Battlestar Galactica on SciFi HD - Season 4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10191 Old 01-08-2005, 09:57 AM - Thread Starter
archiguy's Avatar
Quoted: 3943 Post(s)
Liked: 4090
Seems there was a thread on this a little while ago but a search didn't turn it up. Anybody know if this will be 1080i and/or DD5.1?
archiguy is online now
post #2 of 10191 Old 01-08-2005, 10:04 AM
dm145's Avatar
Quoted: 78 Post(s)
Liked: 44
Have you checked the obvious?:
http://www.nbc.com/nbc/header/TV_Schedule/index.html
8:00 PM NBC MOVIE: BATTLESTAR GALACTICA BATTLESTAR GALACTICA All New HDTV
dm145 is offline
post #3 of 10191 Old 01-08-2005, 10:20 AM
mikey p's Avatar
archiguy and dm145.......
First I also looked after getting a copy of the crips-o-gram, that stated NBC = NO HDTV TONIGHT! So I looked here first as you might expect and I likewise could not see the thread on the first few pages of programing. It frankly did not occur to me to look at the NBC site, I just assumed they would disappoint as they usually do! I'll try to record it (HD OTA) just in case, and did set the SD TiVo to record none the less. In the mean time my fingers are crossed. ;-O Good luck to any interested in this program. BTW; it starts (new shows) on SciFi Friday the 14th, SD sorry to say. Maybe it will show up on Uni-HD later?
It is "WOW" TV!
mikey p is offline
post #4 of 10191 Old 01-08-2005, 01:35 PM
Sc0rp10n's Avatar
will the new series of Battlestar Galactica be shown in HD anywhere? i'm not talking about the miniseries, just the new series. i know it's on scifi, so i would imagine i'm out of luck. just wondering if there are plans to re-air the shows on UHD or something.
Sc0rp10n is offline
post #5 of 10191 Old 01-08-2005, 02:22 PM
MarkW's Avatar
Well, UHD shows the Galactica in all its glory in there advertisements constantly so one would hope they will pick it up sometime after airing on Sci-fi. I've emailed UHD a couple of times with no response. My fingers are crossed.....
Mark...
MarkW is offline
post #6 of 10191 Old 01-08-2005, 04:37 PM
mikegt's Avatar
The showing tonight (Saturday) of the mini-series on NBC at 8 p.m. may be in HD.
Mike G.
mikegt is offline
post #7 of 10191 Old 01-08-2005, 05:03 PM
lowmazda's Avatar
HD on directv & dd 5.1
lowmazda is offline
post #8 of 10191 Old 01-08-2005, 05:08 PM
bfogelstrom's Avatar
Sure does not look like HD from WVIT-DT in Connecticut!
bfogelstrom is offline
post #9 of 10191 Old 01-08-2005, 05:10 PM
Versa's Avatar
The one on NBC right now is not in HDTV here (affiliate normally forwards HDTV), but I did see the "avalible in HDTV where avalible " picture when it started, and it is in cropped widescreen....
Versa is offline
post #10 of 10191 Old 01-08-2005, 05:10 PM
No HD from WVIT-DT in CT. And only 10 minutes to the first commercial - not a good sign!
post #11 of 10191 Old 01-08-2005, 05:13 PM
Chris Loker's Avatar
I had to call my local station to get them to flip the switch to HD. Not a real sharp HD though - a fairly soft film transfer from what I've seen so far.
Chris Loker is offline
post #12 of 10191 Old 01-08-2005, 05:20 PM
Jerry G's Avatar
http://www.avsforum.com/avs-vb/showt...hreadid=493076
Jerry G is offline
post #13 of 10191 Old 01-08-2005, 05:36 PM
Ken H's Avatar
HD 2.0 in Detroit.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #14 of 10191 Old 01-08-2005, 11:01 PM
Joxer's Avatar
I checked it at the beginning and it wasn't HD, only letterboxed SD. But I rechecked a half-hour later and it was in HD then!
Joxer is offline
post #15 of 10191 Old 01-08-2005, 11:12 PM
cappra's Avatar
HD 2.0 in Phoenix. Looked a little soft, but was enjoyable. Wish the Sci Fi channel was in HD!
cappra is offline
post #16 of 10191 Old 01-08-2005, 11:13 PM
inky blacks's Avatar
It was excellent HD in Eugene, Oregon.
What a bleak movie! The special effects were great, as was attention to technical details, but there sure were not allot of laughs. Just one to be exact. Very dark movie! I can see why I never heard about that movie until this week.
IB
inky blacks is offline
post #17 of 10191 Old 01-09-2005, 01:07 AM
turls's Avatar
Quoted: 478 Post(s)
Liked: 206
First, for those that saw it originally, did they cut enough off for it to be worth watching all the way through (its on my Tivo), 2nd if it was DD5.1, maybe it was because your local OTA has the 5.1 stuck in the "on" position.
2.0 in St. Louis. HD kicked in at the end of the credits.
Matt
turls is offline
post #18 of 10191 Old 01-09-2005, 04:24 AM
jones07's Avatar
Just got done watching Galactica on my Comcast 6412............Love this Box
NFL Play-off's and BG both recorded in HD at the same time....... I'm in nirvana.
Since I enjoyed the original 4 hour version it's hard for me to say if the shorter 3 hour version is "worth watching" for you. All I can say is that one can follow the premise of BG even if you was a new viewer that never heard of BG
WeÂre doomed. It will never work
jones07 is offline
post #19 of 10191 Old 01-09-2005, 07:16 AM
shah8's Avatar
Yeah, it *was* in 5.1 in Atlanta. It started out as 2.0 flaged as 5.1, and then went to actual 5.1
shah8 is offline
post #20 of 10191 Old 01-09-2005, 07:28 AM
John Mason's Avatar
Quoted: 76 Post(s)
Liked: 112
Seemed to be HD in NYC via NBC's fiber feed to Time Warner Cable. But only watched the start, then DVRed the rest to monitor live golf from Hawaii. Also might have been, unless an NBC insider chimes in, one of those fairly good-quality 1080i wide-screen upconverts, sometimes seen on PBS, that really requires studying fine on-screen details to pin down whether it's an upconvert or not. -- John
John Mason is offline
post #21 of 10191 Old 01-09-2005, 07:58 AM
Newbie's Avatar
I watched it mainly on Citytv Toronto, but I checked in during commercial breaks on NBC Boston and it was HD the whole time.
Citytv will also be broadcasting the series after it airs on Space (Canada's science-fiction channel) and will presumably have it available in HD.
Blu Loyal, HD Flexible
22 Blu, 10 Red + Heroes + Smallville Season 6
Newbie is offline
post #22 of 10191 Old 01-09-2005, 09:16 AM
I never watched the whole mini-series all the way through because it was a little long and drawn out. However, I enjoyed the 3 hour version. It cut out a lot of the filler and stuff that made the mini-series a little slow in my opinion. The mini-series was also a little over the top with the sex in your face stuff - I thought it was toned down well in the 3 hour version.
post #23 of 10191 Old 01-09-2005, 09:51 AM
mikey p's Avatar
Wonder........ "if"
SciFi show was a little over 4 hours, and you all know how much time they spend on commercials breaks.
NBC show was three hours and in HD here , I watched a lot of it, and copied it to D-VHS for a later view, seems NBC did not have near the same amount of time in commercials that they had on SciFi.
Do any of the "insiders" here know how much was cut for the NBC version, if any (not deleted stuff)? Actually, I really don't expect anyone who knows to fess up. I would not, as they were pushing the DVD sell through big time!
Bottom line IMHO is some of us got to see it in HD, if not DD5.1, so NBC came through for me, for a change. Win - Win! ;-)
It is "WOW" TV!
mikey p is offline
post #24 of 10191 Old 01-09-2005, 10:02 AM
Iteki's Avatar
Nothing vital was left out. Some personal tidbits...for example at the end when they were fighting their way out, and only Starbuck and Apollo were still out fighting, the original had Adama call Starbuck on the radio and order her to get back in. The implication was that she would have kept on fighting regardless.
Still not sold on the Starbuck as a female premise, but the actress did a credible job.
I'm no expert....so your mileage may vary
XboxLiveID: archie68
Iteki is offline
post #25 of 10191 Old 01-09-2005, 10:08 AM
mikey p's Avatar
"Still not sold on the Starbuck as a female premise, but the actress did a credible job."
Your age is showing........ ROFLOL. BTW; me too on the Starbuck opinion!
It was neat to see a version in HD. Have a great day.
It is "WOW" TV!
mikey p is offline
post #26 of 10191 Old 01-09-2005, 10:19 AM
Ken H's Avatar
It finished last in the overnight ratings.
Ken H is offline
post #27 of 10191 Old 01-09-2005, 10:29 AM
Iteki's Avatar
It has a snowball's chance in you-know-where...it was up against playoff NFL football in primetime.
Iteki is offline
post #28 of 10191 Old 01-09-2005, 11:05 AM
mikey p's Avatar
"It has a snowball's chance in you-know-where...it was up against playoff NFL football in primetime."
Your exactly RIGHT! Sorry to say most here, think the sun revolves around the ball sports, if so, where the HE** is ROLLERBALL-HD?
None the less, football be damned! I enjoyed the SciFi on NBC, for a change. Ken H; is this the type of post you were looking to get? ;-O I do wonder WHY you "mod's" stir the pot so much?
No wonder most here try to "lie, cheat, and steal" to get networks via D*! Can you say SUPER BOWL! DUH! I'm sure this gets you off................ YMMV
It is "WOW" TV!
mikey p is offline
post #29 of 10191 Old 01-09-2005, 11:10 AM
Ken H's Avatar
Take a pill.
Ken H is offline
post #30 of 10191 Old 01-09-2005, 11:13 AM
scowl's Avatar
Quoted: 122 Post(s)
Liked: 39
I'm so glad I bought another HD tuner card so I could record them both.
I was impressed and even shocked by how serious and well done Battlestar Galactica was. I don't know why $95 million sci-fi movies can't be made as well as a cable TV series/special.
NOW: my post on AVS Forum.
NEXT: someone else's post on AVS Forum.
scowl is offline
Reply HDTV Programming
