Dish Network and ExpressVu - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-18-2001, 11:30 AM - Thread Starter
dahester's Avatar
Your best bet is to pony up and get two receivers. It is theoretically possible to get Dish to work with BEV and vice-versa, but not without tampering with or hacking the smart cards. Also, the firmware for the two systems is different, so you won't be able to use an SW-64 switch or something to that effect to integrate the two systems.
You can have as many as 3 dishes for Dish Network (61.5W, 110/119W, and now 148W). BEV only requires one 18" dish for 91W, although it helps to have a 20" or 24" dish in southern regions of North America.
Finally, yes you can use the model 5000 receiver and modulator for BEV, but once again you have to tamper with the access card. So it is not supported by ExpressVu. The modulator DOES work correctly, and you can receive any channel that has AC-3 audio with an OTA HDTV tuner such as the DTC-100.
-Dylan
[This message has been edited by dahester (edited 02-18-2001).]
Displays: Sony VPL-HW40ES | 110" SI Motorized Slate screen | Pioneer PRO-150FD
Sources: Sony BDP-S5000ES | Dune HD Smart D1 | Roku HD | LG LST-3410A HD-DVR
Speakers: Nearfield Pipedreams 18 (L,R,Sub1,Sub2), Pipedreams 15 (C)
| Magnepan MC-1 (WL, WR, SL, SR, SBL, SBR)
Audio: Denon AVR-4311CI | Bryston 6B-SST | Bryston 14B-SST
Control: Control4 home automation
dahester is offline
post #2 of 4 Old 02-18-2001, 11:39 AM
bb1987's Avatar
Originally posted by dahester:
Finally, yes you can use the model 5000 receiver and modulator for BEV, but once again you have to tamper with the access cards. The modulator DOES work correctly, and you can receive any channel that has AC-3 audio with an OTA HDTV tuner such as the DTC-100 (this includes ch. 285, 286, 291, most of the movie channels, and most of the PPVs too).
So how do you tamper with the access card?
Bernhard
[This message has been edited by dahester (edited 02-18-2001).][/b]
bb1987 is offline
post #3 of 4 Old 02-18-2001, 10:08 PM
majortom's Avatar
Not sure if this belongs here or in hardware but here goes:
I am trying to find out if a DishNetwork model 6000 receiver can be used to subscribe to ExpressVU in Canada. If I have DishNet for my U.S. address and just carry the receiver to my place in Canada can I use the same box to subscribe to ExpressVu?
If I can, can anyone tell me how many dishes do I need for ExpressVu (Dish needs 2, a model 300 and a model 500)?
Finally, does anyone know if ExpressVu would also support the DishModel 5000 with the 8VSB modulator (so that I can record the programs)?
Thanks in advance for your help.
/carmi
majortom is offline
post #4 of 4 Old 02-18-2001, 10:51 PM
patrickthickey's Avatar
The answer is "no" to all of your questions. EVu uses different SmartCards and the serial number sequences are different for the Canadian versions of the receivers.
patrick
Stop DFAST!
Stop it NOW.
patrickthickey is offline
Closed Thread HDTV Programming
