Amazon streaming letter box - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-09-2012, 08:21 AM - Thread Starter
kjpjr's Avatar
Quoted: 34 Post(s)
Liked: 37
Any way to deal with the letterbox issue? 'zon says nothing they can do about it. I have a panny 60" plasma and get about 6 inches of letterbox top and bottom every time I stream a film. Any help would be appreciated.
kjpjr is offline
post #2 of 3 Old 07-09-2012, 08:35 AM
charlie460's Avatar
Are you sure it's not just OAR? Most movies are not 16:9
charlie460 is offline
post #3 of 3 Old 07-09-2012, 02:31 PM
BCF68's Avatar
If you are watching a movie in 2.35 to 1 aspect ratio of course you are going to have letterbox since your TV is 1.78 to 1. Many movies are filmed in 2.35:1. So you are just seeing the movie the way it was meant to be seen. But if you could gives us a few examples just to be sure that is the situation.
BCF68 is offline
Reply HDTV Programming
