"Touch" on FOX HD - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Old 01-30-2012, 11:39 PM
mrvideo's Avatar
Quoted: 588 Post(s)
Liked: 329
Originally Posted by VisionOn View Post
Well except for that Iraqi kid, who most likely was executed shortly after that oven (which mysteriously appeared in his home) was installed for failing to carry out his assignment and being able to identify the terrorists. It's just lucky the militants didn't wire the bomb in the usual way otherwise he would have been dead as soon as the phone rang, when he removed the battery or have been manually triggered by an observer who was making sure he didn't chicken out of detonation. You know, typical operating procedure for terrorists.
I'd have to go back and check my copy, but didn't the phone have a headphone cable plugged into it, so that the audio from the phone could be used to trigger the bomb? If so, there was no way the kid was going to talk to the caller. Plus, all the kid had to do was unplug the headphone cable and the bomb was disabled. There are no electronic switch contacts available on a phone. No headphone connection, no boom!
Ya, big plot hole with that scene.
"You're Sherlock Holmes, wear the damn hat!" - Watson to Sherlock
Sherlock - The Abominable Bride - 1/01/16
Mr. Video
My Geek Images
mrvideo is offline
Old 01-31-2012, 12:33 PM
MacAlert's Avatar
He pulled the battery from the phone to disable the bomb.
That whole segment was just wrong though.
MacAlert is offline
Old 03-03-2012, 01:52 AM
vfxproducer's Avatar
Quoted: 186 Post(s)
Liked: 295
For those who are interested, FOX decided to air this show on Thursday nights instead of Monday to avoid competing with 'The Voice'. The next episode will air on March 22.
vfxproducer is online now
Old 03-06-2012, 08:31 PM
73shark's Avatar
Quoted: 366 Post(s)
Liked: 176
Originally Posted by Whitearrow View Post
Because Fox only schedules two hours of primetime most nights, and in the spring a significant percentage of that time is sucked up by the black hole known as American Idol. Touch will start once Alcatraz wraps its 13 episodes, and run through the end of the season in May.
There's also the NCAA tourney to contend with.
Preview episode will be repeated Mar 15 at 2000 CDT
In space, no one can hear you scream . . .
73shark is offline
Old 03-09-2012, 09:52 AM
mreedelp's Avatar
Quoted: 98 Post(s)
Liked: 77
TV listings are showing the repeat of the pilot at 60 minutes, not the extended version. Hope the listings are wrong, because I missed the end of the first showing due to the listings being wrong then, too.
Will program my recorder for extra time just in case this time.
mreedelp is online now
Old 03-09-2012, 10:00 AM
mrvideo's Avatar
Quoted: 588 Post(s)
Liked: 329
It is only in a 60 min timeslot.
Mr. Video
My Geek Images
mrvideo is offline
Old 03-09-2012, 10:03 AM
Marcus Carr's Avatar
Quoted: 54 Post(s)
Liked: 99
It was 60 minutes in my Comcast guide the last time but ran over.
YOU ARE READING AVS FORUM
Marcus Carr is offline
Old 03-09-2012, 10:09 AM
mrvideo's Avatar
Quoted: 588 Post(s)
Liked: 329
That may be, but the FoxFlash (Fox official press website) had the correct info for the first time around. Can't help it if whatever service Comcast uses can't get it right.
The schedule listing on FoxFlash only has it for an hour. Most special airings that are longer than normal usually never get a replay at the longer length.
Mr. Video
My Geek Images
mrvideo is offline
Old 03-09-2012, 10:52 AM
Quoted: 54 Post(s)
Liked: 99
Don't really care since I added extra time and saw the whole thing.
Old 03-09-2012, 11:34 AM
R11
R11's Avatar
Liked: 69
So what do they do then, just cut the show off while it's still going? Looks like the running time of the pilot is 51 minutes. Wonder if since it's a repeat and wouldn't command the higher advertising dollars, that they might possibly cut the commercial time down a bit to fit it in the hour slot? I ended up just watching the end off the FOX website after it first aired, since I do have comcast and didn't get it on the DVR.
ron
R11 is offline
Old 03-09-2012, 11:49 AM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
What is much more likely is that they would edit the show's content down to fit what they would normally show, NOT cut the commercial time.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
Old 03-09-2012, 12:09 PM
mrvideo's Avatar
Quoted: 588 Post(s)
Liked: 329
^^^ Correct. About 7-8 minutes will be removed from the repeat.
Mr. Video
My Geek Images
mrvideo is offline
Old 03-10-2012, 12:57 AM
Quoted: 186 Post(s)
Liked: 295
Correct. This is exactly what Fox is doing.
Old 03-10-2012, 09:48 AM
R11
R11's Avatar
Liked: 69
Yeah, I guess in this day and age it would be too much for them to cut any advertising even from the repeat. But it seemed like there were quite a lot of things going on with the multiple, connected, story lines in the pilot. Wonder what they might edit out then?
ron
R11 is offline
Old 03-23-2012, 07:27 AM
jakestir's Avatar
Liked: 24
I enjoyed the 1st episode. The kid with the bomb part was pretty lame for reasons mentioned already....and no doubt he's going to get killed for not completing his mission.
The 2nd episode didn't do much for me. The social worker really wanted to take the kid back even after she saw what played out the day before? And then lets the kid get away a few hours later? Jack needs to set here straight.
Plus it's a little too sappy in the melodrama department.
But I'll stick with it for a while because I like the premise and I like Sutherland. And it's cool to see how the stories interact.
jakestir is offline
Old 03-23-2012, 07:47 AM
Quoted: 54 Post(s)
Liked: 99
Better than the first episode but could get old.
jandron's Avatar
Quoted: 21 Post(s)
Liked: 74
New drinking game: every time Kiefer Sutherland yells "Jake!"
Him following around his autistic son is going to get old fast.
jandron is offline
Old 03-23-2012, 07:53 AM
WaTaGuMp's Avatar
Quoted: 389 Post(s)
Liked: 435
I actually got bored with last nights episode. It came together in the end, but still, yawn, for me not a good sign.
RIP John, my best friend. Oct 17th 1966 - Nov 13th 2010
RIP Victor, my dad, June 26th 1927 - April 13th 2011
WaTaGuMp is offline
Old 03-23-2012, 07:58 AM
Charles R's Avatar
Liked: 536
It came close to getting old during the second episode for me. I want to like it however if the same routine plays out every week I'll be gone... not sure how but move the storyline. With virtually no supporting cast and the star not talking... there isn't much to get invested in.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Old 03-23-2012, 08:33 AM
Waboman's Avatar
Quoted: 4585 Post(s)
Liked: 10715
It's a feel-good show. But it sure has me missing Jack Bauer and 24.
Waboman is online now
Old 03-23-2012, 08:54 AM
jakestir's Avatar
Liked: 24
It would be cool if maybe some of these small stories come together in a large scale later on. Instead of them all being just stories of the week.
I really do like shows and movies with coincidences and chance encounters.
jakestir is offline
Old 03-23-2012, 08:56 AM
Tom Imp's Avatar
Quoted: 283 Post(s)
Liked: 146
I usually give each new show 2 episodes before I make my decision on whether to continue or not. After last night, I think I'm done.
I'm sorry, but the whole concept is preposterous to me that one action could be seen through some numbers and that would start a chain of events that would lead everyone to one spot days later. Seriously, the guy's hospital room number, the number on the bat, and his phone number all happen to contain the same 4 numbers? Give me a break! That and it's just going to be the same thing every week.
Nah, for as much as I like Kiefer, this show isn't cutting it.
Tom Imp is offline
Old 03-23-2012, 10:06 AM
Quoted: 54 Post(s)
Liked: 99
The reappearance of the Japanese girls seems to be hinting at that.
Old 03-23-2012, 11:02 AM
73shark's Avatar
Quoted: 366 Post(s)
Liked: 176
It seems like Jake is doing what the computer is doing in Person of Interest.
73shark is offline
Old 03-23-2012, 12:29 PM
MacAlert's Avatar
What if Jake IS the computer?
MacAlert is offline
Old 03-23-2012, 12:56 PM
73shark's Avatar
Quoted: 366 Post(s)
Liked: 176
73shark is offline
Old 03-23-2012, 01:06 PM
Brian Conrad's Avatar
Quoted: 1425 Post(s)
Liked: 744
"Meh" from me too on episode 2. The episode's production seemed stiff. I think Kring is too much an old school TV showrunner. We need more innovative and better storytelling.
Brian Conrad is offline
Old 03-25-2012, 12:44 PM
djoberg's Avatar
Quoted: 582 Post(s)
Liked: 750
I share some of the same concerns mentioned in previous posts. It's hard to really care about all the characters involved in each episode with such minimal character development. Add to this the constant "suspension of disbelief."
To put my concern for this show more bluntly...I don't believe Chloe could rescue Jack this time!
Sony XBR75X940D...Philips BDP 7501...Samsung BD-H5900...Toshiba HD-A30...Dish Hopper 3...Onkyo TX-NR717...Sony CDP-C725...Sennheiser HD 570...Beyerdynamic Custom One Pro...Harmony One Remote
Cambridge Soundworks MC305 Fronts & Center...Cambridge Soundworks Ambiance Surrounds....SVS PC12-NSD
djoberg is online now
Old 03-26-2012, 10:33 AM
DrLar's Avatar
Quoted: 438 Post(s)
Liked: 230
Little "24" cast member reunion there... and walking into Yankee stadium undisturbed that time? I thought the guards were going to tackle him as he was spreading the ashes on the field..
It's gonna be like this the kid has mastered escaping from wherever they have him..
RIP Mom, we always love you 8/18/13
DrLar is offline
Old 04-07-2012, 08:29 PM
djoberg's Avatar
Quoted: 582 Post(s)
Liked: 750
THE END...for me, and, I take it, for most everyone else. I don't think I could stand listening to Keifer's perpetual gasping for breath (even when he's not running or exerting any energy) or watching characters you never become attached to as they become attracted to one another through far-fetched numbers that defy rational thinking.
