So, which NFL telecaster actually gives the screen to the viewer? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 73 Old 09-14-2009, 03:32 PM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
RULE #1 should be an absolute "no-brainer" whether you are a football fan, fantasy nerd, or the producer/director of the presentation:
NEVER blackout or mask part of the presentation.
The blacked out portion not only eliminates part of your primary product, it also cannot relay any other information. Therefore, it serves absolutely no purpose whatsoever.
If you find yourself in the position that you've taken the historically unprecedented step of masking off part of your programming to address overscan - your graphics have evolved to the unacceptable point that they have "painted you into a corner" and it's time to start over with a different format.
There is no defensible position to justify violating this rule.
CPanther95 is offline
post #62 of 73 Old 09-14-2009, 04:34 PM
URFloorMatt's Avatar
URFloorMatt is offline
post #63 of 73 Old 09-14-2009, 04:40 PM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Originally Posted by URFloorMatt View Post
It looks like ESPN just jumped into second place.
Agreed.
post #64 of 73 Old 09-14-2009, 04:55 PM
Gandu's Avatar
Quoted: 72 Post(s)
Liked: 92
Hopefully the start of a trend. I can actually see the game. Old unis look good too.
Gandu is offline
post #65 of 73 Old 09-14-2009, 05:02 PM - Thread Starter
jpr281's Avatar
Does anyone have a 1920x1080 screencap from any of this weekend's CBS games, with the new "Eye Bar" score bug?
jpr281 is offline
post #66 of 73 Old 09-14-2009, 05:19 PM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Check "NFL on CBS" on Wikipedia for all of them.
post #67 of 73 Old 09-14-2009, 07:20 PM - Thread Starter
jpr281's Avatar
That only has downsized 4:3 versions.
jpr281 is offline
post #68 of 73 Old 09-14-2009, 07:59 PM
mx6bfast's Avatar
I'll try to get a capture of it Sunday. Send me a pm to remind me.
Grit N Grind
Glory Glory Man United
Go Cubs Go
mx6bfast is offline
post #69 of 73 Old 09-14-2009, 09:45 PM
dcowboy7's Avatar
Quoted: 302 Post(s)
Liked: 350
wow thats a bad shot...oh well.
dcowboy7 is offline
post #70 of 73 Old 09-15-2009, 05:10 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
CBS and FOX are now a tossup IMO. Not sure what's worse - eliminating a significant portion of the top, or having a top and bottom bar that makes you feel like you're watching the game while looking through the slats of a closet door.
post #71 of 73 Old 09-15-2009, 08:00 AM
mx6bfast's Avatar
Both. It's almost like what's in the middle doesn't count.
Grit N Grind
Go Cubs Go
mx6bfast is offline
post #72 of 73 Old 09-15-2009, 05:23 PM
ldivinag's Avatar
safe zone... safe zone...
repeat that after me.
safe zones were important back in the old SD says... actually old CRT tv days.
these days, i think what the camera operator sees on his 16x9 view finder is what we see on our HD sets...
that's why those dang lattice shows up on NBC...
sigh...
leo d.
ldivinag is offline
post #73 of 73 Old 09-16-2009, 02:00 AM
NIVO's Avatar
something i would enjoy tremendously is that when the ball is hiked( or any play is "live" for that matter) that all/any overlays fade out. They are already active as it is and being constantly changed for down, yards etc etc. So why cant they just fade out or turn off as the ball is hiked. I dont beleive it would be a big deal as its monitored anyways. They could learn a lesson from some NHL score overlays as they have improved the last 2 years as well.
NIVO is offline
Reply HDTV Programming
