Uncropped OAR Movies: Post your sightings here. - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 1306 Old 02-14-2006, 07:13 PM
Kevin12586's Avatar
Question about OAR movies. Since I have a 16:9 screen, if an HD movie is shown as OAR, do I notice a difference compared to a a standard HD program, since both will fill my screen?
Kevin12586 is offline
post #452 of 1306 Old 02-14-2006, 07:46 PM
HDNair's Avatar
It depends on what the OAR is. Typical aspect ratios are 4:3 (standard television, films made before the 50's), 1.66:1 (European matted widescreen), 1.85:1 (American matted widescreen), 2.2:1 (70mm) and 2.35:1 (anamorphic widescreen, Super35 widescreen). 1.85:1 and probably 1.66:1 (can't say I've ever seen an example of this) would be slightly cropped to fill the 16:9 screen (16:9 translates to 1.78:1). This cropping is pretty minimal and wouldn't bother most people. Wider formats would need to have black bars on the tops and bottoms to be presented in it's OAR, and narrower formats would need to have black bars on the sides to be shown in it's OAR.
If you want to know what the OAR of a film is, check out the technical specs on IMDB.com.
HDNair is offline
post #453 of 1306 Old 02-15-2006, 02:57 AM
HDTVFanAtic's Avatar
50 First Dates in 2.35:1 looked REALLY GOOD this morning.
HDTVFanAtic is offline
post #454 of 1306 Old 02-15-2006, 03:11 AM
Kitok's Avatar
Cabin Fever on HBO also looked really good this morning 2.35:1!
Kitok is offline
post #455 of 1306 Old 02-15-2006, 04:13 AM - Thread Starter
dneily's Avatar
I looked it up in IMDB. Cabin Fever is a "new release" (2002). Lions Gate is the U.S. distributor.
dneily is offline
post #456 of 1306 Old 02-15-2006, 04:24 AM
Darrin's Avatar
Which channel?
Darrin is offline
post #457 of 1306 Old 02-15-2006, 03:34 PM
post #458 of 1306 Old 02-15-2006, 03:53 PM
VideoGrabber's Avatar
Quoted: 185 Post(s)
Liked: 115
HFA wrote,
> 50 First Dates in 2.35:1 looked REALLY GOOD this morning. <<br />
Yo, FanAtic, I'll echo Darrin... which channel?
If Cinemax, that would be very interesting, because both times previously that it aired on HBO, it was 1.78. Unfortunately, I see only a single airing left, Saturday morning at 9:30am.
- Tim
VideoGrabber is offline
post #459 of 1306 Old 02-15-2006, 04:04 PM
Originally Posted by VideoGrabber View Post
HFA wrote,
- Tim
Movie Central HD
post #460 of 1306 Old 02-15-2006, 04:58 PM
lax01's Avatar
ok now where are the "good" pictures...and by good pictures, I mean the ones with exposed breasteses!!!
Josh
PSN: lax01
lax01 is offline
post #461 of 1306 Old 02-15-2006, 05:38 PM
I decided not to post those scenes to make the moderators happy.
post #462 of 1306 Old 02-15-2006, 05:45 PM
DaveFi's Avatar
Quoted: 155 Post(s)
Liked: 63
Odd, because Cabin Fever has been on HBO before Cropped.
I think this is the first occurance where a movie has showed up cropped on HBO first, then Cinemax OAR later. Ususally it's the other way around.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #463 of 1306 Old 02-15-2006, 06:24 PM
Quoted: 185 Post(s)
Liked: 115
HFA,
> Movie Central HD <<br />
Thanks. Those shots did look very clean.
- Tim
P.S. Dave, no, not MAX, though it is airing there this month too (and coming around again in March on HBO). It was MC-HD, presumably on BEV.
post #464 of 1306 Old 02-15-2006, 08:52 PM
Antwone Fisher looked good in OAR this evening
post #465 of 1306 Old 02-15-2006, 09:02 PM
HDTV-NUT's Avatar
Anyone know is Cast Away comming on ABCHD Saturday night will be OAR? http://abc.go.com/movies/castaway.html
PSN: JAY-NUCLEAR
HDTV-NUT is offline
post #466 of 1306 Old 02-15-2006, 09:07 PM
Since it has an ABC-HD logo on on the bottom of the webpage you posted, what do you think?
post #467 of 1306 Old 02-15-2006, 10:16 PM
thefatguy's Avatar
FanAtic, what are you using to get the HD grabs?
-thefatguy
thefatguy is offline
post #468 of 1306 Old 02-15-2006, 10:23 PM
Typiclally either Womble MPEG-VCR as a .bmp and then convert it to .png or .jpg with Photoshop or just a straight VLC capture.
post #469 of 1306 Old 02-16-2006, 02:34 AM
ReplayJanitor's Avatar
Even if they crop it, shouldn't be that big of a big deal, since Castaway was shot in 1.85:1. You'd lose... .07 of the width. It's a 52px crop on the width of a 720p picture (I know that calculation doesn't really make sense). Now, Forrest Gump the Saturday after is a different story if it gets cropped.
ReplayJanitor is offline
post #470 of 1306 Old 02-16-2006, 04:45 AM
Matt_Stevens's Avatar
Liked: 48
1.85:1 films just have the mattes moved out a bit to fit 1.78:1, which means no cropping. Just a tad extra info.
Vimeo is the home of the Super8 Shooter...
http://vimeo.com/super8shooter
Matt_Stevens is offline
post #471 of 1306 Old 02-16-2006, 09:13 AM
Correct.
Concerning Forrest Gump, ABC HAS shown it OAR at least twice before. I doubt they will obtain a new cropped transfer.
post #472 of 1306 Old 02-16-2006, 06:10 PM
Ken H's Avatar
Legally Blond - OAR & 5.1, on FOX!
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #473 of 1306 Old 02-16-2006, 07:42 PM
HDTV-NUT's Avatar
i dont really know. im pretty new to all of this and just trying to learn. cant you just tell me instead of being smart about it? all im doing is asking a simple question for hells sake.
PSN: JAY-NUCLEAR
HDTV-NUT is offline
post #474 of 1306 Old 02-16-2006, 08:16 PM
videojanitor's Avatar
Yes, but unfortunately, it's widescreen SD, same as the last time it aired. And the 5.1 is not "real" -- it's derived from 2-channel Pro-Logic. Oh, and it's time-compressed as well ...
videojanitor is offline
post #475 of 1306 Old 02-17-2006, 10:15 AM
Damnationdoormat's Avatar
You can really see the thick coloration, edge enhancement, and lack of detail with the DVD when compared to the shot above.
Damnationdoormat is offline
post #476 of 1306 Old 02-17-2006, 03:38 PM
Tom Monahan's Avatar
Location: Butte, Montana Hometown of the late Evel Knievel
Quoted: 60 Post(s)
Liked: 43
Wasn't L.A. Confidential OAR on HBO a while back?
My equipment: JVC RS55 for 2D, BenQ W7000 for 3D, Carada 40x117 2.925:1 AR BW Criterion screen, Navatar .8 HD conversion lens, Darbee Darblet, region free Oppo BP93, Toshiba HD-A35 HD-DVD, JVC HD-DH5U D-Theater, Mitsubishi HS-HD 20000 DVHS, Pioneer CLD-97 LD player/AC-3 mod, B&K AC3 Demodulator
Tom Monahan is offline
post #477 of 1306 Old 02-17-2006, 05:15 PM - Thread Starter
dneily's Avatar
Most recently, it was OAR on Cinemax.
dneily is offline
post #478 of 1306 Old 02-17-2006, 05:36 PM
Quoted: 60 Post(s)
Liked: 43
I should have recorded it on HBO.
post #479 of 1306 Old 02-17-2006, 06:38 PM
Liked: 48
But just 2.0. The DVD soundtrack is vastly superior.
post #480 of 1306 Old 02-17-2006, 07:31 PM
yes it was.
Reply HDTV Programming
