Broadchurch on BBC America - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 176 Old 07-31-2013, 08:45 AM - Thread Starter
mrvideo's Avatar
Quoted: 583 Post(s)
Liked: 326
After seeing the posts in Hot off the Press, I remembered that I had the 8 episodes and decided to watch them in a marathon, which I finished up a little bit ago.
It is indeed an excellent series that needs to be seen. I was kept glued to the screen. Even though I had decided to watch it as a marathon, once I got started watching, there was no way I wasn't going to view all of the episodes.
Unfortunately they are going to be shown on BBCA. While the series is an ITV production, the amount of commercial time is less than it is here in the states. The first seven episodes run an average of 46.5 minutes, while the finale runs 50.5 minutes. That means BBCA is going to have to butcher the episodes in order to air them within an hour and still maintain their normal commercial load.
I have no faith in BBCA airing the episodes intact.
Hopefully they will make me eat my words, as the BBCA viewers need to see ALL of what ITV produced and aired.
"You're Sherlock Holmes, wear the damn hat!" - Watson to Sherlock
Sherlock - The Abominable Bride - 1/01/16
Mr. Video
My Geek Images
mrvideo is offline
post #2 of 176 Old 07-31-2013, 09:52 AM
lonwolf615's Avatar
Quoted: 33 Post(s)
Liked: 134
I've been eagerly waiting for this and its good to hear its worth it. Hopefully you're wrong about BBCA-I know The Hour usually ran over its allotted time so I hope this one does also.
"There is no truth. There's just what you believe."
lonwolf615 is offline
post #3 of 176 Old 07-31-2013, 11:33 AM
Steve S's Avatar
Liked: 46
Hopefully they'll do what they do with Top Gear-run first-run eps intact and only cut rebroadcasts.
Steve S.
Steve S is offline
post #4 of 176 Old 07-31-2013, 12:30 PM
sneals2000's Avatar
Quoted: 241 Post(s)
Liked: 127
Broadchurch is an ITV series not a BBC series, so will only run 44-46 minutes per hour (as ITV airs commercials) rather than the 58-59 minutes per hour a BBC-commissioned/produced series will run (as the BBC don't air commercials in the UK).
That means Broadchurch should fit into a US commercial hour with relatively minor cuts - if any at all?
Broadchurch was very popular in the UK, though obviously took some inspiration from The Killing. The only downside is the accents. They were terrible in some cases.
sneals2000 is offline
post #5 of 176 Old 07-31-2013, 12:37 PM
VisionOn's Avatar
Liked: 1946
As the first post mentions, 44-46 is too long for a US commercial hour. A show needs to be running at approximately the 40 minute mark to make it without trimming.
VisionOn is online now
post #6 of 176 Old 07-31-2013, 05:22 PM
HDMe2's Avatar
Quoted: 678 Post(s)
Liked: 485
Most modern shows in the US are clocking close to 42 minutes for an "hour" programming block... typically, though, they run ads over the end-credits to pack in a little extra commercial time...
That said... BBC America has been very good as far as I can tell about airing complete/uncut BBC programming on the night of their designated first-run. After that, you usually get a cut-for-commercial-time version... but the premiere night usually is intact and either they extend the hour by 10 minutes to make room for the commercials OR they air with a sponsor and "limited interruption".
HDMe2 is offline
post #7 of 176 Old 07-31-2013, 06:00 PM
diditagain's Avatar
In the past, BBC America has aired multiple one-hour UK dramas (meaning 45-46 minutes without commercials) uncut in a 60-minute timeslot (Whitechapel, Law & Order: UK, etc.), so there is no reason to assume Broadchurch will be cut for time, at least for the first 7 episodes.
What happens with episode 8, which runs 50.5 minutes, depends on the ratings for the first 7 episodes. Last fall, The Hour S2, which ran 60 minutes, was initially given a 75-minute timeslot. However, the ratings were very low, so low that the final episodes were reduced to 45 minutes in a 60-minute timeslot to allow a repeat of Law & Order: UK, which got higher ratings, to air from 10-11pm.
If enough people watch Broadchurch, making the show profitable for BBC America, then the final episode could very well air unedited in a 60-minute timeslot with limited commercials. If the ratings are just OK, then BBC America might trim 4-5 minutes from the final episode.
On the subject of editing for time, I noticed something interesting with another BBC America show, Ripper Street. BBC America, which co-produces the show, aired 55-minute episodes in a 75-minute timeslot, while BBC One aired 59-minute episodes (I "found" the first few episodes online for comparison, and they all ran around 59 minutes). However, I just bought the S1 Blu-ray, and all episodes run 62-63 minutes, so it looks like even BBC One made edits before broadcast.
diditagain is offline
post #8 of 176 Old 08-02-2013, 05:27 AM
sneals2000's Avatar
Quoted: 241 Post(s)
Liked: 127
Could it be 24 vs 25 fps rather than edits that explain the duration difference. If the S1 Blu-ray was 1080p it will be running at 24fps rather than 25fps, so will run slower than the UK 25fps broadcasts?
post #9 of 176 Old 08-02-2013, 05:28 AM
sneals2000's Avatar
Quoted: 241 Post(s)
Liked: 127
Fox are re-making Broadchurch for a US audience it seems : http://www.bbc.co.uk/news/entertainment-arts-23546542
post #10 of 176 Old 08-07-2013, 08:54 AM
John Mason's Avatar
Quoted: 76 Post(s)
Liked: 103
Noticed an extensive review of the series in today's NYTs, -- John
John Mason is offline
post #11 of 176 Old 08-08-2013, 11:38 AM
lonwolf615's Avatar
Quoted: 33 Post(s)
Liked: 134
Loved the 1st episode, A tight, well written storyline, perfectly acted. The idyllic town with the seamy underside reminds me of Blue Velvet or Twin Peaks without the surreal strangeness.Tenant was great-love the suppressed rage and menace he projects as he takes charge.
daryl zero and tomhunter8 like this.
post #12 of 176 Old 08-08-2013, 03:12 PM
sneals2000's Avatar
Quoted: 241 Post(s)
Liked: 127
It was very good, and very popular in the UK. (But the accents do let it down. They wander wildly and most of my friends from the area found it frustrating that such a good drama could be let down by that...)
post #13 of 176 Old 08-08-2013, 03:45 PM
Distorted's Avatar
Quoted: 431 Post(s)
Liked: 341
...the accents do let it down...
Is that what that was? I thought they were speaking an altogether foreign language. To me they were. As Prof. Doolittle said, "Why, in America they haven't spoken it (English) in years."
"Without music, life would be a mistake." - Friedrich Nietzsche
Distorted is offline
post #14 of 176 Old 08-08-2013, 06:36 PM
sneals2000's Avatar
Quoted: 241 Post(s)
Liked: 127
Yep - actors doing West Country or East Anglian accents usually end up going a bit wrong unless they are very good, or natives of the area.
(And we are two nations divided by a common language...)
post #15 of 176 Old 08-08-2013, 07:42 PM
gwsat's Avatar
Quoted: 2144 Post(s)
Liked: 2361
Because of how popular Broadchurch had been in the UK, I setup a TiVo season pass for it on BBC America but still almost missed it because I had setup my season pass to record first run episodes only. For some reason, I learned that my guide thought every episode was a rerun and it was too late and reset the season pass to record repeats too. Fortunately, i figured it out in time to change my season pass to record every episode.
Tell me about it. Twenty years ago a close friend and colleague of mine went to Europe. When we were in England my friend and I stayed with his cousin and her husband. One evening she accused me of trying to sound British, upon which I explained that what she was hearing was how I sounded everywhere. Trust me on this partner, I don't sound very British.smile.gif
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Crestron Control System; Hsu VTF-3 MK3 Turbo subwoofer, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR
gwsat is offline
post #16 of 176 Old 08-08-2013, 09:45 PM
lonwolf615's Avatar
Quoted: 33 Post(s)
Liked: 134
Did you like it gwsat?
post #17 of 176 Old 08-08-2013, 10:05 PM
rebkell's Avatar
Quoted: 413 Post(s)
Liked: 283
This is getting to be a too common occurrence, you'd think stations would have someone to monitor these things, as plentiful as DVR's are nowadays, you would think the possibility of thousands of viewers not catching the show would warrant a little effort reviewing the guide data.
rebkell is offline
post #18 of 176 Old 08-08-2013, 10:46 PM
HDTVChallenged's Avatar
Liked: 215
A fine first episode. Although, the lead investigator reminded me a bit of a Doctor playing Hamlet playing a police detective inspector. wink.gif (relax ... it's just a joke for recent followers of the Who thread.)
I see Mr. Pond makes an appearance here too.
HDTVChallenged is offline
post #19 of 176 Old 08-08-2013, 10:50 PM
lonwolf615's Avatar
Quoted: 33 Post(s)
Liked: 134
omg, thats a relief. I thought it was just me...
Great post HD.
post #20 of 176 Old 08-09-2013, 10:37 AM
gwsat's Avatar
Liked: 2361
Because of the season pass glitch I described in an earlier post, I missed the first episode when it first ran. Fortunately, it will be rerun tonight and I will record it then. Will report my impressions after I see the show. I am optimistic about the show because of how much I like both Mark Strong and Olivia Coleman.
gwsat is offline
post #21 of 176 Old 08-09-2013, 03:27 PM
Fastslappy's Avatar
Liked: 749
Mark Strong ? is on Broadchurch ?
he's on "Low Winter Sun"
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #22 of 176 Old 08-09-2013, 08:22 PM
gwsat's Avatar
Liked: 2361
Brain fart. I have been confusing the two series for days. I should have said David Tennant and Olivia Coleman. A thousand pardons!smile.gif
gwsat is offline
post #23 of 176 Old 08-12-2013, 08:26 PM
gwsat's Avatar
Liked: 2361
Just got to watch the first episode of Broadchurch. Wow! I was blown away, particularly by Olivia Coleman, who was wonderful as the too-epmathetic-for-her-own-good cop, Ellie Miller, who has long lived in the little English seaside town, Broadchurch, where the show is set. Her performance at the beach when she recognized the dead little boy who had been her son's dear friend was heartbreaking. I thought David Tennant was just fine too, although it's obvious that we have a lot more to learn about his character, Alec Hardy, who has just arrived in town with scandal in his wake to be Ellie's boss. I am really looking forward to seeing the rest of Broadchurch.
gwsat is offline
post #24 of 176 Old 08-13-2013, 03:19 AM
sneals2000's Avatar
Quoted: 241 Post(s)
Liked: 127
Olivia Colman is a brilliant actress - equally capable of comedy and drama. Compare her work in "Peep Show" and "Twenty Twelve" to her performances in "Broadchurch" and the film "Tyrannosaur". Amazing actress.
post #25 of 176 Old 08-13-2013, 08:18 AM
gwsat's Avatar
Liked: 2361
Couldn't agree more. I first became a fan of Olivia Coleman's work on the wonderful Twenty Twelve. As you know, the show had a remarkably talented ensemble cast and I thought Coleman was among the most talented of the bunch. To digress for a moment, I thought just as highly of Jessica Hynes as the garrulous Siobhan Sharpe.
gwsat is offline
post #26 of 176 Old 08-13-2013, 04:45 PM
Garrett Adams's Avatar
Quoted: 877 Post(s)
Liked: 889
You men, cool, this the thing, Jessica Hynes. That character drove up the wall with her devilish ways. I'd love to see that committee reformed for some new big project.
Garrett Adams is offline
post #27 of 176 Old 08-13-2013, 06:17 PM
daryl zero's Avatar
Quoted: 933 Post(s)
Liked: 834
Show reminds me of Twin Peaks. First show mirrors the Twin Peaks first show with the slow, long horror of the death of a child.
"Nowadays, you can just click a button and buy a book, meet your spouse or ruin someone's life. Sometimes those last two are the same thing." John Oliver.
daryl zero is offline
post #28 of 176 Old 08-13-2013, 06:18 PM
daryl zero's Avatar
Quoted: 933 Post(s)
Liked: 834
I missed this post. I think you nailed it.
post #29 of 176 Old 08-15-2013, 10:25 AM
lonwolf615's Avatar
Quoted: 33 Post(s)
Liked: 134
Loved this episode too...The mother being frozen by the cereal box at the store was a nice touch, driving home her sense of loss. And the slow reveal of some of the secrets of the townspeople was nicely done. offerring more clues to the seamy underside of life in Broadchurch. This town makes Twin Peaks look like Mayberry!
One strange thing. Normally I have no problem seperating an actor from a role. But watching Tenant I have to confess its hard to keep the good doctor out of my head. Its my failing, not his acting, and I'm surprised I'm having this problem. It was a little bit better this episode, so maybe after a couple more it will fade. Right now its kinda distracting.
post #30 of 176 Old 08-15-2013, 01:06 PM
Church AV Guy's Avatar
Quoted: 111 Post(s)
Liked: 86
Um, that was Professor Henry Higgins. It was a different role played by the same actor--Rex Harrison.
Luke
Evil is charming and beautiful. It makes you doubt yourself. It asks for one small compromise after another until it whittles you down, and it functions best when no one believes in it.-JOA
Church AV Guy is offline
Reply HDTV Programming
