Turner Classic Movies (TCM) in HDTV! - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 27Likes
post #991 of 1952 Old 04-03-2011, 09:25 PM
Joseph Dubin's Avatar
Quoted: 62 Post(s)
Liked: 44
There have been many black and whites aired over the past few months by TCM which definitely appeared sharper with more contrast and richer blacks than before. I know because I re-dubbed some of them onto DVD-R and even though it's down-converted to 480i, the newer recording were much better than the older ones off of standard definition. Titles included "The Great Zigfield" and "Birth Of A Nation".
These might not be 1080i transfers but if they are good prints, transmitting them in 1080i is a big improvement over 480i. Even the color ones ("Golden Voyage of Sinbad" and "Sinbad And The Eye Of The Tiger" looked better. However, if the prints are bad, they looked better off masked by 480i resolution (for example, "Light In The Piazza" was worse than the original recording I made off of 480i).
Joseph Dubin is offline
post #992 of 1952 Old 04-04-2011, 05:43 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
I'm still hoping that Directv will include TCM in it's next batch of HD. After this year there will be a two year gap before the next satellite goes up so no channels will be added.
joed32 is offline
post #993 of 1952 Old 04-04-2011, 10:36 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Originally Posted by Joseph Dubin View Post
Maybe there was a problem since I tried only on the first of the month.
Fortunately, I was able to review the complete June schedule by going into daily calendar - not as convenient as the old monthly list (one also needs to click in order to get the information) but better than nothing at all.
However, still note that when one searches for a movie title, there is no indication about the next scheduled airing, like before - only how to purchase the DVD if available.
How are you getting the complete June schedule? I can go to daily and select May 31 and then hit weekly which only gets me to June 6. What am I doing wrong?
joed32 is offline
post #994 of 1952 Old 04-04-2011, 10:41 AM
Quoted: 62 Post(s)
Liked: 44
Did it with the daily schedule - meant a lot more clicking.
post #995 of 1952 Old 04-04-2011, 03:10 PM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Thank you, I got it. Bookmarked June 1st so I don't have to do that again.
joed32 is offline
post #996 of 1952 Old 04-04-2011, 09:04 PM
kjbawc's Avatar
Originally Posted by cinema13 View Post
FIOS doesn't carry the faux TCM-HD either. What would be the point? .
Of course we all wish TCMHD was true HD, but the current TCMHD is a vast improvement over TCM SD for WS films. You no longer have to zoom to fill the screen, and the picture is much sharper. At its best, it is as sharp as a good anamorphic DVD, and that's way better than any SD. Also, I can now make anamorphic DVDs from TCMHD.
As to films I'd like TCM to show, I vote for the little-known 1961 British film Johnny Nobody. Of course there are scads of others I'd like to see on TCM, but that one seems the least likely to pop up.
kjbawc is offline
post #997 of 1952 Old 04-04-2011, 09:21 PM
jjeff's Avatar
Quoted: 687 Post(s)
Liked: 245
I don't get TCMHD but even if the content isn't HD it should sure look better than the same content on a 480i SD channel. Like kjbawc said the HD channel will be true 16:9 vs letterbox 16:9 on the SD channel. Sure it would be nice if TCMHD actually showed HD prints but I for one would be happier to at least get a HD carrier
For us recorders even though DVD is 480i that doesn't mean a recording done from a 480i SD channel will look the same as a recording done from a HD channel, HD is noticeably better
jjeff is offline
post #998 of 1952 Old 04-04-2011, 10:11 PM
Quoted: 62 Post(s)
Liked: 44
How do you make anamorphic DVDs from TCMHD? Do you use a RAM or computer software? I use a Panasonic DVD recorder. Since playback is up-converted via HDMI, the recorder is set to display all non-anamorphic DVDs stretched to to fit a 16:9 screen. If the source is widescreen, I use my set's vertical expand to fill the screen properly; if it's 4x3, the DVD recorder's zoom is then also utilized (better than the set's zoom mode).
post #999 of 1952 Old 04-04-2011, 10:13 PM
kjbawc's Avatar
I use a component to S-Video converter, and feed it to my DVDRs' HDDs, edit, and then burn to disc. The WS flag is not set, so they wouldn't play properly on a 4x3 set, but that doesn't bother me.
kjbawc is offline
post #1000 of 1952 Old 04-05-2011, 06:20 AM
jjeff's Avatar
Quoted: 687 Post(s)
Liked: 245
What kjbawc said and at the risk of getting to OT I also use Panasonic DVDRs(kjbawc uses Pioneers) and the key is you need a anamorphic source, something Comcast and most cable companies refuse to give us from their SD outputs (although most satellite STB/DVRs do allow). The trick is to get a component to S-video converter to convert the WS HD to WS SD for use in our DVDRs. They start at <$50 but for the higher quality units >$200 seems to be the starting point. For info on such devices check out this thread. For any follow up questions please use that thread
As kjbawc said most DVDRs don't set the WS bit so the anamorphic DVDs won't play properly on a 4:3 TV but my international Panasonic DVDR (EH-59) sets the bit and has a 250 GB HDD, I paid $250 for a like new floor model.
jjeff is offline
post #1001 of 1952 Old 04-05-2011, 07:54 AM
Quoted: 62 Post(s)
Liked: 44
Thanks guys for explaining it.
I do use the S-video ouput from my cable box into the recorder.
BTW - regarding TCMHD picture quality, last night's airing of "Raintree County" was vastly superior to those of the past. Maybe not quite HD quality but again, a vast improvement and definately sharper and more colorful than anything one could get on standard defintion.
post #1002 of 1952 Old 04-06-2011, 02:23 PM
dneily's Avatar
FIOS doesn't carry the faux TCM-HD either. What would be the point? Fortunately, channels like HDNet Movies, MGM-HD and Showtime DO show classic films in HD. I've seen HIGH NOON, THE MISFITS. Truffaut's BRIDE WORE BLACK, EDGE OF THE CITY, SON OF FRANKENSTEIN, FREAKS, etc. etc. etc. in HD on those channels. And services such as VuDu have even more! So TCM has absolutely NO excuse.
I'm loving the new Hulu Plus additions ... many classics ... U.S. and foreign ... in 720p .... so I no longer pine for HD on TCM-HD.
dneily is offline
post #1003 of 1952 Old 04-13-2011, 04:25 PM
Solfan's Avatar
Quoted: 14 Post(s)
Liked: 32
Originally Posted by Tybee View Post
Incidentally, I know TCM's head of programming, so if you have any requests.
Crawlspace
http://www.imdb.com/title/tt0066954/
The Reflecting Skin
http://www.imdb.com/title/tt0100469/
Solfan is offline
post #1004 of 1952 Old 05-05-2011, 11:38 AM
Quoted: 62 Post(s)
Liked: 44
If anybody is still reading this thread, one can now get the daily schedule through August 31 (three months later) on the TCM website (instead of the monthly schedule for two months later).
post #1005 of 1952 Old 05-06-2011, 05:53 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Excellent, thanks!
joed32 is offline
post #1006 of 1952 Old 05-06-2011, 02:17 PM
mikey mo's Avatar
That is the great mystery. I resubscribed to E* just to get AMC, BBCA, and TCM in HD.
Mikey Mo
"Survived Charley, Frances & Ivan. But Jeanne got me."
Anxiously Awaiting 2014 Hurricane Season.
"OAR OR DIE"
They killed the SACD. Bring it back.
mikey mo is offline
post #1007 of 1952 Old 05-06-2011, 02:29 PM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
I'm too big an NFL fan to leave.
joed32 is offline
post #1008 of 1952 Old 05-07-2011, 12:57 AM
mikey mo's Avatar
I am too. That's the insane reason I have both services.
Mikey Mo
"OAR OR DIE"
mikey mo is offline
post #1009 of 1952 Old 05-07-2011, 07:54 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Best of both worlds!
joed32 is offline
post #1010 of 1952 Old 05-24-2011, 06:38 PM
Shaded Dogfood's Avatar
Quoted: 118 Post(s)
Liked: 83
The Black Stallion tonight reaaaly looks like actual HD.
CW Hinkle
Shaded Dogfood is offline
post #1011 of 1952 Old 05-24-2011, 10:46 PM
bruin95's Avatar
Quoted: 28 Post(s)
But, alas, it's not. Honestly, I'm starting to think that TCM feels that the PQ on the "HD" channel is good enough and that we may never see actual HD on the channel. Saves them a boat load of money.
bruin95 is offline
post #1012 of 1952 Old 05-25-2011, 01:30 AM
mikey mo's Avatar
Agree. But it's still the best channel on TV.
Mikey Mo
"OAR OR DIE"
mikey mo is offline
post #1013 of 1952 Old 05-25-2011, 04:33 AM
Solfan's Avatar
Quoted: 14 Post(s)
Liked: 32
What the hell is E*?
Solfan is offline
post #1014 of 1952 Old 05-25-2011, 06:07 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Dish Network. It used to be EchoStar, that's where the "E" comes from.
joed32 is offline
post #1015 of 1952 Old 05-26-2011, 04:16 AM
bruin95's Avatar
Quoted: 28 Post(s)
Two abbreviations you may want to familiarize yourself with on these, and other tech boards:
E*= Dish Network
D*= Directv
bruin95 is offline
post #1016 of 1952 Old 05-26-2011, 04:49 AM
Solfan's Avatar
Quoted: 14 Post(s)
Liked: 32
No, the "D*" convention always was and still is stupid.
Solfan is offline
post #1017 of 1952 Old 05-26-2011, 09:57 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
Welcome to the internet.
JDLIVE is offline
post #1018 of 1952 Old 05-26-2011, 12:14 PM
Rammitinski's Avatar
E*= Dish Network
D*= Directv
Also, to differentiate between Direct and OTA (or just digital TV in general), there's "DTV" (digital television), which people often erroneously use here as an abbreviation for Direct.
Rammitinski is offline
post #1019 of 1952 Old 05-26-2011, 03:01 PM
mikey mo's Avatar
There's some backstory on using D* for DirecTv. I don't remember the complete story, but as I recall there was a guy named Dave who worked for D* the experience with which one poster had that was comical. So we started rerferring to DirecTv as "Dave" which was shortened to D*.
Some traditions never die.
Mikey Mo
"OAR OR DIE"
mikey mo is offline
post #1020 of 1952 Old 05-26-2011, 06:04 PM
Solfan's Avatar
Quoted: 14 Post(s)
Liked: 32
Great, that's my name.
Solfan is offline
Reply HDTV Programming
