OTA anntenna's for sacramento - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-13-2001, 08:22 PM - Thread Starter
Toolman Tim's Avatar
Does anyone have any suggestions on which ota antenna to buy, to pick up hdtv programming here in sacramento. Can you use any antenna or do you have to buy a hdtv antenna? Or is that hdtv compatible logo just a hoax..
Toolman
Toolman Tim is offline
post #2 of 6 Old 02-13-2001, 09:22 PM
nightowl's Avatar
Depending on your location, just about any antenna will do to pick up the locals channels. All four seem to put out a pretty good signal. I would recommend an outdoor YAGI style antenna, either UHF only or UHF/VHF if you want to get the analog OTA stations as well.
And the HDTV "ready" thing is pretty much garbage. As long as it's UHF, it will work just fine...
Jeff
nightowl is offline
post #3 of 6 Old 02-13-2001, 11:47 PM
Vettster's Avatar
Before I got my permanent antenna, I was getting respectable signals with plain old rabbit ears clamped to a chair out the back porch from Rocklin. Tacky but temporarily served the purpose well.
Those rabbit ears certainly didn't have HDTV stamped on them. http://www.avsforum.com/ubb/wink.gif
Vettster is offline
post #4 of 6 Old 02-14-2001, 10:10 AM
minesh1's Avatar
The "HDTV Compatible" stuff is nonsense, just like "Digital Ready" headphones. UHF is UHF, all you need is the proper hardware to decode the signal and display it.
minesh1 is offline
post #5 of 6 Old 02-14-2001, 10:11 AM
FJ40's Avatar
I got a Radio Crap one for $39 and it works great.
Dan
Mits 55857
Nak AV-10
DTC-100
Dan
Mits 55857
Nak AV-10
Comcrap DVR
FJ40 is offline
post #6 of 6 Old 02-15-2001, 08:55 AM
Trackman's Avatar
Quoted: 114 Post(s)
Liked: 98
Same here. Radio Shack indoor UHF(loop)/VHF(rabbit ears) gets all digitals at 70 or better.
Go Duke !
Go Duke !
Trackman is offline
Closed Thread HDTV Programming
