no audio on Houston Fox 27? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-15-2001, 10:19 PM - Thread Starter
mwschneider's Avatar
Is it just me, or is there really no audio on Houston's Fox 27 DTV channel? Is there some known problem with the TU-DST51A and Fox -- I recently bought mine, but haven't heard Fox since I hooked it up. All of the others seem fine...
-Mark
Mark Schneider, Cable Solutions
mwschneider is offline
post #2 of 3 Old 03-16-2001, 07:03 AM - Thread Starter
I see. That's not good. I mean, it's good that you're getting it, but bad that I'm not!
For what it's worth, Fox looked and sounded very good on my DTC-100, so I don't know what the deal is with my Panasonic TU-DST51A, or with the sync problem on your box. Arrrgh.
-Mark
post #3 of 3 Old 03-16-2001, 07:34 AM - Thread Starter
Well, I just hooked my DTC-100 back up, for a test, and there is no problem with the audio. Then I swapped back to the TO-DST51A, and no audio again. I cycled the power, but it did not change anything...other than the fact that the TU-DST51A did not return to the power-on mode -- I had to turn it back on.
Are there any other TU-DST51A users here in the Houston area? Can you guys hear audio on Fox 27, or is it peculiar to my box? I'm hearing audio from all of the other local OTA channels.
-Mark
Closed Thread HDTV Programming
