with Heidi Swedberg, the actress who played her. On today's episode of "The Howard Stern Show," Jason Alexander set the record straight by explaining that, while he loved Swedberg on a personal level, their on-set chemistry was "a disaster."
"I love her. She's a terrific girl. I love her. I couldn't figure out how to play off of her. Her instincts for doing a scene, where the comedy was, and mine, were always misfiring. And she would do something and I would go, okay, I see what she's gonna do, I'm gonna adjust to her. And then I would adjust. And then it would change!
"So I had done three episodes with her and Larry calls me up at the beginning of the season and says, 'Good news! I got a great arc for you this season. You're gonna get engaged!' I said, 'oh it's great, who do I get engaged to?' He said, 'Susan.' And I went, 'oh great, who's playing George?' Cause it was such a disaster.
What Heidi brought to the character is we could do the most horrible things to her, and the audience was still n my side. ...She wasn't playing a bitchy character or anything, but they knew it wasn't a good fit. ...I kept saying, 'I'm going out of my mind you guys, you're killing me. I can't understand how to play off of this girl. I'm sure that the stuff is not working, it can't be!'...I was the only actor doing scenes with her! And then finally -- they didn't know how the season was gonna end, was George gonna marry her? Was she gonna leave him? What was gonna happen? So finally they do an episode where Elaine and Jerry have a lot of material with her. They do the week...and they go, you know what? It's ****ing impossible. It's impossible.' And Julia actually said, 'I know, it's just, don't you wanna just kill her?' And Larry went, 'kebang!'
"But she is...Heidi is the sweetest...it was just the way I come at stuff and the way she came at stuff is just..."
Okay, I have to admit: this is a great, juicy tidbit and the kind Stern is known for making his interview subjects comfortable enough to spill. But at the same time, you have to feel for Swedberg here; it seems in bad taste to slam an actor who's so much lower on the totem pole -- particularly if she is, as Alexander claims, a good person. The way he constantly refers to her as a "girl" is a little cringe-y too. Personally I thought she did a fine job in that role. Read more at
http://www.hitfix.com/the-dartboard/...4dBMuuPxvRv.99
Young C is offline
