Channels Don't Make Sense - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-15-2013, 03:21 PM - Thread Starter
rockitdoc's Avatar
I have Comcast and hooked up my new LG LCD TV to the cable, but not through the box Comcast rents. I get reception, of course, but the channels are like 81-5 for what would be CBS (654 or 054) with the box. How do I decode this so my kids will know what channel is what and can key in the channel they want to watch. I'm in northern COlorado, Ft Collins.
S
rockitdoc is offline
post #2 of 5 Old 01-15-2013, 06:35 PM
BriscoCountyJr's Avatar
Quoted: 36 Post(s)
Liked: 48
Thats how many cable systems are for the free clear-QAM channels.
You are seeing the raw physical channel number, not the virtual channel number that the cable box uses.
Its tougher because the cable system of course wants you to rent boxes from them at an extra charge...
BriscoCountyJr is offline
post #3 of 5 Old 01-15-2013, 08:39 PM
Westly-C's Avatar
Quoted: 357 Post(s)
Liked: 230
You'll just have to get an index card, and write down the channel numbers and the station/network name. Keep it nearby on a coffee table. plus, you should be able to give those channels a label-look into the channel settings under the Setup menu.
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is online now
post #4 of 5 Old 01-16-2013, 08:45 AM
NetworkTV's Avatar
Quoted: 961 Post(s)
Liked: 1515
Just be sure to write them down in pencil so you can change the list when they move them around on you...
NetworkTV is online now
post #5 of 5 Old 01-18-2013, 09:33 AM
mhufnagel's Avatar
Quoted: 22 Post(s)
Liked: 92
Silicon Dust has pretty accurate clear QAM channel line-ups at their website. Just plug-in your provider and location. It's a great tool to start with.
One of our local cabelcos (Wide Open West) actually has the clear QAM line-up available (using the actual clear QAM numbers) on their website to print. They also issue statements when they will be moving/adding/deleting any of those clear QAM channels so you can do a rescan when needed. Too bad other cablecos are such a-holes about clear QAM.
mhufnagel is offline
Reply HDTV Programming
