Cox HDTV - Page 49 - AVS Forum | Home Theater Discussions And Reviews
Old 05-08-2010, 03:49 PM
DoubleDAZ's Avatar
Quoted: 273 Post(s)
Liked: 302
This is all just so much baloney. All they have to do is tie it to an account number, they don't have to tie it to a receiver serial number. They are just so hung up on over-securing their content and don't care about the consumer. I can bank securely from any computer anywhere in the world, yet I lose all my recordings if my DVR fails, that's really high tech.
Cheers, Dave
DoubleDAZ is online now
Old 05-08-2010, 07:56 PM
coyoteaz's Avatar
It isn't tied to a receiver serial number, it's tied to a security certificate within the box. This is similar to the security certificate your bank's website uses. If the private portion of that certificate were to become accessible, then anyone or anything else could impersonate the bank, or the box, and then the world as we know it would come to an end.
I'm not arguing in favor of the system or claiming that it is anything more than a power grab by a bunch of a-holes in Hollywood. Just explaining how it works and why the way you want it to work is incompatible with reality. Personally I'm in favor of being able to do anything you want with the content that you paid for, but in a country where the content producers own every major media outlet and use this power to control the political process, we're not likely to see anything different without a fundamental shift in the way things work. And I'll stop there lest this comment get too political and find its way to the bin.
coyoteaz is offline
Old 05-08-2010, 09:24 PM
Chere's Avatar
Quoted: 352 Post(s)
Liked: 185
Can someone tell me what the output for ESPN HD is if your HD DVR is seleted to Auto DVI/ HDMI? It's reading 1280x720 on my new HDTV on sportscenter. I thought it was supposed to be 1920x720.
Actually since getting my new HD DVR, picture quality has suffered on my set with a lot of noise and soft picture. I posted the signal strength on the last page and I thought that I had good readings. I've also tried all the other picture formatting options on my DVR and still no difference
Chere is offline
Old 05-08-2010, 10:30 PM
Bryan_CoxPHX's Avatar
Quoted: 112 Post(s)
Liked: 52
ESPNHD and ESPN2HD are both 720p on my set w/ Auto Selected
From Wikipedia
"720p has a widescreen aspect ratio of 16:9, a vertical resolution of 720 pixels and a horizontal resolution of 1280 pixels, that is 1280×720, for a total of 921,600 pixels. The 1280×720 format is always progressive scan, there is no interlace version of 1280×720.
1080i is the shorthand name for a format of high-definition video modes. 1080 denotes the number of horizontal scan linesalso known as vertical resolutionand the letter i stands for interlaced. In the alternate format of high-definition video mode, known as 1080p, the p would stand for progressive scan."
"1080i is a high-definition television (HDTV) video mode. The term usually assumes a widescreen aspect ratio of 16:9, implying a horizontal resolution of 1920 pixels and a frame resolution of 1920×1080 or about 2.07 million pixels."
Your signal: Tuner 1: @ 7/8 dBmV, is a little high, (is it displayed in orange or green? orange denotes out of ideal range), ideally it should be as close to 0dBmV as possible.
TiVo Bolt, Roamio Pro, Premiere XL4, Premiere 2TB-WD20EURS, TiVo Mini
Cisco Tuning Adapter Status Troubleshooting
Bryan_CoxPHX is offline
Old 05-08-2010, 10:36 PM
coyoteaz's Avatar
1280x720 is correct for 720p. 1080i is 1920x1080. Picture quality is not directly affected by signal strength unless there's so little that it causes errors, which would show as breakups in the picture.
What cables are you using? If you're using the Cox-provided component cables, try using HDMI instead.
coyoteaz is offline
Old 05-09-2010, 11:01 AM
Chere's Avatar
Quoted: 352 Post(s)
Liked: 185
I'm using HDMI. I have a brand new Samsung PN50C6500 and that might be the problem. I've tweaked it's picture settings and everything else and there's no change at all. I'll try it with a blu ray disc and see if I can pin it down to the set itself.
Chere is offline
Old 05-09-2010, 11:20 AM
Ken H's Avatar
For linear 24/7 HD networks, 1920x1080i and 1280x720p are the only HD formats used.
As noted, ESPN HD is 1280x720p.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Old 05-10-2010, 11:18 AM
nmajdan's Avatar
nmajdan is offline
Old 05-10-2010, 11:48 AM
DasRaven's Avatar
Good:
They seem to have chosen the 500GB variant of the 8642.
The Trio guide is quite nice.
The new black hardware is a must have.
MOCA networking for the Whole Home DVR and endpoints.
Bad:
I bet it'll be more expensive than my current two room HD/HDVR solution
It isn't here yet.
Still upgrading as soon as possible. Might as well push the Cox payment over $200/mo.
Built a new home, now filling it with sights and sounds!
DasRaven is offline
Old 05-10-2010, 03:48 PM
DoubleDAZ's Avatar
Quoted: 273 Post(s)
Liked: 302
Originally Posted by DasRaven View Post
Good:
Bad:
It isn't here yet.
I suspect it will require a receiver in each room and MoCA adapters that will also probably cost a few dollars per month. I wonder how much functionality it will provide. With a 3-tuner Moxi you can view 4 separate programs at the same time; 3 recorded and 1 live. I guess I need to check the Cisco site.
Cheers, Dave
Old 05-10-2010, 03:53 PM
phdeane's Avatar
I could be wrong, but I believe the MoCA capability is built in to the new receivers/DVRs. I'm sure they'll charge more, but you shouldn't need an additional MoCA device.
phdeane is offline
Old 05-10-2010, 04:08 PM
DoubleDAZ's Avatar
Quoted: 273 Post(s)
Liked: 302
I also got that idea when I saw how they referred to the 1642 receiver needed in each room. That sure would be a nice way if that is the case.
Edit: I checked the Cisco site and both the 8642 and 1642 have Cable-In w/MoCA, so it should all be plug & play.
Cheers, Dave
Old 05-10-2010, 05:26 PM
chvybeatsford's Avatar
Good:
Yeap ill be there too. $200+
chvybeatsford is offline
Old 05-10-2010, 08:06 PM
Chere's Avatar
Quoted: 352 Post(s)
Liked: 185
Anyone know how many tuners it's gonna have?
Chere is offline
Old 05-10-2010, 10:55 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Two. All Cisco/SA DVRs are 2-tuner models. It will tune up to 1GHz, so hello SDV.
http://www.cisco.com/en/US/prod/coll...3/7015625A.pdf
http://www.cisco.com/en/US/prod/coll...38/7014685.pdf
domino92024 is offline
Old 05-11-2010, 08:30 AM
DoubleDAZ's Avatar
Quoted: 273 Post(s)
Liked: 302
The bigger question for me is how many different programs (recorded or live) can be watched at the same time throughout the home? The Moxi supports at least 2 Mates and I know the Moxi setup can deliver at least 4 separate programs. That means people in 4 separate rooms can all watch something different, 3 recorded and 1 live program. DirecTV's new MR DVR is said to support up to 8 clients, but I don't know if that means 8 different recorded/live programs can be watched in 8 separate rooms. The way I read the literature for the 8642, you can only control it from different rooms, not watch something different. In other words, you can start to watch a recording in the family room and then move to the bedroom to finish it or everyone can watch the same recording at the same time. Of course, they can watch something live on the 1642, but that isn't even close to the Moxi in fiunctionality.
Cheers, Dave
Old 05-11-2010, 12:30 PM
phdeane's Avatar
Since they are 2-tuner boxes, then one could assume only two shows throughout the house may be recorded at one time. I'm not sure if multiple DVRs can be used throughout the house and still offer the MRV. Of course, that could get expensive.
phdeane is offline
Old 05-11-2010, 12:44 PM
DoubleDAZ's Avatar
Quoted: 273 Post(s)
Liked: 302
No question about that. However, the question is how many recordings can be viewed at a time. With a 3 tuner Moxi, 3 different recordings can be viewed in 3 different rooms at the same time from a single DVR. The key is that with the Moxi I could be watching one recording and my daughter watching another recording while my wife watches a 3rd recording or live TV. With the 8642 (or DirecTV's version of MR), my daughter and I would have to watch the same recording while my wife watches that recording or live TV and I'm not even sure about the live part.
Cheers, Dave
Old 05-11-2010, 01:47 PM
Quoted: 126 Post(s)
Liked: 216
Good:
It's not "Whole Home." Two additional rooms, only. And they need Explorer 1642 rentals.
Old 05-11-2010, 03:06 PM
DasRaven's Avatar
That depends on the "home." My home needs only one additional room and this solution is therefore "whole home," ymmv.
And I don't think anyone is expecting any (legal) multi-room solution to exist without an endpoint to do decryption of the secured stream.
DasRaven is offline
Old 05-11-2010, 04:21 PM
DoubleDAZ's Avatar
Quoted: 273 Post(s)
Liked: 302
Where are you reading that? There does have to be a 1642 on the other end, but I've seen nothing that says only two 1642's can be used.
Cheers, Dave
Old 05-11-2010, 05:18 PM
phdeane's Avatar
Sorry about that; misread your post. As per the press release:
Up to three different recordings can be viewed simultaneously on different televisions throughout the home.
phdeane is offline
Old 05-11-2010, 05:21 PM
phdeane's Avatar
Per this article:
Multiroom DVR support is provided via the Multimedia over Coax Alliance specification, to up to *two* Explorer 1642 HD set-tops.
Hardly "whole house" but that's what Cox calls it.
edit: the two 1642 limitation is not mentioned on the Cisco data sheets (warning: pdf links):
http://cisco.com/en/US/prod/collater...38/7014685.pdf
this statement from the 8642 data sheet is troubling:
...Record one program while viewing or recording another...
phdeane is offline
Old 05-11-2010, 07:06 PM
DoubleDAZ's Avatar
Quoted: 273 Post(s)
Liked: 302
Per this article:
That'll do it alright, thanks.
Yeah, just like our "friend int he digital age" several years late.
edit: the two 1642 limitation is not mentioned on the Cisco data sheets:
Possibly a limitation of the Trio software, though I suppose it might be hard for the hardware to produce more than 3 streams at the same time. Even so, I'm not sure one can watch different recordings at the same time in different rooms, so that still gives Moxi a big edge in my book.
I suppose it could be the way it is phrased, but I seem to recall that phrase early on for the 8300 too. If the statement is literally true, that is a real deal-breaker for me, a big step backwards. The only saving grace might be how they revamp their OnDemand service. If they add significantly more network primetime content, I might not even need a DVR.
Cheers, Dave
Old 05-11-2010, 07:23 PM
DoubleDAZ's Avatar
Quoted: 273 Post(s)
Liked: 302
Gosh, I feel stupid, I didn't even notice the press release button in the egadget link.
This seems to make it better than DirecTV's MRV setup.
BTW, pulled this out of the spec sheet for the 8642:
Dual tuning, Dual Record, Pause, Rewind, Fast-Forward, Record one program while viewing or recording another, software controlled
So, seems like it might do okay since I too only need the 3 room capability. Of course, I'll wait to see what the cost is for the new software, the higher price package and the needed 1642s.
It looks like this also ushers in paying higher prices for a package with additional HD channels. No longer are they going to be able to claim HD is free. Of course, DirecTV and others already do this, so they are just catching up.
Cheers, Dave
Old 05-11-2010, 10:11 PM
phdeane's Avatar
Yes, but that doesn't explicitly state it can dual record and watch another channel simultaneously. If you take another look at the 8642 data sheet, you'll notice is does state it will dual record; however, there is an operative word there, namely the "or."
Dual tuning, Dual Record, Pause, Rewind, Fast-Forward, Record one program while viewing *or recording* another, software controlled.
Let's just hope that is not a literal feature.
phdeane is offline
Old 05-11-2010, 11:27 PM
Quoted: 126 Post(s)
Liked: 216
Multichannel News article.
http://www.multichannel.com/article/...reen_Guide.php
Old 05-12-2010, 12:58 AM
Chere's Avatar
Quoted: 352 Post(s)
Liked: 185
On a simpler note, will this upgrade be free from my current HD DVR to the new one if I'm just doing a swap and not interested in multi room viewing functionality?
Chere is offline
Old 05-12-2010, 08:07 AM
DoubleDAZ's Avatar
Quoted: 273 Post(s)
Liked: 302
It's hard to say. Since your current DVR is not broken, they could charge you an install fee for the new 8642. When I exchanged my 3270 for the 8300 over 6 years ago, I still had to pay the install fee (though I did get it refunded-long story). At a minimum, you will have to pay the higher price they are going to charge for the 8642 and the new Plus Package. The way I read things, the Plus Package will include the Trio IPG, additional HD channels (yet to be named), and the MRV capability (even if you don't use it), but it will cost more. I'm sure we'll know more once they release it in the first markets.
Cheers, Dave
Old 05-12-2010, 10:59 AM
phdeane's Avatar
My guess is to get the new 8642 DVR, you *must upgrade* to the Plus package which will come at a premium per this excerpt from the Cox press release:
Customers can add the Plus Package to any level of Cox Advanced TV (digital video service) for a small monthly fee.
And this from the Multichannel News article:
The Trio guide will be available to Cox customers as part of the "Plus Package," which includes multiroom DVR service, *additional DVR storage* space and additional high-definition channels. Cox hasn't announced pricing but Necessary said the new Trio HD DVR will be offered at a premium.
phdeane is offline
