Summary of Yule log jokes (Get em while they are hot) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-25-2003, 01:54 AM - Thread Starter
PVR
PVR's Avatar
Yule log jokes taken from other threads:
#1: Watch out or your display will suffer burn-in.
#2: It may be blacked out if you don't live in a heavily forested area.
#3: Hopefully they show it in OAR so you can see all the side embers.
#4: Will Voom now start a 24 hour Yule Log channel?
#5: Will they brodcast 5.1 surround smell?
PVR is offline
post #2 of 7 Old 12-25-2003, 09:51 AM
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
good one
dm145 is offline
post #3 of 7 Old 12-25-2003, 10:23 AM
leesweet's Avatar
#3 "As originally burned!"
-Lee (See my profile for equipment.)
leesweet is offline
post #4 of 7 Old 12-25-2003, 05:12 PM
openhouse's Avatar
Good ones.
:D
openhouse is offline
post #5 of 7 Old 12-26-2003, 10:09 AM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
Yule Log on to find out what they're saying about it on AVS...
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #6 of 7 Old 12-26-2003, 10:16 AM
wward's Avatar
The heat from the Yule log caused my internal receiver in my F38310 to constantly re-boot!
wward is offline
post #7 of 7 Old 12-26-2003, 07:19 PM
Kipp Jones's Avatar
:D :D :D
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
Closed Thread HDTV Programming
