Verizon FiOS HDTV - Page 630 - AVS Forum | Home Theater Discussions And Reviews
 60Likes
post #18871 of 18876 Old 01-25-2016, 04:28 PM
dougotte's Avatar
Quoted: 87 Post(s)
Liked: 53
Originally Posted by aaronwt View Post
Is there an audio compression setting? If so, turn it off. I always turn that off with my devices.
That's a good question. The DVR does have an audio setting called Dynamic Range. It's set at "Heavy," but does that mean it's a "heavy" (aka "wide") dynamic range, with no compression, or does it mean "heavy" compression?
I have never changed this setting, and yet the issue just started happening w/ on-demand content over the past year. I never notice it while watching a channel or a DVR recording, but I admit I don't use the AVR very often, so maybe I haven't noticed it other than while watching on-demand.
Watching the news now, I tried the other two settings: "none" or "light" and the news announcers' voices were much quieter. I'll play w/ it while watching an on-demand movie and will report back. Thanks.
dougotte is offline
post #18872 of 18876 Old 01-25-2016, 04:58 PM
barth2k's Avatar
Quoted: 638 Post(s)
Liked: 449
None means no dynamic range compression. Heavy means more compression. More compression tends to give louder dialogue, at the cost of audio fidelity.
Also make sure you have audio format set to surround. In addition, you can go into the service and under additional HDMI settings, select format for audio output. Choices are Auto (not sure what that is), LPCM, and pass through (meaning Dolby usually). To get into service menu, press power, ok, menu in quick succession on the remote. This does not work if you are recording something.
mrkalel likes this.
barth2k is online now
post #18873 of 18876 Old 01-26-2016, 12:10 AM
GCAVS's Avatar
Quoted: 40 Post(s)
Originally Posted by dougotte View Post
I wonder how much bandwidth they can reclaim by using this effect, or is it something that helps their digital storage?
0 Bandwidth Saved
This isn't Analog.....its all 1s and 0s.
GCAVS is offline
post #18874 of 18876 Old 01-26-2016, 12:12 AM
GCAVS's Avatar
Quoted: 40 Post(s)
There is audio compression in the FiOS STB's setting (as well as others). I always turn it off on setup as well.
GCAVS is offline
post #18875 of 18876 Old Today, 05:30 PM
jackie C's Avatar
Have Verizon Fios Quantum . The Hd channels usually have 42 dBs signal strength. On Demand is 26 dB and the quality is bad but in the menu, they say both signals are "good"
Can anyone tell me if these numbers are up to snuff? Is there an "Excellent" signal strength and if so how do I achieve it? Have a new TV and the blacks are often crushed in On Demand. Any help would be greatly appreciated.
jackie C is online now
post #18876 of 18876 Old Today, 05:30 PM
jackie C's Avatar
Reply HDTV Programming
