ION Television in HDTV - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 185 Old 04-26-2010, 09:22 PM
Buckeye911's Avatar
Originally Posted by mikepier View Post
I think you're right. I think it would be a letterboxed on a 4:3 TV ( bars on top and bottom). Then from the menu on the converter box you can zoom in to whatever you like.
I don't know what I was thinking, I got confused.
OK, I checked it tonight. We have 4:3 SDTVs here at work with analog cable connected direct to the TVs. The broadcast appeared normally on the TV with an undistorted picture filling the entire screen without any black bars. I don't know if the same would be true with an OTA source or not.
The measure of a man's character is what he would do if he knew he never would be found out.
Buckeye911 is offline
post #182 of 185 Old 04-27-2010, 12:30 PM
jmoz2989's Avatar
WQPX is now broadcasting ION TV in HD. The cable company I am connected to is passing the HD signal through. The Motorola box claims that the video signal is 720p at 60fps. There are only infomercials on now, will have to check Criminal Minds tonight for improvement.
DVR: Totally worth the monthly fee to get 15 minutes +/- of a busy life back!
Quality, not quantity!
jmoz2989 is offline
post #183 of 185 Old 04-30-2010, 04:34 PM
rezzy's Avatar
Quoted: 991 Post(s)
Liked: 748
Tango and Cash is in OAR right now; and it looks nice!
"I knew you'd say that"...*BLAM!*
rezzy is offline
post #184 of 185 Old 04-30-2010, 11:42 PM
Rammitinski's Avatar
At least as long as nothing moved too fast.
Rammitinski is offline
post #185 of 185 Old 09-12-2013, 05:34 AM
mgsports's Avatar
life and Qubo HD in the future. ISHOP and QVC what's next? Comcast Olathe looks like it has Life.
mgsports is offline
Reply HDTV Programming
