DirecTV is now blocking recording to DVD recorders on certain channels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 06-29-2013, 10:01 PM - Thread Starter
igreg's Avatar
Quoted: 265 Post(s)
Liked: 47
I tried copying part of the Dodgers/Phillies game from Prime Ticket and received the message, "This program is not recordable in +VR mode". The game was recordable on the Philadelphia CNS channel. Then I switch to HBO and found DirecTV is now blocking these channels also. Even if you record to you DVR, the blocking to you DVD player is still blocked. WTF. Is this legal? When did DIRECTV start doing this? Didn't the Supreme Court settle this for the consumers decades ago? Solutions? Thanks.
(Perhaps recording to another media such as DVD-RAM may still work? Perhaps a VCR will still work? I assume you can still record these in HD via component? I would think they could not block this without blocking viewing by component? I will need to test my recently archived HD DVR recordings off of HBO to see if blocked.)
igreg is offline
post #2 of 28 Old 06-29-2013, 10:37 PM
Aleron Ives's Avatar
Quoted: 1580 Post(s)
Liked: 1289
Welcome to the new world of DRM. Of course it's legal: the content providers don't want you to be able to exercise your rights under fair use, because it's more lucrative if they can make you pay for the same thing multiple times. It's also technically illegal to rip commercial DVDs now, even if you own them. The content providers managed to trample on fair use by saying that bypassing copy protection is illegal, even though copying a disc that you own isn't. Unfortunately, a judge agreed to their asinine argument, and since all commercial DVDs are encrypted, it's therefore illegal to copy pretty much any DVD that you didn't create yourself. See this AVSF topic for more details. If you've been able to copy recordings from premium channels like HBO until recently, you're actually behind the curve. Most pay-TV providers have been setting the copy-once flag on premium channels for quite a while now.
It is sometimes possible to save an analogue capture of protected shows through composite or component outputs, but aside from the inconvenience of having to wait for the entire program to play out, it's also possible for Macrovision protection to disable even VCRs from saving protected content.
Aleron Ives is offline
post #3 of 28 Old 06-29-2013, 10:55 PM
yaomizzle's Avatar
Liked: 26
Welcome to the world brought to you by all those people that think pirating is ok
Sent from my iPad using Tapatalk HD
yaomizzle is offline
post #4 of 28 Old 06-29-2013, 11:54 PM - Thread Starter
igreg's Avatar
Quoted: 265 Post(s)
Liked: 47
It may be I didn't notice until recently because my former DVD recorder broke and may not have had the technology to enable the blocking that my other DVR recorder (which I moved from my bedroom and didn't use often to copy) appears to possess?
Any speculation on if or when the industry will block HD over component? Apparently already restricted to 1080i on Blu-Ray, but apparently most HD sets cannot play 1080p over component anyway. Moot for me for most part since I have a commercial Panasonic from 2004 that is not 1080p.
I wonder how they can block the recording of 480i but still allow the viewer to watch 480i? Then why don't they enable viewers to watch 1080i over component but block its recording? Apparently can do for 480i but not 1080i? Thanks.
igreg is offline
post #5 of 28 Old 06-30-2013, 12:30 AM
Liked: 1289
Yes, that is quite possible. Older VCRs are also immune to some of the analogue copy protection schemes, such as Macrovision's. If your equipment ignores or doesn't have the features that some schemes exploit, it may still function.
Most Blu-ray players, to my knowledge, will only output 480i/p over anything other than HDMI, assuming they are playing a commercial BD-ROM. Unprotected sources may allow up to 1080i over component, but there is some variation between sources and players, especially depending on where the hardware and software originated.
There are multiple ways to facilitate it. Macrovision's ACP exploits newer VCRs' automatic gain control to render recordings of protected content unwatchable, while modern DVD recorders are manufactured to detect and refuse to record analogue sources containing ACP. Televisions are allowed to display the content, since they can't record it. The simplest method to prevent recording over component is to not include component outputs on new cable boxes, which AFAIK is becoming more common.
That's something of an oversimplification, since these asinine protections exist mainly to encourage Joe Sixpack to give up on archiving his TV shows and either buy them on disc or over a subscription video service. They have no effect on piracy rates, since all DRM schemes get cracked eventually: it's an inherently flawed technology.
post #6 of 28 Old 06-30-2013, 01:05 AM - Thread Starter
igreg's Avatar
Quoted: 265 Post(s)
Liked: 47
Thanks for the information. I do see where the new PS3's have component capability but no longer allow HD resolution of Blu-Ray disks via component; gaming, streaming and home video are not effected. I believe the older models that don't have this restriction may still be sold legally until December 31, 2013. My PS3 allows me to pasthrough HD from Blu-Ray; however, the max resolution is capped at 13.5 mbs with the Hauppauge DVR; therefore, not really a good alternative with Blu-Rays having much higher resolution, superior audio, extras, artwork, et al. for reasonable prices.
igreg is offline
post #7 of 28 Old 06-30-2013, 03:26 AM
sneals2000's Avatar
Quoted: 240 Post(s)
Liked: 127
Suspect they are using http://en.wikipedia.org/wiki/CGMS-A
This is a signal that can be embedded in a video output (how this is embedded varies between frame rates and line standards as existing data signalling systems can be used in some cases - such as Line 23 WSS in 576/50i stuff) and it is used to flag copy protection.
Unlike Macrovision, I believe it doesn't modify the video signal to make it un-recordable, it just flags to recorders that there are copy protection issues with the media. For it to be effective it requires that recorders respect the copy flags - the video itself is still perfectly normal (unlike analogue Macrovision which does all sorts of horrible things that TVs are usually happy with but VCRs weren't). AIUI most (if not all) DVD Recorders will respect the CGMS data, presumably it is a requirement for selling DVD Forum licensed devices?
In the UK we've had issues where a broadcaster has used a clip from a commercial DVD (which is legal under UK Fair Dealing law) which has contained CGMS data in Line 23 (SD 576/50i) This has survived all the way through the programme chain and caused people who are recording the show to have their DVD Recorders stop when they see the copy protection data. (So most broadcasters will ask their picture editors to blank the top line to prevent this...)
sneals2000 is offline
post #8 of 28 Old 06-30-2013, 03:55 AM - Thread Starter
igreg's Avatar
Quoted: 265 Post(s)
Liked: 47
Do you know of DVD recorders that do not "respect the flag." I take it that it is not legally required for manufacturs to do so. I am contemplating purchasing a second DVD recorder anyway. Tx.
igreg is offline
post #9 of 28 Old 06-30-2013, 09:06 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Yes, my old Polaroid DVD recorder would record anything. It had component inputs too, which is pretty rare. You could find them on eBay for a while for around $70. It was a model 2001G I think.
mdavej is offline
post #10 of 28 Old 06-30-2013, 03:49 PM
Liked: 1289
Ironically, the one that's on eBay right now is listed as model DRM-2001G. biggrin.gif
It is now, but some recorders will predate the requirements, and recorders made in other countries don't obey them.
post #11 of 28 Old 06-30-2013, 04:10 PM - Thread Starter
igreg's Avatar
Quoted: 265 Post(s)
Liked: 47
That explains a lot. My prior DVD Recorders were both from Panasonic (hard drive models), and I had no problem with them...until they stopped working. The Phillips was less expensive and as it turned out not as good a performer as the Panasonic....and also has the blocking.
So even the newer models from Panasonic should not "obey" the "requirements"? Thanks.
igreg is offline
post #12 of 28 Old 06-30-2013, 04:20 PM
ti-triodes's Avatar
Quoted: 232 Post(s)
Liked: 260
Only the earliest Polaroid recorders could record anything. That was "fixed" with the later units. My Polaroid wouldn't record flagged stuff.
ti-triodes is offline
post #13 of 28 Old 06-30-2013, 04:36 PM
mdavej's Avatar
Liked: 940
Forgot about that. Those Polariods came in several versions. Mine was a C if I remember correctly. It was still wide open. I have to warn you though, picture quality is more than a few steps down from Panasonic. I think the Polaroids were actually Philips/Magnavox inside.
mdavej is offline
post #14 of 28 Old 06-30-2013, 06:51 PM
Liked: 1289
Just because a piece of CE equipment is made by a foreign company doesn't mean it will ignore local regulations. Japanese products designed for the Japanese market won't obey the requirements, but ones made for the American market will. It's possible to buy Blu-ray recorders in Japan that function the same as DVD recorders do in the US, because Japan doesn't have the same regulations. None of those units are sold outside of Japan, of course.
post #15 of 28 Old 06-30-2013, 07:57 PM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
This is incorrect. I have Panasonic DVD recorders from several years, starting with the '05 EH50, and ending with an EH59 manufactured about a year and a half ago, and they ALL conform to the copy inhibit flag. It is easily fixed with a filtering device that removes the flag.
I have never had a program from DirecTV that would not record on my various DVD recorders. I don't attempt to make DVDs of sports, but movies and other programming, from HBO, Cinemax, Starz, and many other channels, have always worked fine. What program exactly did you try to record off HBO that you were unable to copy to a DVD? I'd like to know to test it myself.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
post #16 of 28 Old 07-01-2013, 03:49 AM
sneals2000's Avatar
Quoted: 240 Post(s)
Liked: 127
It's possible to buy Blu-ray recorders in the UK (Panasonic make them) - but AIUI they obey our local copy-protection mechanisms. HD content broadcast free-to-air on OTA and satellite is accompanied by copy protection flags that usually allow just a single copy to be made on removable media. I don't know if Japan has any copy protection on its non-pay TV broadcasts.
ISTR that Japanese Blu-ray players, like UK ones, have integrated OTA and/or satellite tuners, and don't take external HD baseband inputs (i.e. HDMI or the Japanese component D-style connectors)?
post #17 of 28 Old 07-02-2013, 05:16 PM - Thread Starter
igreg's Avatar
Quoted: 265 Post(s)
Liked: 47
Dodgers on Prime Ticket and HBO were blocked. Went to CNN and other basic cable....no problem.
I had the EH50, and did not have any problems either. Only with the Phillips. Why do you believe the Panasonic conforms to the copy inhibit flag if you did not experience problems copying?
igreg is offline
post #18 of 28 Old 07-03-2013, 04:04 PM
ti-triodes's Avatar
Quoted: 232 Post(s)
Liked: 260
I believe he was referring to the Panny in conjunction with the filtering device.
post #19 of 28 Old 07-05-2013, 01:27 AM - Thread Starter
igreg's Avatar
Quoted: 265 Post(s)
Liked: 47
He said, referrring to the Panasonic, that they ALL conform to the copy inhibit flag. I did not find that was true with the Panasonic, unless DirecTV just started the blocking within the last year or at most two.
igreg is offline
post #20 of 28 Old 07-05-2013, 01:44 PM
Quoted: 111 Post(s)
Liked: 86
I know that the Panasonic DVD recorders conform to CP because every time I have attempted to make a recording of known protected content, the machines tell me the content is protected and not recordable. Legally, they HAVE to comply. This issue isn't with the Panasonic DVD recorders, it's with the Philips recorder being set so sensitive (by the manufacturer) that it THINKS that there is content protection when it isn't present. Sony recorders, and Philips are known for these "false positives". I do have a filter, but I have never needed it for anything I have attempted to record off DirecTV yet. This weekend I made many recordings from HBO and Starz without any problem at all.
It isn't the Panasonic ignoring the content protection, it's the Philips that is seeing one where it doesn't exist. A filter would most probably fix the problem. Why the issue has just appeared is interesting.
Luke
post #21 of 28 Old 07-05-2013, 05:22 PM
ti-triodes's Avatar
Quoted: 232 Post(s)
Liked: 260
Do you have something plugged into the HDMI output of your D* receiver when you're recording? The only way I get my Panny's to record is to unplug the HDMI.
post #22 of 28 Old 07-06-2013, 07:13 PM
Quoted: 111 Post(s)
Liked: 86
Oh yes, I have the HDMI output of my DirecTV DVRs connected to my television.
Luke
post #23 of 28 Old 07-07-2013, 04:40 PM
ti-triodes's Avatar
Quoted: 232 Post(s)
Liked: 260
Thanks. I PM'd you.
post #24 of 28 Old 09-23-2013, 09:43 AM
QueJay1351's Avatar
D'accord! Content venders are using the 'arms race' between themselves and the encryption crackers as an excuse to double and triple charge fair users for content. As you said the codes always get cracked anyway, but why not make a little extra money off of 'Joe Six-pack' in the interim? So, welcome to the new world of 'corporate-fleeces-the-consumer-yet-again'.
QueJay1351 is offline
post #25 of 28 Old 09-24-2013, 11:57 AM
Liked: 645
You just necro'd a thread that was in the wrong forum to begin with (DVDs aren't HD), here's the right place to continue the good fight...
http://www.avsforum.com/f/106/dvd-recorders-standard-def
slowbiscuit is offline
post #26 of 28 Old 09-25-2013, 01:32 AM - Thread Starter
igreg's Avatar
Quoted: 265 Post(s)
Liked: 47
....except it does belong because you are attempting to record a HD broadcast, even if the resultant recording is in SD.
igreg is offline
post #27 of 28 Old 11-09-2013, 08:02 AM
MD Movie's Avatar
Where can you get the filter
MD Movie is offline
post #28 of 28 Old 11-09-2013, 08:40 AM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
One possible filter(and the cheapest) if you have component would be something like this:
http://www.monoprice.com/Product?c_id=101&cp_id=10114&cs_id=1011407&p_id=7114&seq=1&format=2
Another if you only have composite or S-video would be this Grex:
http://www.amazon.com/XDIMAX-GREX-7-4-Grex-Video-Stabilizer/dp/B0096I2DNE/ref=sr_1_1?ie=UTF8&qid=1384011560&sr=8-1&keywords=grex+digital+video+stabilizer
I own both and the picture quality of the more expensive Grex is better but you also might be OK with the Monoprice(Lenkeng built) model, again if you have component output.
jjeff is online now
Reply HDTV Programming
